Problem mit Loxone Music Server
Sounds ab bit like Alsa don't store the settings.
Try at my test system, but work even after a reboot.
Can you send me a Screenshot of the Soundcard Settings (WebUI) and without canging anything the output of the Termianl
amixer -c 0
amixer -c 1
amixer -c 2 -
Code:root@MusicServer:~# amixer -c 0 Simple mixer control 'Master',0 Capabilities: pvolume pswitch pswitch-joined Playback channels: Front Left - Front Right - Rear Left - Rear Right - Front C enter - Woofer - Side Left - Side Right Limits: Playback 135 - 255 Mono: Front Left: Playback 255 [100%] [0.00dB] [on] Front Right: Playback 255 [100%] [0.00dB] [on] Rear Left: Playback 255 [100%] [0.00dB] [on] Rear Right: Playback 255 [100%] [0.00dB] [on] Front Center: Playback 255 [100%] [0.00dB] [on] Woofer: Playback 255 [100%] [0.00dB] [on] Side Left: Playback 255 [100%] [0.00dB] [on] Side Right: Playback 255 [100%] [0.00dB] [on] Simple mixer control 'Headphone',0 Capabilities: pvolume pswitch pswitch-joined Playback channels: Front Left - Front Right Limits: Playback 61 - 127 Mono: Front Left: Playback 61 [0%] [off] Front Right: Playback 61 [0%] [off] Simple mixer control 'Front Mic',0 Capabilities: cswitch cswitch-joined Capture channels: Mono Mono: Capture [off] Simple mixer control 'Line',0 Capabilities: cswitch cswitch-joined Capture channels: Mono Mono: Capture [on] Simple mixer control 'Mic',0 Capabilities: cswitch cswitch-joined Capture channels: Mono Mono: Capture [off] Simple mixer control 'IEC958',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'IEC958 Loopback',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'IEC958 Validity Check',0 Capabilities: cswitch cswitch-joined Capture channels: Mono Mono: Capture [off] Simple mixer control 'Aux',0 Capabilities: cswitch cswitch-joined Capture channels: Mono Mono: Capture [off] Simple mixer control 'ADC Filter',0 Capabilities: cenum Items: 'None' 'High-pass Filter' Item0: 'High-pass Filter' Simple mixer control 'Analog Input Monitor',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 1 Mono: Playback 1 [100%] [0.00dB] [off] Simple mixer control 'Digital Input Monitor',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 1 Mono: Playback 1 [100%] [0.00dB] [off] Simple mixer control 'Input',0 Capabilities: cvolume Capture channels: Front Left - Front Right Limits: Capture 165 - 255 Front Left: Capture 165 [0%] Front Right: Capture 165 [0%] Simple mixer control 'Level Control',0 Capabilities: cenum Items: 'None' 'Peak Limiter' 'Automatic Level Control' Item0: 'None' Simple mixer control 'Noise Gate',0 Capabilities: cswitch cswitch-joined Capture channels: Mono Mono: Capture [off] Simple mixer control 'Stereo Upmixing',0 Capabilities: enum Items: 'Front' 'Front+Surround' 'Front+Surround+Back' 'Front+Surround+Center/L FE' 'Front+Surround+Center/LFE+Back' Item0: 'Front+Surround' root@MusicServer:~# amixer -c 1 Simple mixer control 'IEC958',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'IEC958',1 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'IEC958',2 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'IEC958',3 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] root@MusicServer:~# amixer -c 2 Simple mixer control 'Master',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 64 Mono: Playback 44 [69%] [-20.00dB] [on] Simple mixer control 'Headphone',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 64 Mono: Front Left: Playback 64 [100%] [0.00dB] [on] Front Right: Playback 64 [100%] [0.00dB] [on] Simple mixer control 'Front',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 64 Mono: Front Left: Playback 64 [100%] [0.00dB] [on] Front Right: Playback 64 [100%] [0.00dB] [on] Simple mixer control 'Front Mic',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 0 [0%] [-34.50dB] [off] Front Right: Playback 0 [0%] [-34.50dB] [off] Simple mixer control 'Front Mic Boost',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 3 Front Left: 0 [0%] [0.00dB] Front Right: 0 [0%] [0.00dB] Simple mixer control 'Surround',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 64 Mono: Front Left: Playback 64 [100%] [0.00dB] [on] Front Right: Playback 64 [100%] [0.00dB] [on] Simple mixer control 'Center',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 64 Mono: Playback 64 [100%] [0.00dB] [on] Simple mixer control 'LFE',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 64 Mono: Playback 64 [100%] [0.00dB] [on] Simple mixer control 'Side',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 64 Mono: Front Left: Playback 64 [100%] [0.00dB] [on] Front Right: Playback 64 [100%] [0.00dB] [on] Simple mixer control 'Line',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 0 [0%] [-34.50dB] [off] Front Right: Playback 0 [0%] [-34.50dB] [off] Simple mixer control 'Line Boost',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 3 Front Left: 0 [0%] [0.00dB] Front Right: 0 [0%] [0.00dB] Simple mixer control 'IEC958',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'IEC958 Default PCM',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Capture',0 Capabilities: cvolume cswitch Capture channels: Front Left - Front Right Limits: Capture 0 - 46 Front Left: Capture 28 [61%] [12.00dB] [on] Front Right: Capture 28 [61%] [12.00dB] [on] Simple mixer control 'Capture',1 Capabilities: cvolume cswitch Capture channels: Front Left - Front Right Limits: Capture 0 - 46 Front Left: Capture 0 [0%] [-16.00dB] [off] Front Right: Capture 0 [0%] [-16.00dB] [off] Simple mixer control 'Auto-Mute Mode',0 Capabilities: enum Items: 'Disabled' 'Enabled' Item0: 'Enabled' Simple mixer control 'Input Source',0 Capabilities: cenum Items: 'Front Mic' 'Rear Mic' 'Line' Item0: 'Front Mic' Simple mixer control 'Input Source',1 Capabilities: cenum Items: 'Front Mic' 'Rear Mic' 'Line' Item0: 'Front Mic' Simple mixer control 'Loopback Mixing',0 Capabilities: enum Items: 'Disabled' 'Enabled' Item0: 'Disabled' Simple mixer control 'Rear Mic',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 0 [0%] [-34.50dB] [off] Front Right: Playback 0 [0%] [-34.50dB] [off] Simple mixer control 'Rear Mic Boost',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 3 Front Left: 0 [0%] [0.00dB] Front Right: 0 [0%] [0.00dB] root@MusicServer:~#
Zuletzt geändert von hismastersvoice; 08.01.2023, 12:01.
Can you send me please the Terminal output of...
sensors-detect --auto
Thanks.
Kein Support per PN!Kommentar
Thanks again...
Maybe I change the additional setting in "Amp all" and activate directly after install the card. Have to think about.
Will check why the PowerButton don't work. -
Found the issue please try
apt -y install acpi acpi-support
After that the PowerButton should work like expected.
If it work also for you I will pack it into install and update-script
Zuletzt geändert von digi77; 08.01.2023, 11:51.Kommentar
digi77
If think the best option is to write additional the values to a file and set it every boot of the system.
The failure is only after a reboot, during the uptime there is no change in volume by them self, right?Kein Support per PN!Kommentar
Sorry for my late response, have had several things to do on the weekend...
How can I help now?
When I start any zone via app or via T5 touch the zone starts very quiet.
I have set the volumes to 90% (as suggested in the manual)
-have set the volume setting for each zone to 100%
-"activate Channel-Volume"
When I now start playing music e.g. via T5 or via app it should get the volume settings from the MSG (if I am not wring) or if not, than it should start with the 100% pre-setting.
In the loxconfig the start up volume "Vd" is set to 25 so it should be not too quite.
with the original MuS it was much louder... now it is so quite, that you nearly do not hear that music is switched on.
output from amixer:
in next post
Code:root@Musicserver:~# amixer -c 0 Simple mixer control 'Master',0 Capabilities: pvolume pswitch pswitch-joined Playback channels: Front Left - Front Right - Rear Left - Rear Right - Front C enter - Woofer - Side Left - Side Right Limits: Playback 135 - 255 Mono: Front Left: Playback 243 [90%] [-6.00dB] [on] Front Right: Playback 243 [90%] [-6.00dB] [on] Rear Left: Playback 243 [90%] [-6.00dB] [on] Rear Right: Playback 243 [90%] [-6.00dB] [on] Front Center: Playback 243 [90%] [-6.00dB] [on] Woofer: Playback 243 [90%] [-6.00dB] [on] Side Left: Playback 243 [90%] [-6.00dB] [on] Side Right: Playback 243 [90%] [-6.00dB] [on] Simple mixer control 'Headphone',0 Capabilities: pvolume pswitch pswitch-joined Playback channels: Front Left - Front Right Limits: Playback 61 - 127 Mono: Front Left: Playback 61 [0%] [off] Front Right: Playback 61 [0%] [off] Simple mixer control 'Front Mic',0 Capabilities: cswitch cswitch-joined Capture channels: Mono Mono: Capture [off] Simple mixer control 'Line',0 Capabilities: cswitch cswitch-joined Capture channels: Mono Mono: Capture [on] Simple mixer control 'Mic',0 Capabilities: cswitch cswitch-joined Capture channels: Mono Mono: Capture [off] Simple mixer control 'IEC958',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'IEC958 Loopback',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'IEC958 Validity Check',0 Capabilities: cswitch cswitch-joined
Code:root@Musicserver:~# amixer -c 1 Simple mixer control 'Master',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 64 Mono: Playback 58 [91%] [-6.00dB] [on] Simple mixer control 'Headphone',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 64 Mono: Front Left: Playback 64 [100%] [0.00dB] [on] Front Right: Playback 64 [100%] [0.00dB] [on] Simple mixer control 'Front',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 64 Mono: Front Left: Playback 64 [100%] [0.00dB] [on] Front Right: Playback 64 [100%] [0.00dB] [on] Simple mixer control 'Front Mic',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 0 [0%] [-34.50dB] [off] Front Right: Playback 0 [0%] [-34.50dB] [off] Simple mixer control 'Front Mic Boost',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 3 Front Left: 0 [0%] [0.00dB] Front Right: 0 [0%] [0.00dB] Simple mixer control 'Surround',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 64 Mono: Front Left: Playback 64 [100%] [0.00dB] [on] Front Right: Playback 64 [100%] [0.00dB] [on] Simple mixer control 'Center',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 64 Mono: Playback 64 [100%] [0.00dB] [on] Simple mixer control 'LFE',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 64 Mono: Playback 64 [100%] [0.00dB] [on] Simple mixer control 'Side',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 64 Mono: Front Left: Playback 64 [100%] [0.00dB] [on] Front Right: Playback 64 [100%] [0.00dB] [on] Simple mixer control 'Line',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 0 [0%] [-34.50dB] [off] Front Right: Playback 0 [0%] [-34.50dB] [off] Simple mixer control 'Line Boost',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 3 Front Left: 0 [0%] [0.00dB] Front Right: 0 [0%] [0.00dB] Simple mixer control 'IEC958',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'IEC958 Default PCM',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Capture',0 Capabilities: cvolume cswitch Capture channels: Front Left - Front Right Limits: Capture 0 - 46 Front Left: Capture 28 [61%] [12.00dB] [on] Front Right: Capture 28 [61%] [12.00dB] [on] Simple mixer control 'Capture',1 Capabilities: cvolume cswitch Capture channels: Front Left - Front Right Limits: Capture 0 - 46 Front Left: Capture 0 [0%] [-16.00dB] [off] Front Right: Capture 0 [0%] [-16.00dB] [off] Simple mixer control 'Input Source',0 Capabilities: cenum Items: 'Front Mic' 'Rear Mic' 'Line' Item0: 'Front Mic' Simple mixer control 'Input Source',1 Capabilities: cenum Items: 'Front Mic' 'Rear Mic' 'Line' Item0: 'Front Mic' Simple mixer control 'Loopback Mixing',0 Capabilities: enum Items: 'Disabled' 'Enabled' Item0: 'Disabled' Simple mixer control 'Rear Mic',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 0 [0%] [-34.50dB] [off] Front Right: Playback 0 [0%] [-34.50dB] [off] Simple mixer control 'Rear Mic Boost',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 3 Front Left: 0 [0%] [0.00dB] Front Right: 0 [0%] [0.00dB] root@Musicserver:~#
