Relay works also in pulse mode with adjustable delay
Ankündigung
Keine Ankündigung bisher.
Relay board controlled over HTTP POST is not working
Today I finally installed the board. TCP works perfectly because of this nice topic.
However, the inputs do not work. How did you connect the fysical inputs?
I tried to measure the voltage between input 1 and com, but there is nothing!? Can you please measure what you have?
Hi all,
I have followed your post here and I bought the same relay board.
I am done with the relay commands, this is working perfectly through HTTP GET.
Now I would like to know the status of the inputs from the Miniserver. I am able to view the state of the inputs through a HTTP Post (http://192.168.1.166/state.cgi) and I have a text like "10000000" which says that the 1st input is activated. How to decode that information in the Miniserver ? I think I have to do a mask for each input, or to convert from binary to decimal, then back to binary ?
How did you do ?
Thanks,
I just found how to to it, maybe this might help some people.
1) I have created a virtual HTTP input
2) I have set in the URL : http://admin:12345678@192.168.1.166/state.cgi
3) I have created 8 HTTP virtual input signals : one for each input (I have 8 inputs on my relay board)
4) In the command detection I have set "input":\s0\1 for the first input, "input":\s1\1 for the second input, etc...
5) When the input state is 0, the Miniserver returns "48" which is "0" in ASCII
6) When the input state is 1, the Miniserver returns "49" which is "1" in ASCII
7) I put in my logic a statement "Input value = 49" --> Memory flag "Input is active"
Exactly the same to know the state of the outputs (relay). Instead of "input":\s0\1 just type "output":\s0\1 for the first output
The thing is, with that relay board we can only poll in TCP every 10 seconds. It is not UDP, so the refresh is not very good...
Thanks to Christian Fenzl who helped me with that, and told me that we could also put a "Status" block to convert the "48" value in 0 and the "49" value in "1".
Zitat von Christian Fenzl Beitrag anzeigenThis is not Modbus communication!
It seems to be fairly simple.
Create a Virtual Output with address
tcp://192.168.1.166:1234
Create a Virtual Output Command with
Command for ON:
L1\r\n
Command for OFF:
D1\r\n
Use as digital output: YES
That's it.
You have to send an ON state (for example from a switch block), not an impuls.
Greetings to all!
Can I ask you a question ?
How do I create a Create a Virtual Output?
Sorry, I don't know much about it!
Very thanks
What program do you mean? Loxone Config software?LoxBerry/Plugin Support: Wenn du einen Begriff in meiner Antwort nicht auf Anhieb verstehst, bitte nicht gleich rückfragen, sondern erst die Suche im LoxWiki und bei Google bemühen.
Hi everyone
has anybody any more info on this board please? Documentation, firmwares and so on.
i have received two of them and firmwares are different. Plus the boards send/receives mqtt data to some chinese cloud. Some chinese could control your relays.
please answer if you have any more info. The winddeal.net address with the firmware is not working either.
thanks
