kann mir jemand sagen, warum die Werte unterschiedlich sind? (Auch wenn es nur minimal ist)
Oben sind die Werte vom Wetterserver = Emulator und unten virtuelle Eingänge vom Plugin.
Danke und Gruß
Stefan
LoxBerry - Beyond the LimitsLogfile does not exist. Use file in ~/log, ~/webfrontend/html/tmp or /tmp und give relative path started from these folders.<br><br>Usage: /admin/system/tools/logfile.cgi?logfile=FILE[&length] [&offset] [&header= txt|html|none] [&format=html|terminal|plain|template]
loxberry@loxberry:~ $ loxberry@loxberry:~ $ /opt/loxberry/webfrontend/cgi/plugins/wu4lox/bin/fetch.pl -v -bash: loxberry@loxberry:~: command not found loxberry@loxberry:~ $ <INFO> Starting /opt/loxberry/webfrontend/cgi/plugins/wu4lox/bin/fetch.pl Version 3.0.5 -bash: INFO: No such file or directory loxberry@loxberry:~ $ <INFO> Fetching Data for pws:IHAMBURG893 -bash: INFO: No such file or directory loxberry@loxberry:~ $ <INFO> URL: http://api.wunderground.com/api/xxxxxxxxxxxxxxx/conditions/astronomy/forecast/hourly10day/pws:1/lang:DL/q/pws:IHAMBURG893.json -bash: INFO: No such file or directory loxberry@loxberry:~ $ <INFO> Saving new Data for Timestamp Tue, 21 Nov 2017 16:25:59 +0100 to database. -bash: INFO: No such file or directory loxberry@loxberry:~ $ Cannot open /opt/loxberry/data/plugins/wu4lox/current.dat: Permission denied at /opt/loxberry/webfrontend/cgi/plugins/wu4lox/bin/fetch.pl line 99. -bash: Cannot: command not found
total 0 lrwxrwxrwx 1 loxberry loxberry 57 Nov 21 16:54 wu4lox -> /opt/loxberry/webfrontend/cgi/plugins/wu4lox/bin/fetch.pl
# m h dom mon dow user command 17 * * * * root cd / && run-parts --report /etc/cron.hourly 25 6 * * * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily ) 47 6 * * 7 root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly ) 52 6 1 * * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly ) # # Loxberry # # m h dom mon dow user command * * * * * loxberry cd / && run-parts /opt/loxberry/system/cron/cron.01min > /dev/null 2>&1 */3 * * * * loxberry cd / && run-parts /opt/loxberry/system/cron/cron.03min > /dev/null 2>&1 */5 * * * * loxberry cd / && run-parts /opt/loxberry/system/cron/cron.05min > /dev/null 2>&1 */10 * * * * loxberry cd / && run-parts /opt/loxberry/system/cron/cron.10min > /dev/null 2>&1 */15 * * * * loxberry cd / && run-parts /opt/loxberry/system/cron/cron.15min > /dev/null 2>&1 */30 * * * * loxberry cd / && run-parts /opt/loxberry/system/cron/cron.30min > /dev/null 2>&1 13 * * * * loxberry cd / && run-parts /opt/loxberry/system/cron/cron.hourly > /dev/null 2>&1 23 4 * * * loxberry cd / && run-parts /opt/loxberry/system/cron/cron.daily > /dev/null 2>&1 33 4 * * 1 loxberry cd / && run-parts /opt/loxberry/system/cron/cron.weekly > /dev/null 2>&1 43 4 1 * * loxberry cd / && run-parts /opt/loxberry/system/cron/cron.monthly > /dev/null 2>&1 53 4 1 1 * loxberry cd / && run-parts /opt/loxberry/system/cron/cron.yearly > /dev/null 2>&1 #
ls -l /opt/loxberry/data/plugins/wu4lox/current.dat
LoxBerry - Beyond the Limitsloxberry@loxberry:~ $ ls -l /opt/loxberry/data/plugins/wu4lox/current.dat lrwxrwxrwx 1 loxberry loxberry 31 Nov 21 17:50 /opt/loxberry/data/plugins/wu4lox/current.dat -> /var/run/shm/wu4lox/current.dat
