MS4H V1.2.0_beta - the next big thing ;)
    • 7599
    After a long period of development we (gagi and me) like to introduce the V1.2.0_beta.
    What's included... A lot of fixes, and even more new cool stuff.
    The biggest thing is the MSG in a new Version. ULTRA, MEGA, BIG THANKS to Gagi
    The most functions are working (see Changelog below), included the announcement function (reserved for the AudioServer)
    Also the https-function of the MiniServer V2 is supported now.
    A lot of new Stuff at Events...
    Now its possible with "single Event" to use multiple instances of events at one time. eg. Alarm-Clock in different Rooms at the same time.
    Better support for network-shares
    and,and,and..., see Changelog...
    but be careful, it's still a beta version!!
    Tested on X86, Raspberry 3B and 4
    Read the manual!!! (only in german, looking for contributors to translate the manual)
    #V1.2.3.3_beta
    System
    fix -> config is not read if update from <= v1.0.12 on Virtual Machines
    #V1.2.3.2_beta
    System
    change -> Support-Data show again MSG Config, (was removed because of showing plain-password), Now password is exchanged by xxxxx before shown in Support-Data-File
    new -> Raspberry, possibility to deactivate the GPIO Service in PowerManger, needed if you use e.g. HifiBerry Amp2
    MSG
    new -> Filter options for Spotify Menu in WebUI -> MusicServerGateway
    new -> more Filter options for Radio in WebUI -> MusicServerGateway
    new -> User multiple Spotify Users -> Important read manual! (Add Users to MSG-Config)
    fix -> sayFav didn't say Fav-Names with German "Umlauts"
    WebUI
    new -> MiniServer User/password check
    improve -> minor optical improvements
    change -> KNX-Connect, KNXd configuration shows now direct the /etc/knxd.cfg and saves to it. Because of complexity it is not possible to build a simple form to config it.
    new -> RoomFav Editor (->Tools ->LoxHelper), you can rearrange or change Name,Stream-URL,Image-URL of Room-Favs
    improve -> Handling of disconnected external Zones
    #V1.2.0_beta
    Events
    fix -> ResponsiveVoice didn't work
    fix -> missed language-variables for one/minus one
    fix -> stop for type playfav works now
    fix -> external Zones play Event with repeat (endless), if repeat was set before at music playing
    fix -> autoplay set now explicit stop if autoplay is not 1
    new -> new Event for single Zones. Works independent for each event/zone, so it's possible to have alarm-clock etc for each Zone separate. Events are stoppable by pause/stop the zone.
    new -> category's &cat=bell / alarm / fire-alarm / clock so we can handle the Events from Music-Block in Config
    new -> Event-Creator for Single-Zone
    new -> risevol implemented in Event-Generator
    new -> change standard-event-setting from MiniServer with URL
    new -> The title will be played at the same position as it had been played before the event. (in special fro external zones)
    MiniServer
    new -> support of https-connection for MiniServer V2
    Statistic
    new -> add configured Speaker-Set (Stereo/Down-mix/Total-Speaker)
    Raspi
    fix -> GPIO not always working
    fix -> minor issues at start-sequence
    fix -> wrong Binary ARM<->X86
    WebUI
    update -> language files
    fix -> add missed variables
    new -> User-settings with password-hash to use functions from outside the WebUI
    Netshare
    new -> Samba Version choosable, e.g. for older NAS or FritzBox >V7.20
    fix -> Apache-Crash when not all form has data at saving
    Install-Script
    new-> always install latest LMS Version
    new-> Setup all packages for MSG
    Update
    new -> Update now automatically reads the latest-version of the LMS, no code changes for further LMS versions e.g. 8.2,8.3,9.0.....
    System
    change -> LMS 8.x is now standard, 7.9.x is not supported anymore
    new -> Folder /tmp (ram-drive) gets automatic cleaned after period
    new -> Start/Stop for own script, put your own executable scripts into /opt/music_server/init/start or .../stop and they get executes on system start or system stop (files has to be executable 0755)
    new -> reboot/shutdown or services control via URL (https://music-server.net/help/Reboot...erMiniSer.html)
    WARNING!! The old power.php is not reachable from outside any longer, if used in MiniServer please switch to the new set.php
    MusicServerGateway
    new -> MSG V1.2 Beta
    most of the functions are now integrated
    Zuletzt geändert von hismastersvoice; 14.02.2021, 07:13.
    • 7599
    Sammel-Post für gemeldete Fehler
    - Spotify Suche funktioniert nicht sauber wenn nur ein User in Spotify angelegt ist. ## fixed with v1.2.1_beta ##
    - RoomFav fängt beim ersten RoomFav an wenn ein stop anstatt eine pause gesendet wurde. ## fixed with v1.2.1_beta ##
    - Synchronisation hat einen Versatz in machen Zonen.## fixed with v1.2.1_beta ##
    - Internet Radio, stream URL wird als Sender Alias bei der Widergabe angezeigt. (Raspberry Pi3)
    - Wiedergabe übernehmen funktioniert nicht (bekannter Fehler) ## fixed with v1.2.1_beta ##
    Zuletzt geändert von hismastersvoice; 02.01.2021, 14:21.
    • oa20
      • 31.01.2016
      • 152
      Respekt!!!!! Danke für deine Hingabe!
      Bin gespannt wie lange das Loxone noch mit ansieht
        Vermutlich lange
        Sonst müssten sie alle User der org. MusikServer zum Update zwingen.
        Aber wir wissen ja was Loxone schon alles gemacht hat, ausgeschlossen ist das nicht.
        Ernsthaft...
        Ich glaube kaum das Loxone das als Bedrohung ansieht. dazu sind wir zu wenige.
        Sollten es aber "viel" mehr werden, dann kann das schon passieren.
        PS: Meine Hingabe und die von Gagi. Der hat beim MSG mehr Arbeit als ich
      • oa20
        oa20 kommentierte
        Natürlich, ein großes Danke an euch Beide!!!
    • menK0
      • 20.06.2019
      • 23
      First, thank you for your hard work. This is a huge improvement.
      Fehler:
        Aufgenommen, ist nicht nur beim Raspi so.
    • czgaston
      • 22.09.2018
      • 14
      I have a question about TTS weather.
      When there are two values {condition today} a sign is inserted / is it possible to insert a conjunction?
      For example - und, and, a .....by language
      I did not find anything in the translation
        • 7599
        Not sure if I understand right.... Can you give me an more detail example with a full sentence.
          Hmmmm
          I get an und if there are two conditions.
          Text = Heute haben wir einen Mix aus Schnee und Regen, die Höchsttemperatur beträgt ein Grad, die Tiefsttemperatur Minus ein Grad. Die Regenwahrscheinlichkeit liegt bei 75 Prozent.
          How is your sting is looking.
          I found the issue.
          You have used in cz translation a "/" between the conditions.
          So for sure you can use an "and".
          $language ["WTTS_CONDITION_610"] = 'mix sněžení/ déšťě';
          $language ["WTTS_CONDITION_731"] = 'písek / prach
        • czgaston
          czgaston kommentierte
          Oh, I'll fix it tonight
      • duncan
        • 330
        i got an installation error but things still seem to work Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 1435
Größe: 82,7 KB
          Happens because of overhangs... But this is only from console and not from WebUI.
          It work even if you get this message.
      • oa20
        • 31.01.2016
        • 152
        Hallo an Euch.
        Habe zwei Sachen bei denen ich etwas nachfragen möchte. Seit dem Update 1.2.0 Beta ist das Synchronisieren nicht mehr synchron. In Loxone sowie über den LMS. Oder kommt mir das nur so vor?
        Wie bekomme ich die Durchsagen laut? Es scheint als würde er mit der Lautstärke komplett herunterfahren. Danach läuft die Musik in der normalen Lautstärke weiter.
        Der Rest läuft soweit super und stabil. Werde aber gerne nach Silvester ausgiebig weiter testen.
        Danke, bg.
          • 7599
          Durchsage Volume kannst du in den TTS-Settings einstellen.
          Die Handys nehmen unterschiedlich laut auf. Ich versuche durch Normalisierung das ganze gleich zu ziehen.
          Das Handy sollte auch nicht zu nahe an den Mund gehalten werden.
          Synchronisieren ist synchronisieren, wir sagen nur dem LMS das er das machen soll. Wir machen das nicht selber.
          Was genau ist nicht synchron? interne Zonen externe Zonen Events....?
          • oa20
            • 31.01.2016
            • 152
            Also wenn er die Durchsage startet, dann sieht man wie die Lautstärke auf 0 herunter geht. Danach geht sie wieder auf die ursprüngliche Lautstärke zurück. TTS hätte ich auf 60 eingestellt.
            Ich habe beim Synchronisieren normale Radiosender probiert. Mir kommt vor dass sie jetzt etwas verzögert sind und nicht mehr 100 Prozentig synchron wie davor bei 1.0.12 stable. Ich nutze alles interne Zonen.
              Ich denke das mit dem sync liegt daran das wir im Gegensatz zum LMS alle Zonen direkt auf play setzen.
              Im LMS und org. MusikServer muss man die Zonen noch manuell auf play setzen.
              Ich habe es versucht nachzustellen, es ist mir aber von vielen Versuchen nur 2x gelungen einen leichten Versatz zu bekommen.
              Kann vielleicht auch an der Geschwindigkeit des System liegen oder was anderem.
              Wir werden das wohl wieder raus nehmen müssen mit dem play.
            • Gagi
              Gagi kommentierte
              Ich glaube wir haben es jetzt hinbekommen das die Zonen auf play gehen und es trotzdem syncron bleibt. Das sollte dann mit dem nächsten Update kommen.
            • oa20
              oa20 kommentierte
              Danke für die Info. Super!
          • tollertenya
            • 20.10.2019
            • 148
            Super Update ich bin sehr happy damit tolle Arbeit - kann man euch beiden Spenden zukommen lassen?
            Sollte das hinzufügen von Spotify Elementen zu den Raumfavoriten bereits funktionieren? Das tut es bei mir nämlich nicht.
            Zuletzt geändert von tollertenya; 29.12.2020, 07:56.
            • Gagi
              Gagi kommentierte
              Hi, nein Spotify Elemente direkt zu den Raumfavoriten hinzufügen geht noch nicht. Du kannst dir mit nem Workaround behelfen, indem du im LMS Web-UI das Spotify Element in die globalen Favoriten aufnimmst und ihn dann von da über die App in die Raumfavoriten bringst. Das sollte gehen.
          • simekp02
            • 22.10.2020
            • 10
            super aktualizace..mnohé díky skvělá práce
            by mohla být přidána NASTAVENÍ SIGNÁLU do globálního nastavení TTS ???
            nyní použijte TTS na hudebním serveru ...
            v minulém generátoru událostí (odkaz HTML) a pracovní vytvoření
            Zuletzt geändert von simekp02; 29.12.2020, 15:44.
            • simekp02
              simekp02 kommentierte
              question was about SIGNAL for TTS
            • hme0354
              hme0354 kommentierte
              war das nicht vor 5min noch Englisch? Egal habs auch in Englisch nicht verstanden
            • Gagi
              Gagi kommentierte
              I also don't get it, please write a full english sentence on what you think is missing or doesn't work.
            • 7599
            I think you meant to ask if signals 1,2,3 can also be implemented in the TTS/alarm/announcement standards.
            Right?
            Something like that...
Ansichten: 1185
Größe: 22,1 KB
            Zuletzt geändert von hismastersvoice; 29.12.2020, 17:20.
            • simekp02
              Yes You are right..
              I mean thats signals and implementation in TTS/alarm/announcement standards.
              Could be??
            • hme0354
              what signals are that?
              @hme354 signal=1(2,3) Es werden vom den Event ein kurzer Signalsound abgespielt. So das man zB direkt hört das ein Event anfängt.
              @simekp02
              Makes only sense for the TTS, Alarm etc are Sounds that don`t need a signal before they are played.
              Will implement it for next update.
            • 7599
            simekp02
Ansichten: 1174
Größe: 13,0 KB
            If added this option to TTS.
            So you can set a signal for MSG and URL Events, or only if the Event comes from the MSG.
            All options are open than how to use it.
            I also implemented it to the set.php, so you can also change the value from the MiniServer with a logic
            Will add it also to the manual than before the update comes.
            OK for you?
            • simekp02
              Super thats it
              Many many thanks
          • Hannes Schellnast
            • 93
            Bin gerade beim Testen der neuen Beta Version:
            Nach dem Umstieg von Ubuntu auf Debian bin ich von der neuen Oberfläche und den Features begeistert. Auch mein eigenes Plugin funktionierte ohne irgendwelchen Änderungen im C++ Code ohne Probleme mit der letzten Version vom MS4Home. Da sich in den Konfig-Files keine Namen geändert haben, kommt auch meine Applikation damit ohne Probleme zurecht.
            Großes Lob an hismastersvoice !!!
            Folgende Punkte sind mir in der Beta aufgefallen:
            - Zum Feature: new -> Start/Stop for own script, put your own executable scripts into /opt/music_server/init/start or .../stop and they get executes on system start or system stop (files has to be executable 0755)
            Zu welchem Zeitpunkt werden die Scripte gestartet? Mir ist aufgefallen, dass sie beim "System neu starten" durchlaufen werden, jedoch nicht, wenn aus dem Dashboard unter "Dienste->MusicServer->Neustart aller Dienste" ausgeführt wird. Ist das so gewollt, oder sollten die Scripts nicht auch beim Starten/Stoppen/Neustarten ausgeführt werden?
            - Vielleicht sollte in die Doku mit aufgenommen werden, dass im Zonenmenü immer nur die letzte Zone gelöscht werden kann.
            MfG
            Hannes
