Humidity sensor & slider
    I have an Elsner knx humidity sensor
    I want to integrate this sensor to Loxone Server
    I have created a sensor for the current humidity value (This works well).
    No I want to have a slider to change the current target humidity value.
    I try several ways to add the corresponding group address to the loxone config (sensor,actuator,...) but I can figure out how I can change this value through a slider.
    I click on the "Use" in "User interface"
    I change the datatype to EIS6 0-100%
    However no slider appears in the gui
    How can I do that?
    When this is a sensor value, you cannot change the value - it's value is from the sensor.
    What are you considering to do with the sensor value?
      I know sensor is for input and actuator for output.
      I create one sensor for the current humidity rate --> Ok it's a read only value in the interface
      I create one actuator for the targetted humidity rate (I select the dimming input type, I select "Use" in web interface but the result is the same, no slider appears in the web interface
      Idon't know if a dimmer button can help me because in this case the humidity can change after a couple of minutes
        Both sensors and actuators cannot be changed in the App/webinterface.
        You can create a virtual input to act as a slider to set values.
        You'll need some logic in between, but, again, please explain what you are trying to do, otherwise we cannot help.
          I want to have as less logic as possible in the loxone server.
          The humidity hardware sensor has:
          - an actual humidity rate through a knx address (I want to display it through the web interface --> this part is ok)
          - a configurable target humidity rate through a knx address (I want to change this value with the web interface)
          Just try to link a virtual input with the actuator, untick "use as digital input" now I have a slider.
          What will be the default value of the slider? How to link this field to the knx address?
          Zuletzt geändert von Gast; 02.01.2017, 17:43.
