Installed Loxberry in Raspberry PI 3 Model B+ microSD card compatibility
  • ager
    • 15.11.2017
    • 48
    Hi Christian Fenzl
    I have found and solved it here as you wrote and it start all work OK.
    After all working great I made backup of loxberry by win32DiskImager.
    I start update loxberry and I have done:
    04.03.2023 02:36: LoxBerry Update: A new version was installed successfully: v2.0.0
    04.03.2023 02:23: LoxBerry Update: A new version was installed successfully: v1.4.4
    06.03.2019 16:14: LoxBerry Update: A new version was installed successfully: v1.4.0.3
    23.09.2018 23:53: LoxBerry Update: A new version was installed successfully: v1.2.4.5
    11.09.2018 21:00: LoxBerry Update: A new version was installed successfully: v1.2.3.2
    I am not able to do update from v2.0.0 to v2.2.2.2 and here is my log.
    In version v2.0.0 I have tried widget backup but it doesnt work so widget backup work only from loxberry V2.2.2.2 please?
    Any help please?
    Many Many thanks​!
      Prof.Mobilux Hast du eine Idee, wie wir da drüber kommen? Beim 2.0.2 FW-Update läuft er fehlerfrei durch, aber der /boot Check liefert dann trotzdem einen Fehler.
      Hart auf 2.0.2 setzen?
        This is the kernel update which fails. Maybe because of a too small boot partition. You can ignore the error (remove the failed script from general.json) and then go to LB 3.0.
      ager
      So, via the file share or via Putty, edit these files in /opt/loxberry/config/system
      general.json
      general.cfg
      In both, remove the Failedscript tag without destroying the file format.
      If editing under Windows, use Notepad++, not the standard Notepad, to not destroy Linux line-endings.
      The update then should bring you up to 2.2.2.2 (if nothing else fails).
      Christian
      • ager
        • 15.11.2017
        • 48
        Thanks a lot for help Christian Fenzl and Prof.Mobilux
        I did it but no help.
        I connect to loxberry by FTP from windows program Winscp.
        In general.cfg there is no line Failedscript so I didnt touch.
        In general.json there is line Failedscript:
        I couldnt edit file directly due to no permissions.
        So I copied general.json file to PC, edited in PC by deleting this line.
        before:
        "Update": {
        "Branch": null,
        "Dryrun": null,
        "Failedscript": null,
        "Installtype": "notify",
        "Interval": "1",
        "Keepinstallfiles": null,
        "Keepupdatefiles": null,
        "Latestsha": "",
        "Releasetype": "release"
        "Watchdog": {
        after:
        "Update": {
        "Branch": null,
        "Dryrun": null,
        "Interval": "1",
        "Latestsha": "",
        "Watchdog": {
        Then I deleted original general.json file in loxberry by Winscp.
        Then I copied edited general.json file to /opt/loxberry/config/system.
        No reboot of loxberry.
        I Have tried install loxberry to v2.2.2.2.
        It didnt passed again errors.
        I did reboot of loxberry.
        I have checked general.json in /opt/loxberry/config/system​ and there was back Failedscript line again.
        I repeat process as mentioned to delete this line.
        Reboot loxberry.
        I have checked general.json in /opt/loxberry/config/system​ and there was NO Failedscript line.
        See log file in attachment.
        Any help please?
        Many thanks
        • ager
          ager kommentierte
          Guys can you please reply if there is any solution to avoid instalation from beggining or I will keep loxberry 1.4.0.3 version please?
          Many thanks
