Fronius Hybrid with Modbus TCP
  • HBeumer
    • 24.02.2017
    • 47
    #76
    Zitat von Tico
    I have hit a snag with one of the Fronius Hybrid modbus commands - namely, putting the inverter into STANDBY mode. It has stopped working.
    There are three possibilities I've considered -
    1. A bug has been introduced by a Fronius firmware update;
    2. A bug has been introduced with a Loxone firmware update; or
    3. A hardware fault has developed in my inverter.
    I can't tell the exact time when the STANDBY mode stopped working, but the timeframe could include all the above.
    Can anyone confirm whether their system works to place the inverter into STANDBY using Loxone?
    The specific register is called CONN. It's a read/write register that can have two values -
    0 = STANDBY
    1 = ON
    The CONN register is being successfully written to and reflects the correct value from the modbus sensor. The inverter is not physically going into Standby when observed at the inverter.
    I know this is a very old message by now, but I want to have the ability to switch my Fronius Symo (non-hybrid, non gen24) into standby mode when the electricity prices are negative and producing energy is going to cost me money. Is it correct that for this I need to write a "0" to register 40241 and a "1" to resume solar production again?
    Also seems that in the current template from the wiki the "input value 2" and "target value 2" are set to 100, while this example seems to set them to a value of 10. Would this matter much?
    Zuletzt geändert von HBeumer; 11.02.2024, 18:27.
    • Tico
      Tico kommentierte
      Yes, register 40241 is correct; 0 for Standby and 1 for On. If "Input Value 2" and "Target Value 2" are the same, it makes no difference.
      I have the following set just as a reminder to myself of the expected values at the input -
      Input Value 1 = 0
      Target Value 1 = 0
      Input Value 2 = 1
      Target Value 2 = 1
    • HBeumer
      HBeumer kommentierte
      I managed to implement this and it works like a charm. Thanks for the help.
  • tga1317
    • 25.02.2020
    • 5
    #77
    Hallo Zusammen!
    Denke mein Problem auf dem ich gerade auflaufe könnte hier zu diesem Thread passen..
    Ich versuche vergebens das Register 40361 (40360) MinRsvPct auszulesen.
    Eingestellt habe ich IO-Adresse 40360, Befehl 3 - Read Holding Register, Datentyp 16-bit unsig. integ.
    Es gibt mir immer nur ein "0" aus.
    Diverse andere Register wie z.B. 40091 "AC-Power" lese ich erfolgreich aus.
    GRUND:
    Ich möchte den aktuell eingestellten "Setpoint for min. reserve for storage" auslesen.
    Nach erfolgreichen auslesen möchte ich per Modbus auch darauf schreiben um damit per Loxone vorzugeben wie weit (SOC) der Akku entladen werden darf.
    Hat den einfachen Grund, wenn wie vergangene Woche schlechtes Wetter vorhergesagt wird, dass ich umschalten kann, dass immer 70% im Speicher bleiben für Fullbackup Reserve.
    2. Frage:
    Kann ich per Modbus auch auslesen wenn der GEN24 in Full Backup Mode ist?
    Möchte damit bewerkstelligen, dass wenn wir im Backup Betrieb sind die Jalousien nach oben fahren.
    Danke vielmals schon vorab für die Unterstützung.
    • Tico
      • 31.08.2016
      • 1035
      #78
      Ich glaube, das MinRsvPct-Register im Gen24 ist Adresse 40351 (Loxone 40350). Es gibt auch einen Minimum Reserve Skalierungsfaktor, MinRsvPct_SF als 40365 (Loxone 40364). In meinem Fronius Hybrid ändert sich dieser Wert nie von -2. Die Gen24 kann anders sein.
      Der Actuator sieht wie folgt aus. Ich habe den Wert des Skalierungsfaktors auf eine Konstante von -2 geändert.
Name: Min Reserve.png
Ansichten: 654
Größe: 21,9 KB
      Alle Modbus-Befehle funktionieren im Backup-Modus in meinem Fronius Hybrid wie gewohnt. Ich habe eine kleine USV, die den Miniserver und den Router für die Umschaltung in den Notfall-Backup-Modus sichert. Seien Sie vorsichtig bei der Wahl Ihrer USV. Einige halten den Ladezustand im Backup-Modus bei 53 Hz nicht aufrecht und greifen auf die interne Batterie der USV zurück.
      • tga1317
        tga1317 kommentierte
        40350 gibt mir im LiveView aus: 65535
        40364 gibt mir im LiveView aus: 5
        Auf der Weboberfläche vom Wechselrichter ist als min. Ladezustand 75% eingestellt aktuell.
        Irgendwie will das ganze nicht so wie es soll. Danke auf jeden fall für die rasche Hilfe!
    • Tico
      • 31.08.2016
      • 1035
      #79
      Haben Sie in den Modbus-Einstellungen des Wechselrichters Float oder Int&SF eingestellt?
      Float -
      MinRsvPct = 40361 (Loxone 40360)
      MinRsvPct_SF = 40375 (Loxone 40374)
      Int&SF -.
      MinRsvPct = 40351 (Loxone 40350)
      MinRsvPct_SF = 40365 (Loxon 40364)
      Ich habe versucht, die Zip-Datei mit den maßgeblichen Modbus-Codes unten anzuhängen.
      • tga1317
        Wechselrichter ist Eingestellt auf "float"
        Modbus Register Nummern hatte ich aus der Excel im Anhang "Gen24_Primo_Symo_Inverter_Register_Map_Float_stor age.xlsx"
        Habe alles soeben auf den Miniserver Geladen folgende Rückmeldung:
        40360 (3 - read holding register, 16bit uint) - hier wird mir 0 ausgegeben.
        40374 (3 - read holding register, 16bit uint) - hier wird mir 65534 ausgegeben.
        Bei der Korrektur in der Config ist eingestellt:
        Eingang 1 = 0
        Zielwert 1 = 0
        Eingang 2 = 100
        Zielwert 2 = 100
        Einheit <v>
        Ich habe schon vieles versucht aber er will mir einfach nicht die Werte korrekt anzeigen.
    • Tico
      • 31.08.2016
      • 1035
      #80
      Prüfen Sie, ob Sie die folgenden Einstellungen vorgenommen haben. Am wichtigsten ist es, die Wechselrichtersteuerung über Modbus zuzulassen. Die Gen24 sieht etwas anders aus, hat aber die gleichen Optionen.
      Restrict Control ist nicht unbedingt erforderlich. Ich habe es mit der IP-Adresse des Miniserver ausgewählt.
      Stellen Sie sicher, dass Sie beim Wechselrichter als Benutzer: Service angemeldet sind. Einige Optionen sind sonst nicht sichtbar.
Name: Inverter Control.png
Ansichten: 562
Größe: 42,0 KB
      • tga1317
        Hallo, ja alles genau so konfiguriert.
        Einige andere Werte lese ich ja bereits aus und die Funktionieren - als Bsp.:
        40091 (3 - read holding register, 32bit floatingpoint) - hier wird mir AC-Power korrekt ausgegeben
        40101 (3 - read holding register, 32bit floatingpoint) - hier wird mir lifetime energy in kWh korrekt ausgegeben
        40361 (3 - read holding register, 16bit unsign.integ) - hier wird mir der aktuelle Ladezustand vom Akku in % korrekt ausgegeben
        Kann mir das einfach nicht erklären. Danke für die Mühe! LG
      • Tico
        Tico kommentierte
        Ich kann nur vorschlagen, einen Screenshot der Sensoreigenschaften zu posten. Vielleicht fällt etwas auf.
        Ansonsten sind mir die Ideen ausgegangen. Vielleicht ist es an der Zeit, ein Problem bei Fronius zu melden.
    • tga1317
      • 25.02.2020
      • 5
      #81
      Gerne, hier ein Screenshot der beiden Register.
      • Tico
        Tico kommentierte
        Ja, sie sehen völlig in Ordnung aus.
        Mir sind die Ideen ausgegangen, aber Sie könnten versuchen, alles zu löschen, was Sie erstellt haben, und die Vorlagen von diesem Loxwiki-Link herunterladen -
      • SPS-Guru
        SPS-Guru kommentierte
        Bei Daten-Typ / 16-Bit Register anhacken!?
    • hme0354
      • 06.07.2019
      • 1042
      #82
      tga1317 probier mal beim Fronius int + SF mit folgenden Settings. Hatte das Problem auch, aber so geht es.
      • Temminator
        • 12.01.2024
        • 14
        #83
        Hallo, Super Arbeit die ich hier gefunden habe.
        Ich habe nur leider das Problem, das ich den BYD Speicher nicht aus dem Netz laden kann.
        Es Funktioniert den Speicher in das Netz zu entladen, wenn ich -10000 in OutWRte schreibe.
        Meine frage ist nun, welche Modbus Register müssen wie beschrieben werden, damit ich aus dem Netz in den Speicher laden kann?
        Ich habe den Eindruck, das StorCtl_Mod auf Adr. 40358 nichts ändert.
        InWRte liegt auf 40366
        OutWRte liegt auf 40365
        Mein Symogen24 steht auf Float.
        • Tico
          • 31.08.2016
          • 1035
          #84
          On the previous page at Post 80 is a screenshot of controlling priorities. Can you confirm that 'Controlling via Modbus' is uppermost?
          Otherwise, to ensure that you load from the network, StorCtl_Mod should be set to value 3. Then InWRte should be set to 10000 and OutWRte should be set to -10000.
          If the StorCtl_Mod sensor in your image above isn't changing to reflect value 3, then you have a more fundamental problem in the Modbus control. Ensure Command = 6 (Write Single Register 0x06), Data Type 16-bit Unsigned Integer.
          InOutWRte_SF in your image above should be -2. The fact that it reads 8244 says something else is not correct. 16bit Signed integer set?
          • Temminator
            • 12.01.2024
            • 14
            #85
            Vielen Danke, für Ihre Hilfe, es funktioniert.
            Es lag an der Korrekten Werte Vorgabe.
            Jetzt wo ich gesehen habe, das der Entladewert negativ und der Beladewert Positiv sein muss, viel mir auch wieder ein, dass das ja auch so ist, wenn ich die werte vorgabe im WebIF vom Wechselrichter Batterievorgabe -> Zeitabhängige Batteriesteuerung mache.
          • Triple-M
            • 17.12.2018
            • 323
            #86
            Ich habe die Steuerung über Modbus bei meinem alten Symo Hybrid schon länger nicht mehr benutzt aber ich wollte jetzt ein Ladelimit einstellen das der Akku nur bis x% geladen wird und das auch nur mit x kw aber irgendwie klappt das nicht mehr. Wenn ich den Aktor "StorCtl_Mod" auf 1 oder 3 stelle dann wird die Ladung auch ganz kurz eingestellt aber nach 2-3 Sekunden wird schon wieder weitergeladen. Das kann ich immer so weiterführen, wenn ich z.B. wieder von 3 auf 1 umstelle dann wird ganz kurz das Laden unterbrochen aber dann auch schon vorgeführt. Irgendwie bleibt der Befehl nicht oder wird gleich wieder überschrieben. Woran kann das liegen?
            • SPS-Guru
              • 27.12.2022
              • 141
              #87
              Hast du in der Zwischenzeit etwas geändert ?
              Benutzt du das neue Fronius Plugin ?
              Zusammen mit dem Plugin funktioniert das nicht mehr da wohl die selben Register benutzt werden und
              Fronius/Loxone es nicht geschafft haben Lade-/Entladeleistungsbegrenzung und Zwangsladung/Entladung
              zu implementieren.
Ansichten: 293
Größe: 83,6 KB
              • Triple-M
                • 17.12.2018
                • 323
                #88
                Ja das neue Plugin nutze ich auch aber aktuell nur für die Zähler usw., nicht für die Steuerung. Bei meinem Gen24 kann ich die Zähler auch per Plugin abrufen und zusätzlich die Ladeleistung per Modbus begrenzen. Eben weil das über das Plugin (noch) nicht geht.
                Beim Symo Hybrid, an einem anderen Standort, geht das aber irgendwie nicht mehr über Modbus.
                • SPS-Guru
                  Beim Symo Hybrid das Plugin rausschmeissen und schauen ob es dann wieder geht ?
                • Tico
                  Tico kommentierte
                  Ich benutze die Symo Hybrid-Firmware 1.31.1-5. Es gibt eine höhere Version, auf die ich noch nicht aktualisiert habe (1.32.1-2).
                  Alles funktioniert normal mit Zwangsladung und Entladung.
                  Wenn StorCtl auf 3 eingestellt ist, müssen Sie immer noch sowohl Charge Limit als auch Discharge Limit einstellen.
                • Triple-M
                  Triple-M kommentierte
                  Ja ich habe die 1.32.1-2 installiert, vielleicht liegt es daran.
              • HBeumer
                • 24.02.2017
                • 47
                #89
                I know that this topic is about the Fronius Symo Hybrid, my question is about the non-hybrid version of this inverter (Fronius Symo 7.0-3-M), hopefully somebody can help me. I currently have the ability to put the inverter on standby by writing 0 to register 40241. Now I want to be able to throttle the inverter, instead of fully stopping it.
                I wonder which register I need to write for this (I only have a document for the hybrid version, no clue what the correct register is to throttle).
                • SPS-Guru
                  • 27.12.2022
                  • 141
                  #90
                  I don't have any Symo register tables.
                  For SymoHybrid inverters, these are the registers:
Ansichten: 67
Größe: 3,6 KB
