What's included... A lot of fixes, and even more new cool stuff.
The biggest thing is the MSG in a new Version. ULTRA, MEGA, BIG THANKS to Gagi
The most functions are working (see Changelog below), included the announcement function (reserved for the AudioServer)
Also the https-function of the MiniServer V2 is supported now.
A lot of new Stuff at Events...
Now its possible with "single Event" to use multiple instances of events at one time. eg. Alarm-Clock in different Rooms at the same time.
Better support for network-shares
and,and,and..., see Changelog...
but be careful, it's still a beta version!!
Tested on X86, Raspberry 3B and 4
Read the manual!!! (only in german, looking for contributors to translate the manual)
#V1.2.3.3_beta
System
fix -> config is not read if update from <= v1.0.12 on Virtual Machines
#V1.2.3.2_beta
System
change -> Support-Data show again MSG Config, (was removed because of showing plain-password), Now password is exchanged by xxxxx before shown in Support-Data-File
new -> Raspberry, possibility to deactivate the GPIO Service in PowerManger, needed if you use e.g. HifiBerry Amp2
MSG
new -> Filter options for Spotify Menu in WebUI -> MusicServerGateway
new -> more Filter options for Radio in WebUI -> MusicServerGateway
new -> User multiple Spotify Users -> Important read manual! (Add Users to MSG-Config)
fix -> sayFav didn't say Fav-Names with German "Umlauts"
WebUI
new -> MiniServer User/password check
improve -> minor optical improvements
change -> KNX-Connect, KNXd configuration shows now direct the /etc/knxd.cfg and saves to it. Because of complexity it is not possible to build a simple form to config it.
new -> RoomFav Editor (->Tools ->LoxHelper), you can rearrange or change Name,Stream-URL,Image-URL of Room-Favs
improve -> Handling of disconnected external Zones
#V1.2.0_beta
Events
fix -> ResponsiveVoice didn't work
fix -> missed language-variables for one/minus one
fix -> stop for type playfav works now
fix -> external Zones play Event with repeat (endless), if repeat was set before at music playing
fix -> autoplay set now explicit stop if autoplay is not 1
new -> new Event for single Zones. Works independent for each event/zone, so it's possible to have alarm-clock etc for each Zone separate. Events are stoppable by pause/stop the zone.
new -> category's &cat=bell / alarm / fire-alarm / clock so we can handle the Events from Music-Block in Config
new -> Event-Creator for Single-Zone
new -> risevol implemented in Event-Generator
new -> change standard-event-setting from MiniServer with URL
new -> The title will be played at the same position as it had been played before the event. (in special fro external zones)
MiniServer
new -> support of https-connection for MiniServer V2
Statistic
new -> add configured Speaker-Set (Stereo/Down-mix/Total-Speaker)
Raspi
fix -> GPIO not always working
fix -> minor issues at start-sequence
fix -> wrong Binary ARM<->X86
WebUI
update -> language files
fix -> add missed variables
new -> User-settings with password-hash to use functions from outside the WebUI
Netshare
new -> Samba Version choosable, e.g. for older NAS or FritzBox >V7.20
fix -> Apache-Crash when not all form has data at saving
Install-Script
new-> always install latest LMS Version
new-> Setup all packages for MSG
Update
new -> Update now automatically reads the latest-version of the LMS, no code changes for further LMS versions e.g. 8.2,8.3,9.0.....
System
change -> LMS 8.x is now standard, 7.9.x is not supported anymore
new -> Folder /tmp (ram-drive) gets automatic cleaned after period
new -> Start/Stop for own script, put your own executable scripts into /opt/music_server/init/start or .../stop and they get executes on system start or system stop (files has to be executable 0755)
new -> reboot/shutdown or services control via URL (https://music-server.net/help/Reboot...erMiniSer.html)
WARNING!! The old power.php is not reachable from outside any longer, if used in MiniServer please switch to the new set.php
MusicServerGateway
new -> MSG V1.2 Beta
most of the functions are now integrated
