Additional RJ45 Relay board for loxone?
Hello Helmut,
I have unfortunately no electronics experience. Can I implement the simple? Can you explain that to me I have nothing found (or not searched right)- Neubau EFH Einzug November 2016
- MiniServer + Extension + Dimmer + DMX + 1-wire
- Finder Slave Dimmer + KMtronic RS485 Relay Board
- Start Programmierung 29.10.2016 - Fertigstellung......
- LoxberryKommentar
Hallo Helmut,
ja ich kann deutsch
. Ich schreibe dir eine PN.
- LoxberryKommentar
Thanks for your response. If I'm not mistaken, I would need an extra module for this to work?
I only have UTP available in my "garden house". So I would need a RJ45 network relay card I guess. Next to several outputs, I would also need several inputs.Kommentar
I'm using the KMTtronic stuff. controllable with http-commands
http://info.kmtronic.com/kmtronic-la...lay-board.html
For the outputs you have now already a solution. For inputs, check out Pokey's 57e. Goes also over LAN.- Neubau EFH Einzug November 2016
- LoxberryKommentar
Both, thanks for the info!
Thomas, can you give me some more details of your setup?
[never mind what is written below. I thought that the status LED where inputs.]
- Is it possible to see in loxone that the input on the KMTronic is changed?
- Are the inputs pulse or on/off?
The sketch what I want to do is the following:
It should be possible to set the lights on in my "garden house" by switch.
Furthermore it schould be possible to set the light to off, even when it is switched on in the "garden house". A pulse switch would be the best option, I guess.
To come to pokey 57. My german is not that good, but if I'm not mistaken this is a self built instrument?Zuletzt geändert von K.Clemens; 02.11.2016, 17:15.Kommentar
Hi, me?? I am quite new in the topic! I am programming for a week my system and hope to move in the new house end of november.
I have all infos here from the forum (and the wiki) and when I have time I will also give back some. All the people here with more experience make a great job here in the forum.
I have KMtronic as output in use. You have one LEDs for each output. Everything you need to know about pokeys here and in the wiki be provided by Helmut.
Give me one more month then I will introduce my system and then maybe a few of your questions are clarified.
- LoxberryKommentar
Hello,I'll use the RS485 Version of the KMTronic...
Why...
- less Standby-Consumption as the LAN Version
- 10A Relais instead of 5A from the Arduino Relais-Board
- easy to control it with the Loxone MS
- Price... Yes you need an additional Ext RS485, but if you need 6,7... Boards it make sense because of the cheaper price of each board.
with the new release of Config 10.3 the KM-Tronic Web-Relay board is no more working fine... Lot of delay between commands and status reply.
Do you know if something has changed at the HTTP Virtual Outputs settings?
Keep in mind I've used them just fine until last wk... so I'm wondering about some last changes in the FW done for the release... here attached a setting screenshot of this Virtual Output1 BildKommentar
I don`t use KM-Ethernet only RS485.
But I use other devices with http Connection, they don`t have any delay and work fine after Update.
Do you use the stable verion or the public beta Config-Software? -
I'm using 10.3 stable release since yesterday. Last week I used the public beta without issues... Now I see the same problem with two different projects.
Do u also have Virtual Outputs commands with your HTTP devices ?
p.s. My KM-Modbus are working fine too. -
Yes I have, 2 of my 8 Channel Control Boards for my zome-amplifers are working with http.
No Problem with them.
