1) MQTT funktioniert nicht:
Mosquitto not running.
● mosquitto.service - Mosquitto MQTT Broker
Loaded: loaded (/opt/loxberry/system/systemd/mosquitto.service; enabled; v>
Active: failed (Result: exit-code) since Sun 2023-03-05 20:07:00 CET; 13s >
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Process: 14334 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=e>
Process: 14335 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=e>
Process: 14336 ExecStartPre=/bin/touch ${LBSTMPFSLOG}/mosquitto.log (code=e>
Process: 14337 ExecStartPre=/bin/chown mosquitto:loxberry ${LBSTMPFSLOG}/mo>
Process: 14338 ExecStartPre=/bin/chmod 640 ${LBSTMPFSLOG}/mosquitto.log (co>
Process: 14339 ExecStartPre=/bin/ln -sf ${LBSTMPFSLOG}/mosquitto.log /var/l>
Process: 14340 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exite>
Process: 14341 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exite>
Process: 14342 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.co>
Main PID: 14342 (code=exited, status=1/FAILURE)
CPU: 79ms
Mar 05 20:07:00 loxberry systemd[1]: mosquitto.service: Scheduled restart job, >
Mar 05 20:07:00 loxberry systemd[1]: Stopped Mosquitto MQTT Broker.
Mar 05 20:07:00 loxberry systemd[1]: mosquitto.service: Start request repeated >
Mar 05 20:07:00 loxberry systemd[1]: mosquitto.service: Failed with result 'exi>
Mar 05 20:07:00 loxberry systemd[1]: Failed to start Mosquitto MQTT Broker.
lines 1-22/22 (END)
Loaded: loaded (/opt/loxberry/system/systemd/mosquitto.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2023-03-05 20:07:00 CET; 13s ago
man:mosquitto(8)
Process: 14334 ExecStartPre=/bin/mkdir -m 740 -p /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 14335 ExecStartPre=/bin/chown mosquitto /var/log/mosquitto (code=exited, status=0/SUCCESS)
Process: 14336 ExecStartPre=/bin/touch ${LBSTMPFSLOG}/mosquitto.log (code=exited, status=0/SUCCESS)
Process: 14337 ExecStartPre=/bin/chown mosquitto:loxberry ${LBSTMPFSLOG}/mosquitto.log (code=exited, status=0/SUCCESS)
Process: 14338 ExecStartPre=/bin/chmod 640 ${LBSTMPFSLOG}/mosquitto.log (code=exited, status=0/SUCCESS)
Process: 14339 ExecStartPre=/bin/ln -sf ${LBSTMPFSLOG}/mosquitto.log /var/log/mosquitto/mosquitto.log (code=exited, status=0/SUCCES>
Process: 14340 ExecStartPre=/bin/mkdir -m 740 -p /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 14341 ExecStartPre=/bin/chown mosquitto /run/mosquitto (code=exited, status=0/SUCCESS)
Process: 14342 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
CPU: 79ms
Mar 05 20:07:00 loxberry systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
Mar 05 20:07:00 loxberry systemd[1]: mosquitto.service: Start request repeated too quickly.
Mar 05 20:07:00 loxberry systemd[1]: mosquitto.service: Failed with result 'exit-code'.
2)Zigbee2MQTT funktioniert auch nicht:
Habe extra das Plugin auf neue Version 1.7.0 aktualisiert.
LOG anbei.
Alle benötigten Logs anbei !
Ich werd jetzt mein Backup 2.2.2.2 wieder einlegen.
Danke,vielleicht kann mir wer helfen.
