ramlog voll
  • Witte
    • 30.12.2019
    • 147
    #31
    Ok, nochmal ein Update.
    root@loxberry:/proc/14772/fd# lsof -nP +L1
    lsof: no pwd entry for UID 1000
    COMMAND PID USER FD TYPE DEVICE SIZE/OFF NLINK NODE NAME
    rpimonito 3013 root 2w REG 254,0 94995482 0 35 /opt/loxberry/log/plugins/rpi_monitor/RPi-Monitor_daemon.log (deleted)
    apache2 14770 loxberry 9u REG 254,0 0 0 507 /tmp/.ZendSem.Gwx76q (deleted)
    apache2 14771 loxberry 9u REG 254,0 0 0 507 /tmp/.ZendSem.Gwx76q (deleted)
    apache2 14772 loxberry 9u REG 254,0 0 0 507 /tmp/.ZendSem.Gwx76q (deleted)
    apache2 14773 loxberry 9u REG 254,0 0 0 507 /tmp/.ZendSem.Gwx76q (deleted)
    apache2 14774 loxberry 9u REG 254,0 0 0 507 /tmp/.ZendSem.Gwx76q (deleted)
    apache2 14814 loxberry 9u REG 254,0 0 0 507 /tmp/.ZendSem.Gwx76q (deleted)
    apache2 14834 loxberry 9u REG 254,0 0 0 507 /tmp/.ZendSem.Gwx76q (deleted)
    apache2 15883 loxberry 9u REG 254,0 0 0 507 /tmp/.ZendSem.Gwx76q (deleted)
    apache2 19207 root 9u REG 254,0 0 0 507 /tmp/.ZendSem.Gwx76q (deleted)
    rpimonito 24118 1000 2w REG 254,0 94995482 0 35 /opt/loxberry/log/plugins/rpi_monitor/RPi-Monitor_daemon.log (deleted)
    rpimonito 24119 root 2w REG 254,0 94995482 0 35 /opt/loxberry/log/plugins/rpi_monitor/RPi-Monitor_daemon.log (deleted)
    root@loxberry:/proc/14772/fd# : > /proc/24118/fd/2
    root@loxberry:/proc/14772/fd# : > /proc/24119/fd/2
    rpimonito 3013 root 2w REG 254,0 0 0 35 /opt/loxberry/log/plugins/rpi_monitor/RPi-Monitor_daemon.log (deleted)
    rpimonito 24118 1000 2w REG 254,0 0 0 35 /opt/loxberry/log/plugins/rpi_monitor/RPi-Monitor_daemon.log (deleted)
    rpimonito 24119 root 2w REG 254,0 0 0 35 /opt/loxberry/log/plugins/rpi_monitor/RPi-Monitor_daemon.log (deleted)
    root@loxberry:/proc/14772/fd# df -h
    Filesystem Size Used Avail Use% Mounted on
    /dev/root 15G 8.0G 6.4G 56% /
    devtmpfs 1.8G 0 1.8G 0% /dev
    tmpfs 2.0G 20K 2.0G 1% /dev/shm
    tmpfs 2.0G 203M 1.8G 11% /run
    tmpfs 5.0M 0 5.0M 0% /run/lock
    tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
    /dev/mmcblk0p1 6.4G 40M 6.4G 1% /boot
    /dev/zram0 386M 14M 343M 4% /opt/loxberry/log/ramlog
    tmpfs 391M 0 391M 0% /run/user/1001
    overlay 15G 8.0G 6.4G 56% /var/lib/docker/overlay2/87a1a3a245d595d4c258f5a554b1ae9be1accc9d2ef70a430e 815998fb1a792f/merged
    overlay 15G 8.0G 6.4G 56% /var/lib/docker/overlay2/c836bf807b12a1f683c8186179173e4133e15b3c20f264b431 35063ea9bc1e67/merged
    overlay 15G 8.0G 6.4G 56% /var/lib/docker/overlay2/371fdb69f2b8c10b542deedc8633f8e33fab8237e49941503b c0c197f64a567c/merged
    overlay 15G 8.0G 6.4G 56% /var/lib/docker/overlay2/6a62a32e6f14cde623d4f16e50fcb4396d3d63a7d6da714f56 c85b583f3a011b/merged
    shm 64M 0 64M 0% /var/lib/docker/containers/33e7e370d2b0f1ff8658368a14f9b4154c7fc3bf0e6bb6df3b 405e7606c5670e/mounts/shm
    overlay 15G 8.0G 6.4G 56% /var/lib/docker/overlay2/aab7fe28f4ad10c1eb636bd2bb4d668dfdd2c77f626206804a 5ffaa7db241ff3/merged
    -> nachdem ich die FileDescriptoren vom rpimonitor genullt habe ist der ramlog wieder auf 14mb (vorher 103mb)
    scheinbar hat der rpimonitor selber ein ResourceLeak...wie könnte man das beheben?
    Zuletzt geändert von Witte; 17.03.2021, 11:08.
    • Witte
      • 30.12.2019
      • 147
      #32
      Update: Als Maßnahme hab ich jetzt erstmal das RPIMonitor Plugin deinstalliert, seitdem ist die Speicherbelegung vom ramlog konstant.
      • TomekWaw
        TomekWaw kommentierte
        I do not recommend running RPiMonitor as it heavily writes to the SD Card.
    • Iksi
      • 1112
      #33
      ich hatte das gleiche Problem. Ich musste ca. alle 7 Tage den Loxberry neu starten, da das Ramlog voll war.
      Mit den Befehlen aus dem Wiki konnte ich allerdings nicht herausfinden woran es lag. Mittels "df -h /var/log" konnte ich zwar sehen dass das ramlog komplett voll war. Die anderen 4 Befehle zum überprüfen der 4 Verzeichnisse haben aber immer nur ein paar MB zurück gegeben...
      Jetzt habe ich auch das RPIMonitor Plugin deinstalliert und siehe da, keine Probleme mehr.
      • Noschvie
        • 24.09.2018
        • 692
        #34
        Siehe Forum : https://www.loxforum.com/forum/projektforen/loxberry/allgemeines-aa/242152-ramlog-voll?p=300705#post300705
        • Wörsty
          • 06.11.2015
          • 203
          #35
          In der Version von heute ist das behoben. Ihr hättet aber auch einfach das Logging im Plugin ausschalten können...
          Loxone Miniserver (letzte Beta) in KNX Umfeld
          • Noschvie
            • 24.09.2018
            • 692
            #36
            Danke für die Korrektur!
            Norbert
            • Noschvie
              • 24.09.2018
              • 692
              #37
              Mein "RAM-Disk voll" Problem wurde durch RPi-Monitor Plugin Version 2021.06.14 gelöst.
