Release der Version 1.x
  • Gagi
    • 20.01.2018
    • 296
    Congrats, super Projekt, danke für die ganze Zeit und Neben die du hier investierst.
      • 7433
      Zitat von mac338
      Hi, ist die Spotify Integration im MSG geplant ?
      Ja, ist sie. Der eigentliche Entwickler mjesun hat hier schon gute fortschritte gemacht. Mal sehen wann er es Zeitlich schafft die integration weiterzugeben.
      • Iluminatus23
        • 07.08.2016
        • 235
        Zitat von TomekWaw
        tom37
        I highly recommend you connecting Sonos speakers with Airplay Bridge instead of UPnP Bridge. ROAP is superior to DLNA as it supports zone synchronization. I'm using it with three Sonos speakers right now and it works on RPi perfectly.
        Is it possible to sync sonos and "normal" zones by using this Airplay bridge?
          • 7433
          Tried it right now, works.
          Starts with a short delay and works after a second fine.
            • 7433
            Zitat von TomekWaw
            tom37
            Also Events TTS etc works much more faster when Sonos is connected via AirPlay-Bridge.
            • Iluminatus23
              • 07.08.2016
              • 235
              that sounds great. Can you give me an link to an airplay bridge tutorial, please?
              • 7433
              Unfortunatly no devices appear.... I want to pair some Play1 und Play5... :/
              Screenshot of the Settings...
              Is the Service running?
              Is Settings-File generated?
Ansichten: 468
Größe: 65,9 KB
              Than the Sonos-Player should be shown.
Ansichten: 376
Größe: 14,2 KB
              • Iluminatus23
                • 07.08.2016
                • 235
                mea culpa. The original Play1 and Play5 doesn*t support Airplay. Thats the cause, isn*t it?
                  • 7433
                  Than use UPnP-Bridge to use the Player as external Zone.
                  • Iluminatus23
                    • 07.08.2016
                    • 235
                    Yeah, but With this there is no chance to sync internal and external zones correctly
                      Your right, that isn't possible to sync such Zones.
                    • Iluminatus23
                      Iluminatus23 kommentierte
                      Ok. So there is only a Chance to Do this by buying a newer Sonos and using the airplay bridge, right?
                      Yes, or... Ikea Symfonisk instead of the Sonos One
                  • Iluminatus23
                    • 07.08.2016
                    • 235
                    Thank you und Thank you very much for this great Release!!!
                    • TomekWaw
                      • 25.07.2019
                      • 444
                      If by "original" you mean Play:5 Gen 1 here, then you're right - they don't support Airplay, unfortunately. And will never do. Airplay1 is not supported by Apple devices anymore and Airplay2 in a speaker requires 64-bit cpu and memory resources those "old" Sonos speakers just don't have.
                      The only Sonos products that support Airplay (2) are:
                      • One
                      • One SL
                      • Move
                      • Play:5 (Gen 2)
                      • Five
                      • Playbase
                      • Beam
                      • Arc
                      • Port
                      • Amp
                      • and two speakers sold by IKEA as Symfonisk
                      • f.hien
                        • 380
                        Hallo zusammen, nun muss ich auch nochmal ein Herzliches Danke Sagen an @hismastervoice für diue Spitzen Arbeit. Das Update lief ohne Problem von der Version 0.7 auf die Version 1.0.11.
                        Zwei Kleinigkeiten habe ich. Zum einen ist es mir nun zwei mal passiert das sich irgendwie die USB Verbindung aufhängt. Die Soundkarten werden erkannt aber es wird nichts mehr gespielt. (Nur bei Internen) die Externen Funktionieren. Server und Soundkarten liefen unter Version 0.7x ohne Fehler. erst nach einem Ausstecken und anstecken der USB Soundkarten gings wieder.
                        2. Bei dem Email Settings ist es möglich einzustellen das ohne Authentifizierung verschickt wird?
                        • oa20
                          oa20 kommentierte
                          Den kleinen Fehler mit der USB Soundkarte hatte ich auch schon bei vorherigen Versionen. War aber nur bei den Updates direkt danach der Fall. Danach nicht mehr.
                        • 7433
                        zu 1
                        Gibt es etwas was du in dem Augenblick machst oder ist das willkürlich?
                        Wenn du zB an den Soundkarten etwas änderst oder könnte es sein das nicht mehr alle Player start. Das habe ich in der nächsten Version gefixt
                        Wenn das passiert bitte mal schauen ob im Dashboard alle Zonen auf rot sind.
                        Dann MusikServer unter Dienste anklicken und Neustart aller Dienste wählen.
                        zu 2
                        Nein man kann "absichtlich" keine unverschlüsselten SMTP einstellen. Ich denke das seit einigen Jahren alle Provider nur noch verschlüsselte Verbindungen anbieten.
                        Hast du einen speziellen Fall?
                        • f.hien
                          • 380
                          #30
                          zu 1
                          Nein es ist willkürlich, mir ist es heute früh aufgefallen weil der wecker nichts gespielt hat.
                          Vorgestern nach dem Update lief die Zone Büro. Ich hatte sie ausgeschaltet und nach ca. 1h bis 1,5 wieder ein leider kein Ton.
                          Ich der Oberfläche aber alles Grün und es wurde auch angezeigt das was laufen würde. genauso heute früh. Nur eben kein Ton
                          zu 2
                          Ein Weiterleitung auf einen Internen Mail Server. Weil irgendwie kommt er mit der Domän regiestrierung nich zurecht.
