  • Zoltan
    • 28.09.2020
    • 20
    #916
    Nach einiger Zeit passiert mir ein Tipp.Eine andere Sache ist, dass es mir nicht die aktuelle Temperatur von FOSHKplugin anzeigt, sondern die Vorhersage in Loxone
    Gruss Zoltan
      • 5317
      #917
      Maybe this is a bug with OpenWeatherMap. Have to look into this.
      Regarding FOSHKPlugin: have you activated it in the Config? Please attach the Logfile of the FOSHK fetch command here.
      • Zoltan
        Zoltan kommentierte
        Until now, it worked
    • Zoltan
      • 28.09.2020
      • 20
      #918
      Latest data from the plugin kl 04:21
      Now I found that after the update stopped reading data
      Plugin version Version 4.10.0.1
      Zuletzt geändert von Zoltan; 04.12.2022, 19:39.
      • Zoltan
        • 28.09.2020
        • 20
        #919
        Hello again
        After reinstalling to V4.9.0.4, everything works again
        • daant3
          • 21.02.2022
          • 6
          #920
          funktioniert perfekt! Danke
            • 5317
            #921
            Zoltan Try latest master - unfortunately I cannot test because I have no subscription to OneCall 3.0 API.
            https://github.com/mschlenstedt/LoxB...ads/master.zip
            Save your settings after installation one time in Weather4Lox (no changes needed, just save). After that it should work again. Please note that you need a subscription to the OneCall Api 3.0! This subscription includes 1000 Calls per day for free, but you have to give them your credit card data.
            If you do not want that, change to Visual Crossing Weather service.
            • CheeseR
              • 11.03.2021
              • 1
              #922
              Hello,
              Since the latest version the OpenWeatherMap integration is broken, even when onecall API is activated.
              The plugin is trying to fetch the wrong URL:
              "https://api.openweathermap.org/data/2.5/3.0/onecall?appid=6e31009ebef4640bb6e582ae70cb8ecb&lat =46.279265&lon=20.119375&lang=en&units=metric"
              Status: 404 Not Found
              /2.5/ should be removed.​
              Regards
                Yes, see one posting above yours.
            • mastercheef
              • 09.03.2021
              • 20
              #923
              Seit dem neuesten Miniserver Update oder Config Update 13.1.11.17 kommen keine Wetterdaten mehr an?! Wie geht's euch diesbezüglich?
              • jroesch
                • 11.05.2021
                • 19
                #924
                Hallo!
                Ich habe gestern Abend umgestellt auf Visual Crossing. Hat sofort mit der API funktioniert, aber irgendwas stimmt mit der Uhrzeit nicht. Das Wetter geht eine Stunde vor. Heute morgen sollte um 8:28 Uhr als ich nachgeschaut habe, doch 8:00 Uhr oben in der Mitte stehen. Dementsprechend ist um 23 Uhr schon der nächste Tag. Weiß nicht wo mein Fehler ist. Ich habe es jetzt auf Weatherbit umgestellt und dort wird die Uhrzeit korrekt angezeigt. Möchte aber lieber Visual Crossing....
Ansichten: 1042
Größe: 205,1 KB
                  • 5317
                  #925
                  Vermutlich ein Problem mit der Timezone. Das muss ich mir anschauen.
                  • jroesch
                    • 11.05.2021
                    • 19
                    #926
                    Ich habe vorhin in einer Facebook Gruppe gelesen, dass das Problem noch jemand hat. Dachte schon, ich hab irgendwo etwas versaubeutelt.
                    • mastercheef
                      • 09.03.2021
                      • 20
                      #927
                      Mall Loxberry und Miniserver neu gestartet jetzt kommen zwar wieder Werte an aber alles wird mit einem falschen Datum abgefragt. Am Loxberry stimmt die TimeZone am Miniserver auch...!
                        Ja, hab ich doch schon geschrieben....
                      • 5317
                      #928
                      Zur falschen Zeit / Timezone:
                      Ich kann das bei mir nicht nachstellen. Ich brauche das Logfile "Grabber_visualcrossing" im Debugmodus und direkt nach dem Abholen der Daten einen Screenshot aus der Vorschau aus der WebUI des Plugins (Achtung! Vorschau Button verwenden, damit ich eine Live-View bekomme):
                      http://loxberry/admin/plugins/weather4lox/show.cgi?theme=dark&lang=de&iconset=color
                      Ich habe gerade die Wetterdaten abgeholt:
                      OK: Data fetched successfully for 51.07,13.72
                      INFO: Saving new Data for Timestamp Sat Dec 10 08:00:46 2022 to database.
                      OK: Saving current data to /opt/loxberry/log/plugins/weather4lox/current.dat.tmp successfully.
                      Database content:
                      1670655646|Sat, 10 Dec 2022 08:00:46 +0100|CET|Europe/Berlin|+0100|Dresden|Deutschland|-9999|51.07|13.72|-9999|0.4|-3.2|86.8|Nord-Osten|50|11.1|0|-3.2|1006|-1.6|5.0|0.0|-9999|0.00|-9999|0|snow|21|Overcast|94|-9999|53|-9999|07|57|15|58|-9999|100|0|0.10|
                      OK: Saving daily forecast data to /opt/loxberry/log/plugins/weather4lox/dailyforecast.dat.tmp successfully.​
                      Man sieht, dass die Wetterdaten vom Sat, 10 Dec 2022 08:00:46 +0100 mit der Zeitzone CET / Europe/Berlin geholt wurden. Und dazu passt auch die Visualisierung:
                      Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 50,5 KB ID: 370522
                      • jroesch
                        jroesch kommentierte
                        Guten Morgen. Bei mir sieht es genauso aus, wenn ich auf Vorschau klicke und mir die Daten im Browser anschaue. Aber in der App sieht es anders aus.
                      • 5317
                      #929
                      jroesch Aha. In der App meinst Du die Darstellung vom Weather Emulator? Dann brauche ich das Grabber-Logfile im Debugmodus wie geschrieben und dazu den Auszug, wenn Du auf "Teste Emulator" klickst.
                      Da sieht das aktuell bei mir so aus - man sieht auch hier, dass die erste Zeile die Daten von 8 Uhr enthält.
                      <mb_metadata>
                      id;name;longitude;latitude;height (m.asl.);country;timezone;utc-timedifference;sunrise;sunset;local date;weekday;local time;temperature(C);feeledTemperature(C);windspeed (km/h);winddirection(degr);wind gust(km/h);low clouds(%);medium clouds(%);high clouds(%);precipitation(mm);probability of Precip(%);snowFraction;sea level pressure(hPa);relative humidity(%);CAPE;picto-code;radiation (W/m2);
                      </mb_metadata><valid_until>2030-12-31</valid_until>
                      <station>
                      ;Dresden;13.72;51.07;-9999;Deutschland;CET;UTC+01.00;07:57;15:58;
                      10.12.2022;Sat;08; 0.6; 0.6; 0;311; 0; 0; 0; 0; 0.0; 0;0.0; 994; 94; 0;24; 4;
                      10.12.2022;Sat;09; 0.1; 0.1; 4; 22; 4; 99; 99; 99; 0.0; 66;0.0;1009; 95; 0;23; 19;​
                      • jroesch
                        • 11.05.2021
                        • 19
                        #930
                        Ich hoffe, ich liefere die richten Daten.
                        cur_date@439893605
                        cur_day@10
                        cur_month@12
                        cur_year@2022
                        cur_hour@8
                        cur_min@40
                        cur_loc_lat@50.337844
                        cur_loc_long@10.138888
                        cur_loc_el@-9999
                        cur_tt@-0.1
                        cur_tt_fl@-0.1
                        cur_hu@96.0
                        cur_w_dir@339.0
                        cur_w_sp@0.0
                        cur_w_gu@0.0
                        cur_w_ch@-0.1
                        cur_pr@1057.8
                        cur_dp@0.0
                        cur_vis@0.0
                        cur_sr@25.1
                        cur_hi@-9999
                        cur_uvi@0
                        cur_prec_today@0
                        cur_prec_1hr@0
                        cur_we_code@3
                        cur_moon_p@94
                        cur_moon_a@-9999
                        cur_sun_r@439891680
                        cur_sun_s@439920900
                        cur_ozone@-9999
                        cur_sky@71.2
                        cur_pop@0
                        cur_snow@0.00
                        dfc0_per@0
                        dfc0_date@439858800
                        dfc0_day@10
                        dfc0_month@12
                        dfc0_year@2022
                        dfc0_hour@00
                        dfc0_min@00
                        dfc0_tt_h@0.8
                        dfc0_tt_l@-2.5
                        dfc0_pop@100.0
                        dfc0_prec@0.10
                        dfc0_snow@0.10
                        dfc0_w_sp_h@18.40
                        dfc0_w_dir_h@-9999
                        dfc0_w_sp_a@8.3
                        dfc0_w_dir_a@13.4
                        dfc0_hu_a@86.9
                        dfc0_hu_h@-9999
                        dfc0_hu_l@-9999
                        dfc0_we_code@19
                        dfc0_ozone@-9999
                        dfc0_moon_p@53
                        dfc0_dp@-2.6
                        dfc0_pr@1009.1
                        dfc0_uvi@2.0
                        dfc0_sun_r@439891680
                        dfc0_sun_s@439920900
                        dfc0_vis@20.8
                        dfc1_per@1
                        dfc1_date@439945200
                        dfc1_day@11
                        dfc1_month@12
                        dfc1_year@2022
                        dfc1_hour@00
                        dfc1_min@00
                        dfc1_tt_h@-0.6
                        dfc1_tt_l@-3.5
                        dfc1_pop@33.3
                        dfc1_prec@0.20
                        dfc1_snow@0.40
                        dfc1_w_sp_h@18.70
                        dfc1_w_dir_h@-9999
                        dfc1_w_sp_a@7.6
                        dfc1_w_dir_a@259.8
                        dfc1_hu_a@84.1
                        dfc1_hu_h@-9999
                        dfc1_hu_l@-9999
                        dfc1_we_code@21
                        dfc1_ozone@-9999
                        dfc1_moon_p@55
                        dfc1_dp@-4.6
                        dfc1_pr@1010.8
                        dfc1_uvi@3.0
                        dfc1_sun_r@439891740
                        dfc1_sun_s@439920900
                        dfc1_vis@18.6
                        dfc2_per@2
                        dfc2_date@440031600
                        dfc2_day@12
                        dfc2_month@12
                        dfc2_year@2022
                        dfc2_hour@00
                        dfc2_min@00
                        dfc2_tt_h@-1.7
                        dfc2_tt_l@-5.8
                        dfc2_pop@33.3
                        dfc2_prec@0.10
                        dfc2_snow@0.00
                        dfc2_w_sp_h@12.60
                        dfc2_w_dir_h@-9999
                        dfc2_w_sp_a@5.8
                        dfc2_w_dir_a@258.3
                        dfc2_hu_a@84.4
                        dfc2_hu_h@-9999
                        dfc2_hu_l@-9999
                        dfc2_we_code@3
                        dfc2_ozone@-9999
                        dfc2_moon_p@59
                        dfc2_dp@-5.9
                        dfc2_pr@1014.0
                        dfc2_uvi@3.0
                        dfc2_sun_r@439891800
                        dfc2_sun_s@439920900
                        dfc2_vis@19.5
                        dfc3_per@3
                        dfc3_date@440118000
                        dfc3_day@13
                        dfc3_month@12
                        dfc3_year@2022
                        dfc3_hour@00
                        dfc3_min@00
                        dfc3_tt_h@-3.5
                        dfc3_tt_l@-7.7
                        dfc3_pop@9.5
                        dfc3_prec@0.00
                        dfc3_snow@0.00
                        dfc3_w_sp_h@16.60
                        dfc3_w_dir_h@-9999
                        dfc3_w_sp_a@7.3
                        dfc3_w_dir_a@46.8
                        dfc3_hu_a@86.5
                        dfc3_hu_h@-9999
                        dfc3_hu_l@-9999
                        dfc3_we_code@3
                        dfc3_ozone@-9999
                        dfc3_moon_p@62
                        dfc3_dp@-7.3
                        dfc3_pr@1013.1
                        dfc3_uvi@3.0
                        dfc3_sun_r@439891860
                        dfc3_sun_s@439920900
                        dfc3_vis@24.1
                        dfc4_per@4
                        dfc4_date@440204400
                        dfc4_day@14
                        dfc4_month@12
                        dfc4_year@2022
                        dfc4_hour@00
                        dfc4_min@00
                        dfc4_tt_h@-1.5
                        dfc4_tt_l@-4.3
                        dfc4_pop@33.3
                        dfc4_prec@24.20
                        dfc4_snow@16.00
                        dfc4_w_sp_h@39.20
                        dfc4_w_dir_h@-9999
                        dfc4_w_sp_a@18.0
                        dfc4_w_dir_a@58.9
                        dfc4_hu_a@88.5
                        dfc4_hu_h@-9999
                        dfc4_hu_l@-9999
                        dfc4_we_code@21
                        dfc4_ozone@-9999
                        dfc4_moon_p@67
                        dfc4_dp@-5.2
                        dfc4_pr@999.0
                        dfc4_uvi@1.0
                        dfc4_sun_r@439891920
                        dfc4_sun_s@439920900
                        dfc4_vis@10.3
                        dfc5_per@5
                        dfc5_date@440290800
                        dfc5_day@15
                        dfc5_month@12
                        dfc5_year@2022
                        dfc5_hour@00
                        dfc5_min@00
                        dfc5_tt_h@-1.7
                        dfc5_tt_l@-11.7
                        dfc5_pop@42.9
                        dfc5_prec@0.50
                        dfc5_snow@0.50
                        dfc5_w_sp_h@31.00
                        dfc5_w_dir_h@-9999
                        dfc5_w_sp_a@14.8
                        dfc5_w_dir_a@347.1
                        dfc5_hu_a@87.4
                        dfc5_hu_h@-9999
                        dfc5_hu_l@-9999
                        dfc5_we_code@19
                        dfc5_ozone@-9999
                        dfc5_moon_p@71
                        dfc5_dp@-9.0
                        dfc5_pr@1012.6
                        dfc5_uvi@2.0
                        dfc5_sun_r@439891920
                        dfc5_sun_s@439920960
                        dfc5_vis@19.9
                        hfc1_per@1
                        hfc1_date@439894800
                        hfc1_day@10
                        hfc1_month@12
                        hfc1_year@2022
                        hfc1_hour@10
                        hfc1_min@00
                        hfc1_tt@-0.7
                        hfc1_tt_fl@-0.7
                        hfc1_hi@-9999
                        hfc1_hu@86.96
                        hfc1_w_dir@7.8
                        hfc1_w_sp@3.6
                        hfc1_w_ch@-0.7
                        hfc1_pr@1009.0
                        hfc1_dp@-2.6
                        hfc1_sky@74
                        hfc1_uvi@1.0
                        hfc1_prec@0.00
                        hfc1_snow@0.00
                        hfc1_pop@0.0
                        hfc1_we_code@3
                        hfc1_ozone@-9999
                        hfc1_sr@79.0
                        hfc1_vis@24.1
                        hfc2_per@2
                        hfc2_date@439898400
                        hfc2_day@10
                        hfc2_month@12
                        hfc2_year@2022
                        hfc2_hour@11
                        hfc2_min@00
                        hfc2_tt@0.1
                        hfc2_tt_fl@-1.7
                        hfc2_hi@-9999
                        hfc2_hu@84.51
                        hfc2_w_dir@12.9
                        hfc2_w_sp@5.4
                        hfc2_w_ch@-1.7
                        hfc2_pr@1009.0
                        hfc2_dp@-2.2
                        hfc2_sky@85
                        hfc2_uvi@1.0
                        hfc2_prec@0.00
                        hfc2_snow@0.00
                        hfc2_pop@0.0
                        hfc2_we_code@3
                        hfc2_ozone@-9999
                        hfc2_sr@134.0
                        hfc2_vis@21.1
                        hfc3_per@3
                        hfc3_date@439902000
                        hfc3_day@10
                        hfc3_month@12
                        hfc3_year@2022
                        hfc3_hour@12
                        hfc3_min@00
                        hfc3_tt@0.5
                        hfc3_tt_fl@-1.9
                        hfc3_hi@-9999
                        hfc3_hu@82.71
                        hfc3_w_dir@25.6
                        hfc3_w_sp@7.2
                        hfc3_w_ch@-1.9
                        hfc3_pr@1009.0
                        hfc3_dp@-2.1
                        hfc3_sky@89
                        hfc3_uvi@2.0
                        hfc3_prec@0.00
                        hfc3_snow@0.00
                        hfc3_pop@0.0
                        hfc3_we_code@3
                        hfc3_ozone@-9999
                        hfc3_sr@161.0
                        hfc3_vis@9.6
                        calc+4_ttmax@0.8
                        calc+8_ttmax@0.8
                        calc+16_ttmax@0.8
                        calc+24_ttmax@0.8
                        calc+32_ttmax@0.8
                        calc+40_ttmax@0.8
                        calc+48_ttmax@0.8
                        calc+4_ttmin@-0.7
                        calc+8_ttmin@-0.7
                        calc+16_ttmin@-3.2
                        calc+24_ttmin@-3.5
                        calc+32_ttmin@-3.5
                        calc+40_ttmin@-3.5
                        calc+48_ttmin@-5.3
                        calc+4_popmax@0.0
                        calc+8_popmax@4.8
                        calc+16_popmax@28.6
                        calc+24_popmax@28.6
                        calc+32_popmax@28.6
                        calc+40_popmax@33.3
                        calc+48_popmax@33.3
                        calc+4_popmin@0.0
                        calc+8_popmin@0.0
                        calc+16_popmin@0.0
                        calc+24_popmin@0.0
                        calc+32_popmin@0.0
                        calc+40_popmin@0.0
                        calc+48_popmin@0.0
                        calc+4_prec@0
                        calc+8_prec@0
                        calc+16_prec@0
                        calc+24_prec@0
                        calc+32_prec@0.1
                        calc+40_prec@0.3
                        calc+48_prec@0.3
                        calc+4_snow@0
                        calc+8_snow@0.1
                        calc+16_snow@0.1
                        calc+24_snow@0.1
                        calc+32_snow@0.1
                        calc+40_snow@0.5
                        calc+48_snow@0.5​
                        <mb_metadata> id;name;longitude;latitude;height (m.asl.);country;timezone;utc-timedifference;sunrise;sunset;local date;weekday;local time;temperature(C);feeledTemperature(C);windspeed(km/h);winddirection(degr);wind gust(km/h);low clouds(%);medium clouds(%);high clouds(%);precipitation(mm);probability of Precip(%);snowFraction;sea level pressure(hPa);relative humidity(%);CAPE;picto-code;radiation (W/m2);
                          <station>
                          ;Windshausen;10.138888;50.337844;-9999;Deutschland;CET;UTC+01.00;08:08;16:15;
                          10.12.2022;Sat;08; -0.1; -0.1; 0;339; 0; 0; 0; 0; 0.0; 0;0.0;1057; 96; 0; 8; 25;
                          10.12.2022;Sat;10; -0.7; -0.7; 3; 7; 3; 74; 74; 74; 0.0; 0;0.0;1009; 86; 0; 8; 79;
                          10.12.2022;Sat;11; 0.1; -1.7; 5; 12; 5; 85; 85; 85; 0.0; 0;0.0;1009; 84; 0; 8; 134;
                          10.12.2022;Sat;12; 0.5; -1.9; 7; 25; 7; 89; 89; 89; 0.0; 0;0.0;1009; 82; 0; 8; 161;
                          10.12.2022;Sat;13; 0.8; -1.9; 8; 29; 8; 92; 92; 92; 0.0; 0;0.0;1009; 79; 0;22; 141;
                          10.12.2022;Sat;14; 0.7; -2.0; 8; 29; 8; 90; 90; 90; 0.0; 4;0.0;1009; 79; 0; 8; 108;
                          10.12.2022;Sat;15; 0.4; -1.8; 6; 34; 6; 83; 83; 83; 0.0; 4;0.0;1009; 84; 0; 8; 76;
                          10.12.2022;Sat;16; 0.0; 0.0; 4; 28; 4; 84; 84; 84; 0.0; 4;0.0;1010; 86; 0;33; 32;
                          10.12.2022;Sat;17; -0.5; -0.5; 3;355; 3; 91; 91; 91; 0.0; 4;0.0;1010; 88; 0;22; 0;
                          10.12.2022;Sat;18; -0.8; -0.8; 3;354; 3; 93; 93; 93; 0.0; 4;0.0;1011; 87; 0;22; 0;
                          10.12.2022;Sat;19; -1.0; -1.0; 3;356; 3; 94; 94; 94; 0.0; 4;0.0;1011; 86; 0;22; 0;
                          10.12.2022;Sat;20; -1.2; -1.2; 2; 10; 2; 53; 53; 53; 0.0; 28;0.0;1011; 84; 0; 8; 0;
                          10.12.2022;Sat;21; -1.6; -1.6; 2;355; 2; 70; 70; 70; 0.0; 28;0.0;1011; 84; 0; 8; 0;
                          10.12.2022;Sat;22; -2.0; -2.0; 2;323; 2; 81; 81; 81; 0.0; 28;0.0;1011; 85; 0; 8; 0;
                          10.12.2022;Sat;23; -2.5; -2.5; 2;301; 2; 89; 89; 89; 0.0; 28;0.0;1011; 86; 0; 8; 0;
                          11.12.2022;Sun;00; -2.9; -2.9; 2;289; 2; 88; 88; 88; 0.0; 28;0.0;1011; 88; 0; 8; 0;
                          11.12.2022;Sun;01; -3.2; -3.2; 2;267; 2; 57; 57; 57; 0.0; 28;0.0;1011; 88; 0; 8; 0;
                          11.12.2022;Sun;02; -3.3; -3.3; 2;243; 2; 74; 74; 74; 0.0; 4;0.0;1011; 88; 0; 8; 0;
                          11.12.2022;Sun;03; -3.5; -3.5; 2;218; 2; 88; 88; 88; 0.0; 4;0.0;1011; 90; 0; 8; 0;
                          11.12.2022;Sun;04; -3.3; -3.3; 3;223; 3; 95; 95; 95; 0.0; 4;0.0;1011; 90; 0;22; 0;
                          11.12.2022;Sun;05; -2.9; -2.9; 3;233; 3; 90; 90; 90; 0.0; 4;0.0;1011; 90; 0; 8; 0;
                          11.12.2022;Sun;06; -2.7; -2.7; 3;241; 3; 90; 90; 90; 0.0; 4;0.0;1011; 84; 0; 8; 0;
                          11.12.2022;Sun;07; -2.9; -2.9; 3;234; 3; 91; 91; 91; 0.0; 4;0.0;1011; 82; 0;22; 0;
                          11.12.2022;Sun;08; -3.1; -3.1; 3;240; 3; 93; 93; 93; 0.0; 4;0.0;1011; 84; 0;22; 0;
                          11.12.2022;Sun;09; -3.0; -3.0; 2;250; 2; 82; 82; 82; 0.0; 4;0.0;1011; 84; 0; 8; 17;
                          11.12.2022;Sun;10; -2.4; -2.4; 2;229; 2; 92; 92; 92; 0.0; 4;0.0;1012; 84; 0;22; 105;
                          11.12.2022;Sun;11; -1.8; -3.7; 5;251; 5; 86; 86; 86; 0.0; 4;0.0;1011; 79; 0; 8; 198;
                          11.12.2022;Sun;12; -1.0; -2.8; 5;269; 5; 91; 91; 91; 0.0; 4;0.0;1011; 73; 0;22; 253;
                          11.12.2022;Sun;13; -0.6; -3.3; 7;292; 7;100;100;100; 0.0; 4;0.0;1010; 67; 0;22; 252;
                          11.12.2022;Sun;14; -0.9; -3.7; 7;284; 7;100;100;100; 0.0; 19;0.0;1010; 75; 0;22; 173;
                          11.12.2022;Sun;15; -1.1; -3.5; 6;288; 6; 98; 98; 98; 0.1; 19;0.0;1010; 80; 0;22; 105;
                          11.12.2022;Sun;16; -1.3; -3.1; 5;268; 5; 92; 92; 92; 0.0; 19;0.0;1010; 83; 0;22; 35;
                          11.12.2022;Sun;17; -1.7; -1.7; 4;254; 4; 97; 97; 97; 0.0; 19;0.0;1010; 86; 0;22; 0;
                          11.12.2022;Sun;18; -1.9; -1.9; 4;257; 4; 95; 95; 95; 0.0; 19;0.0;1010; 86; 0;24; 0;
                          11.12.2022;Sun;19; -2.0; -2.0; 4;268; 4; 99; 99; 99; 0.0; 19;0.0;1010; 85; 0;24; 0;
                          11.12.2022;Sun;20; -2.4; -4.5; 5;261; 5;100;100;100; 0.0; 33;0.0;1011; 85; 0;24; 0;
                          11.12.2022;Sun;21; -2.4; -4.4; 5;253; 5; 99; 99; 99; 0.0; 33;0.0;1011; 85; 0;24; 0;
                          11.12.2022;Sun;22; -2.4; -2.4; 4;249; 4;100;100;100; 0.1; 33;0.0;1011; 86; 0;22; 0;
                          11.12.2022;Sun;23; -2.3; -2.3; 4;252; 4;100;100;100; 0.0; 33;0.0;1011; 86; 0;22; 0;
                          12.12.2022;Mon;00; -2.4; -2.4; 4;272; 4;100;100;100; 0.0; 33;0.0;1011; 87; 0;22; 0;
                          12.12.2022;Mon;01; -2.4; -4.4; 5;307; 5; 85; 85; 85; 0.1; 33;0.0;1011; 81; 0; 8; 0;
                          12.12.2022;Mon;02; -2.6; -4.9; 5;323; 5; 84; 84; 84; 0.0; 4;0.0;1011; 76; 0; 8; 0;
                          12.12.2022;Mon;03; -2.9; -4.9; 5;332; 5; 88; 88; 88; 0.0; 4;0.0;1012; 77; 0; 8; 0;
                          12.12.2022;Mon;04; -3.5; -3.5; 3;330; 3; 48; 48; 48; 0.0; 4;0.0;1012; 79; 0; 8; 0;
                          12.12.2022;Mon;05; -3.9; -3.9; 1;306; 1; 0; 0; 0; 0.0; 4;0.0;1012; 80; 0; 1; 0;
                          12.12.2022;Mon;06; -4.3; -4.3; 2;303; 2; 2; 2; 2; 0.0; 4;0.0;1013; 81; 0; 1; 0;
                          12.12.2022;Mon;07; -4.8; -4.8; 2;267; 2; 58; 58; 58; 0.0; 4;0.0;1013; 84; 0; 8; 0;
                          12.12.2022;Mon;08; -5.2; -5.2; 2;242; 2; 96; 96; 96; 0.0; 0;0.0;1013; 87; 0;22; 0;
                          12.12.2022;Mon;09; -5.3; -5.3; 2;233; 2; 96; 96; 96; 0.0; 0;0.0;1014; 88; 0;22; 15;
                          12.12.2022;Mon;10; -4.6; -4.6; 1;210; 1; 69; 69; 69; 0.0; 0;0.0;1015; 87; 0; 8; 101;
                          12.12.2022;Mon;11; -3.5; -3.5; 2;200; 2; 62; 62; 62; 0.0; 0;0.0;1015; 82; 0; 8; 193;
                          12.12.2022;Mon;12; -2.7; -2.7; 3;224; 3; 64; 64; 64; 0.0; 0;0.0;1015; 79; 0; 8; 247;
                          12.12.2022;Mon;13; -2.1; -2.1; 3;207; 3; 63; 63; 63; 0.0; 0;0.0;1015; 78; 0; 8; 258;
                          12.12.2022;Mon;14; -1.8; -1.8; 3;200; 3; 60; 60; 60; 0.0; 4;0.0;1014; 78; 0; 8; 224;
                          12.12.2022;Mon;15; -1.7; -1.7; 4;211; 4; 60; 60; 60; 0.0; 4;0.0;1015; 79; 0; 8; 147;
                          12.12.2022;Mon;16; -2.2; -2.2; 3;199; 3; 0; 0; 0; 0.0; 4;0.0;1015; 84; 0; 1; 49;
                          12.12.2022;Mon;17; -3.0; -3.0; 3;184; 3; 6; 6; 6; 0.0; 4;0.0;1015; 86; 0; 1; 1;
                          12.12.2022;Mon;18; -3.5; -3.5; 2;204; 2; 0; 0; 0; 0.0; 4;0.0;1016; 88; 0; 1; 0;
                          12.12.2022;Mon;19; -3.9; -3.9; 2;223; 2; 0; 0; 0; 0.0; 4;0.0;1016; 89; 0; 1; 0;
                          12.12.2022;Mon;20; -4.3; -4.3; 1;249; 1; 0; 0; 0; 0.0; 0;0.0;1016; 89; 0; 1; 0;
                          12.12.2022;Mon;21; -4.8; -4.8; 1;272; 1; 0; 0; 0; 0.0; 0;0.0;1016; 91; 0; 1; 0;
                          12.12.2022;Mon;22; -5.3; -5.3; 1;357; 1; 0; 0; 0; 0.0; 0;0.0;1016; 91; 0; 1; 0;
                          12.12.2022;Mon;23; -5.8; -5.8; 2;348; 2; 0; 0; 0; 0.0; 0;0.0;1016; 92; 0; 1; 0;
                          13.12.2022;Tue;00; -6.0; -6.0; 1;338; 1; 0; 0; 0; 0.0; 0;0.0;1016; 90; 0; 1; 0;
                          13.12.2022;Tue;01; -6.2; -6.2; 2; 2; 2; 0; 0; 0; 0.0; 0;0.0;1016; 89; 0; 1; 0;
                          13.12.2022;Tue;02; -6.5; -6.5; 2; 2; 2; 1; 1; 1; 0.0; 0;0.0;1016; 89; 0; 1; 0;
                          13.12.2022;Tue;03; -6.8; -6.8; 2; 2; 2; 1; 1; 1; 0.0; 0;0.0;1016; 89; 0; 1; 0;
                          13.12.2022;Tue;04; -7.0; -7.0; 2; 1; 2; 2; 2; 2; 0.0; 0;0.0;1016; 89; 0; 1; 0;
                          13.12.2022;Tue;05; -7.3; -7.3; 2; 17; 2; 14; 14; 14; 0.0; 0;0.0;1015; 90; 0; 1; 0;
                          13.12.2022;Tue;06; -7.5; -7.5; 2; 34; 2; 27; 27; 27; 0.0; 0;0.0;1015; 92; 0; 8; 0;
                          13.12.2022;Tue;07; -7.7; -7.7; 2; 50; 2; 40; 40; 40; 0.0; 0;0.0;1015; 93; 0; 8; 0;
                          13.12.2022;Tue;08; -7.3; -7.3; 3; 51; 3; 60; 60; 60; 0.0; 0;0.0;1015; 93; 0; 8; 0;
                          13.12.2022;Tue;09; -6.9; -6.9; 3; 51; 3; 80; 80; 80; 0.0; 0;0.0;1015; 93; 0; 8; 16;
                          13.12.2022;Tue;10; -6.4; -6.4; 4; 52; 4;100;100;100; 0.0; 0;0.0;1015; 93; 0;22; 106;
                          13.12.2022;Tue;11; -5.7; -5.7; 4; 56; 4; 97; 97; 97; 0.0; 0;0.0;1014; 89; 0;22; 196;
                          13.12.2022;Tue;12; -5.0; -7.6; 5; 61; 5; 95; 95; 95; 0.0; 0;0.0;1013; 86; 0;22; 251;
                          13.12.2022;Tue;13; -4.2; -7.1; 6; 65; 6; 92; 92; 92; 0.0; 0;0.0;1013; 83; 0;22; 262;
                          13.12.2022;Tue;14; -4.0; -6.8; 6; 58; 6; 95; 95; 95; 0.0; 0;0.0;1012; 82; 0;22; 226;
                          13.12.2022;Tue;15; -3.8; -6.6; 6; 51; 6; 97; 97; 97; 0.0; 0;0.0;1011; 82; 0;22; 150;
                          13.12.2022;Tue;16; -3.5; -6.3; 6; 44; 6;100;100;100; 0.0; 0;0.0;1011; 82; 0;22; 49;
                          13.12.2022;Tue;17; -3.7; -6.3; 6; 47; 6;100;100;100; 0.0; 0;0.0;1010; 82; 0;22; 1;
                          13.12.2022;Tue;18; -3.9; -6.2; 5; 50; 5;100;100;100; 0.0; 0;0.0;1010; 82; 0;22; 0;
                          13.12.2022;Tue;19; -4.0; -6.2; 5; 54; 5;100;100;100; 0.0; 0;0.0;1010; 82; 0;22; 0;
                          13.12.2022;Tue;20; -4.1; -6.6; 5; 52; 5;100;100;100; 0.0; 9;0.0;1009; 80; 0;22; 0;
                          13.12.2022;Tue;21; -4.2; -6.9; 6; 51; 6;100;100;100; 0.0; 9;0.0;1009; 79; 0;22; 0;
                          13.12.2022;Tue;22; -4.2; -7.3; 6; 50; 6;100;100;100; 0.0; 9;0.0;1009; 78; 0;22; 0;
                          13.12.2022;Tue;23; -4.2; -7.4; 7; 52; 7;100;100;100; 0.0; 9;0.0;1008; 77; 0;22; 0;
                          14.12.2022;Wed;00; -4.2; -7.6; 7; 54; 7;100;100;100; 0.0; 9;0.0;1007; 76; 0;22; 0;
                          14.12.2022;Wed;01; -4.1; -7.7; 8; 57; 8;100;100;100; 0.0; 9;0.0;1006; 74; 0;22; 0;
                          14.12.2022;Wed;02; -4.0; -7.6; 8; 60; 8;100;100;100; 0.0; 4;0.0;1004; 74; 0;22; 0;
                          14.12.2022;Wed;03; -3.9; -7.5; 8; 64; 8;100;100;100; 0.0; 4;0.0;1003; 73; 0;22; 0;
                          14.12.2022;Wed;04; -3.8; -7.5; 8; 68; 8;100;100;100; 0.0; 4;0.0;1002; 73; 0;22; 0;
                          14.12.2022;Wed;05; -4.0; -8.0; 9; 67; 9;100;100;100; 0.0; 4;0.0;1001; 79; 0;22; 0;
                          14.12.2022;Wed;06; -4.2; -8.5; 10; 65; 10;100;100;100; 0.0; 4;0.0;1000; 85; 0;22; 0;
                          14.12.2022;Wed;07; -4.3; -9.0; 11; 64; 11;100;100;100; 2.7; 4;0.0; 999; 92; 0;24; 0;
                          14.12.2022;Wed;08; -4.1; -8.4; 10; 63; 10;100;100;100; 0.0; 9;0.0; 998; 92; 0;22; 0;
                          14.12.2022;Wed;09; -3.9; -7.8; 9; 62; 9;100;100;100; 0.0; 9;0.0; 997; 92; 0;22; 6;
                          14.12.2022;Wed;10; -3.7; -7.1; 7; 60; 7;100;100;100; 4.5; 9;0.0; 996; 92; 0;24; 31;
                          14.12.2022;Wed;11; -3.3; -6.5; 7; 69; 7;100;100;100; 0.0; 9;0.0; 994; 91; 0;22; 50;
                          14.12.2022;Wed;12; -2.8; -5.9; 7; 78; 7;100;100;100; 0.0; 9;0.0; 993; 90; 0;24; 58;
                          14.12.2022;Wed;13; -2.3; -5.3; 7; 86; 7;100;100;100; 7.6; 9;0.0; 992; 90; 0;24; 51;
                          14.12.2022;Wed;14; -2.1; -4.3; 5; 73; 5;100;100;100; 0.0; 23;0.0; 991; 91; 0;24; 49;
                          14.12.2022;Wed;15; -1.8; -1.8; 4; 60; 4;100;100;100; 0.0; 23;0.0; 991; 92; 0;24; 34;
                          14.12.2022;Wed;16; -1.5; -1.5; 2; 46; 2;100;100;100; 3.7; 23;0.0; 991; 94; 0;24; 14;
                          14.12.2022;Wed;17; -3.6; -9.5; 18; 78; 18;100;100;100; 0.9; 23;0.0;1002; 94; 0;24; 0;
                          14.12.2022;Wed;18; -3.6; -9.3; 16; 69; 16;100;100;100; 1.0; 23;0.0;1001; 95; 0;24; 0;
                          14.12.2022;Wed;19; -3.6; -9.2; 16; 61; 16;100;100;100; 1.0; 23;0.0;1001; 94; 0;24; 0;
                          14.12.2022;Wed;20; -3.7; -9.3; 16; 48; 16;100;100;100; 1.0; 33;0.0;1001; 95; 0;24; 0;
                          14.12.2022;Wed;21; -3.8; -9.3; 15; 38; 15;100;100;100; 0.8; 33;0.0;1001; 95; 0;24; 0;
                          14.12.2022;Wed;22; -3.9; -9.4; 15; 29; 15;100;100;100; 0.5; 33;0.0;1001; 94; 0;24; 0;
                          14.12.2022;Wed;23; -4.1; -9.6; 15; 21; 15;100;100;100; 0.5; 33;0.0;1002; 94; 0;24; 0;
                          15.12.2022;Thu;00; -4.1; -9.5; 14; 11; 14;100;100;100; 0.3; 33;0.0;1003; 94; 0;24; 0;
                          15.12.2022;Thu;01; -4.1; -9.3; 14; 3; 14; 74; 74; 74; 0.2; 33;0.0;1003; 92; 0;33; 0;
                          15.12.2022;Thu;02; -5.4;-10.5; 12;117; 12; 51; 51; 51; 0.0; 33;0.0;1004; 91; 0; 8; 0;
                          15.12.2022;Thu;03; -6.7;-11.6; 10;232; 10; 29; 29; 29; 0.0; 33;0.0;1005; 90; 0; 8; 0;
                          15.12.2022;Thu;04; -8.0;-12.7; 9;346; 9; 6; 6; 6; 0.0; 33;0.0;1006; 89; 0; 1; 0;
                          15.12.2022;Thu;05; -8.6;-13.1; 8;342; 8; 10; 10; 10; 0.0; 33;0.0;1007; 90; 0; 1; 0;
                          15.12.2022;Thu;06; -9.2;-13.5; 7;339; 7; 14; 14; 14; 0.0; 33;0.0;1008; 90; 0; 1; 0;
                          15.12.2022;Thu;07; -9.8;-13.9; 7;336; 7; 17; 17; 17; 0.0; 33;0.0;1009; 90; 0; 1; 0;
                          15.12.2022;Thu;08; -8.6;-12.2; 6;341; 6; 24; 24; 24; 0.0; 42;0.0;1010; 89; 0; 8; 12;
                          15.12.2022;Thu;09; -7.4;-10.5; 6;347; 6; 30; 30; 30; 0.0; 42;0.0;1011; 87; 0; 8; 24;
                          15.12.2022;Thu;10; -6.1; -8.8; 5;353; 5; 36; 36; 36; 0.0; 42;0.0;1013; 86; 0; 8; 36;
                          15.12.2022;Thu;11; -4.7; -4.7; 4;343; 4; 25; 25; 25; 0.0; 42;0.0;1013; 80; 0; 8; 104;
                          15.12.2022;Thu;12; -3.2; -3.2; 3;333; 3; 14; 14; 14; 0.0; 42;0.0;1013; 75; 0; 1; 173;
                          15.12.2022;Thu;13; -1.7; -1.7; 2;323; 2; 2; 2; 2; 0.0; 42;0.0;1014; 71; 0; 1; 242;
                          15.12.2022;Thu;14; -3.3; -3.3; 2;300; 2; 3; 3; 3; 0.0; 28;0.0;1014; 76; 0; 1; 211;
                          15.12.2022;Thu;15; -4.9; -4.9; 1;277; 1; 4; 4; 4; 0.0; 28;0.0;1015; 82; 0; 1; 180;
                          15.12.2022;Thu;16; -6.4; -6.4; 1;254; 1; 5; 5; 5; 0.0; 28;0.0;1016; 89; 0; 1; 149;
                          15.12.2022;Thu;17; -7.7; -7.7; 2;285; 2; 10; 10; 10; 0.0; 28;0.0;1017; 89; 0; 1; 99;
                          15.12.2022;Thu;18; -9.0; -9.0; 3;315; 3; 15; 15; 15; 0.0; 28;0.0;1018; 89; 0; 1; 49;
                          15.12.2022;Thu;19;-10.2;-10.2; 4;346; 4; 20; 20; 20; 0.0; 28;0.0;1019; 90; 0; 1; 0;
                          15.12.2022;Thu;20;-10.6;-10.6; 4;235; 4; 18; 18; 18; 0.0; 19;0.0;1019; 89; 0; 1; 0;
                          15.12.2022;Thu;21;-11.0;-11.0; 4;125; 4; 17; 17; 17; 0.0; 19;0.0;1020; 89; 0; 1; 0;
                          15.12.2022;Thu;22;-11.3;-11.3; 4; 14; 4; 16; 16; 16; 0.0; 19;0.0;1021; 89; 0; 1; 0;
                          15.12.2022;Thu;23;-11.7;-11.7; 4; 16; 4; 12; 12; 12; 0.0; 19;0.0;1021; 89; 0; 1; 0;
                          16.12.2022;Fri;00;-12.1;-12.1; 4; 18; 4; 9; 9; 9; 0.0; 19;0.0;1021; 89; 0; 1; 0;
                          16.12.2022;Fri;01;-12.4;-12.4; 3; 19; 3; 5; 5; 5; 0.0; 19;0.0;1021; 89; 0; 1; 0;
                          16.12.2022;Fri;02;-12.7;-12.7; 3; 19; 3; 17; 17; 17; 0.0; 14;0.0;1021; 89; 0; 1; 0;
                          16.12.2022;Fri;03;-13.0;-13.0; 3; 19; 3; 29; 29; 29; 0.0; 14;0.0;1022; 89; 0; 8; 0;
                          16.12.2022;Fri;04;-13.3;-13.3; 3; 19; 3; 41; 41; 41; 0.0; 14;0.0;1023; 89; 0; 8; 0;
                          16.12.2022;Fri;05;-13.5;-13.5; 3; 19; 3; 40; 40; 40; 0.0; 14;0.0;1023; 88; 0; 8; 0;
                          16.12.2022;Fri;06;-13.6;-13.6; 3; 19; 3; 39; 39; 39; 0.0; 14;0.0;1023; 88; 0; 8; 0;
                          16.12.2022;Fri;07;-13.7;-13.7; 3; 18; 3; 38; 38; 38; 0.0; 14;0.0;1024; 87; 0; 8; 0;
                          16.12.2022;Fri;08;-12.0;-12.0; 2; 31; 2; 27; 27; 27; 0.0; 19;0.0;1024; 85; 0; 8; 13;
                          16.12.2022;Fri;09;-10.3;-10.3; 2; 43; 2; 16; 16; 16; 0.0; 19;0.0;1024; 83; 0; 1; 27;
                          16.12.2022;Fri;10; -8.5; -8.5; 1; 56; 1; 4; 4; 4; 0.0; 19;0.0;1025; 82; 0; 1; 41;
                          16.12.2022;Fri;11; -6.9; -6.9; 1; 66; 1; 3; 3; 3; 0.0; 19;0.0;1024; 78; 0; 1; 108;
                          16.12.2022;Fri;12; -5.2; -5.2; 1; 76; 1; 2; 2; 2; 0.0; 19;0.0;1024; 74; 0; 1; 175;
                          16.12.2022;Fri;13; -3.5; -3.5; 1; 85; 1; 0; 0; 0; 0.0; 19;0.0;1024; 71; 0; 1; 242;
                          16.12.2022;Fri;14; -4.8; -4.8; 1; 64; 1; 2; 2; 2; 0.0; 9;0.0;1024; 76; 0; 1; 210;
                          16.12.2022;Fri;15; -6.1; -6.1; 1; 42; 1; 3; 3; 3; 0.0; 9;0.0;1024; 81; 0; 1; 178;
                          16.12.2022;Fri;16; -7.3; -7.3; 1; 20; 1; 5; 5; 5; 0.0; 9;0.0;1025; 87; 0; 1; 147;
                          16.12.2022;Fri;17; -8.5; -8.5; 2; 18; 2; 5; 5; 5; 0.0; 9;0.0;1025; 87; 0; 1; 98;
                          16.12.2022;Fri;18; -9.6; -9.6; 3; 16; 3; 5; 5; 5; 0.0; 9;0.0;1026; 88; 0; 1; 49;
                          16.12.2022;Fri;19;-10.7;-10.7; 4; 14; 4; 5; 5; 5; 0.0; 9;0.0;1027; 88; 0; 1; 0;
                          16.12.2022;Fri;20;-11.1;-11.1; 4; 19; 4; 9; 9; 9; 0.0; 23;0.0;1027; 89; 0; 1; 0;
                          16.12.2022;Fri;21;-11.6;-11.6; 4; 24; 4; 13; 13; 13; 0.0; 23;0.0;1027; 89; 0; 1; 0;
                          16.12.2022;Fri;22;-11.9;-11.9; 4; 29; 4; 17; 17; 17; 0.0; 23;0.0;1028; 90; 0; 1; 0;
                          16.12.2022;Fri;23;-12.0;-15.2; 5; 29; 5; 26; 26; 26; 0.0; 23;0.0;1028; 90; 0; 8; 0;
                          17.12.2022;Sat;00;-12.1;-15.5; 5; 28; 5; 35; 35; 35; 0.0; 23;0.0;1028; 90; 0; 8; 0;
                          17.12.2022;Sat;01;-12.1;-15.8; 5; 27; 5; 43; 43; 43; 0.0; 23;0.0;1028; 90; 0; 8; 0;
                          17.12.2022;Sat;02;-12.0;-15.7; 5; 23; 5; 62; 62; 62; 0.0; 14;0.0;1028; 90; 0; 8; 0;
                          17.12.2022;Sat;03;-11.9;-15.5; 5; 20; 5; 81; 81; 81; 0.0; 14;0.0;1028; 90; 0; 8; 0;
                          17.12.2022;Sat;04;-11.7;-15.4; 5; 17; 5;100;100;100; 0.0; 14;0.0;1028; 90; 0;22; 0;
                          17.12.2022;Sat;05;-11.4;-14.8; 5; 18; 5;100;100;100; 0.0; 14;0.0;1027; 90; 0;22; 0;
                          17.12.2022;Sat;06;-11.1;-14.3; 5; 20; 5;100;100;100; 0.0; 14;0.0;1027; 90; 0;22; 0;
                          17.12.2022;Sat;07;-10.7;-13.8; 5; 21; 5;100;100;100; 0.0; 14;0.0;1027; 90; 0;22; 0;
                          17.12.2022;Sat;08; -9.6; -9.6; 4; 30; 4;100;100;100; 0.0; 19;0.0;1027; 87; 0;22; 10;
                          17.12.2022;Sat;09; -8.4; -8.4; 4; 38; 4;100;100;100; 0.0; 19;0.0;1028; 85; 0;22; 21;
                          </station>
                        • jroesch
                          Was auch noch komisch ist (bei mir):
                          Beim Abruf über das Webinterface werden andere Zeiten für Sonnenauf- und -untergang angezeigt, als in der Loxone App.
                          Das mit den unterschiedlichen Orten leuchtet mir noch ein, da ich den fürs Webinterface ja selber vergeben kann.
