Problem mit Loxone Music Server
    • 7664
    #136
    Zitat von simon_hh
    hismastersvoice
    Habe das gleiche Phänomen, dass es viel zu leise startet und auch nicht sonderlich laut geht...
    Vielleicht hast du ne idee
    Kannst du mir das genauer beschreiben, was ist zu leise, die ganze Soundkarte oder die einzelne Zonen?
    Häng mal die Ausgabe der folgenden Befehle bitte mit an
    amixer -c 0
    amixer -c 1
    amixer -c 2
      Sounds ab bit like Alsa don't store the settings.
      Try at my test system, but work even after a reboot.
      Can you send me a Screenshot of the Soundcard Settings (WebUI) and without canging anything the output of the Termianl
      amixer -c 0
      amixer -c 1
      amixer -c 2
    • digi77
      digi77 kommentierte
      root@MusicServer:~# amixer -c 0
      Simple mixer control 'Master',0
        Capabilities: pvolume pswitch pswitch-joined
        Playback channels: Front Left - Front Right - Rear Left - Rear Right - Front C            enter - Woofer - Side Left - Side Right
        Limits: Playback 135 - 255
        Mono:
        Front Left: Playback 255 [100%] [0.00dB] [on]
        Front Right: Playback 255 [100%] [0.00dB] [on]
        Rear Left: Playback 255 [100%] [0.00dB] [on]
        Rear Right: Playback 255 [100%] [0.00dB] [on]
        Front Center: Playback 255 [100%] [0.00dB] [on]
        Woofer: Playback 255 [100%] [0.00dB] [on]
        Side Left: Playback 255 [100%] [0.00dB] [on]
        Side Right: Playback 255 [100%] [0.00dB] [on]
      Simple mixer control 'Headphone',0
        Limits: Playback 61 - 127
        Mono:
        Front Left: Playback 61 [0%] [off]
        Front Right: Playback 61 [0%] [off]
      Simple mixer control 'Front Mic',0
        Capabilities: cswitch cswitch-joined
        Capture channels: Mono
        Mono: Capture [off]
      Simple mixer control 'Line',0
        Mono: Capture [on]
      Simple mixer control 'Mic',0
        Mono: Capture [off]
      Simple mixer control 'IEC958',0
        Capabilities: pswitch pswitch-joined
        Playback channels: Mono
        Mono: Playback [off]
      Simple mixer control 'IEC958 Loopback',0
      Simple mixer control 'IEC958 Validity Check',0
        Mono: Capture [off]
      Simple mixer control 'Aux',0
        Mono: Capture [off]
      Simple mixer control 'ADC Filter',0
        Capabilities: cenum
        Items: 'None' 'High-pass Filter'
        Item0: 'High-pass Filter'
      Simple mixer control 'Analog Input Monitor',0
        Capabilities: pvolume pvolume-joined pswitch pswitch-joined
        Limits: Playback 0 - 1
        Mono: Playback 1 [100%] [0.00dB] [off]
      Simple mixer control 'Digital Input Monitor',0
      Simple mixer control 'Input',0
        Capabilities: cvolume
        Capture channels: Front Left - Front Right
        Limits: Capture 165 - 255
        Front Left: Capture 165 [0%]
        Front Right: Capture 165 [0%]
      Simple mixer control 'Level Control',0
        Capabilities: cenum
        Items: 'None' 'Peak Limiter' 'Automatic Level Control'
        Item0: 'None'
      Simple mixer control 'Noise Gate',0
        Mono: Capture [off]
      Simple mixer control 'Stereo Upmixing',0
        Capabilities: enum
        Items: 'Front' 'Front+Surround' 'Front+Surround+Back' 'Front+Surround+Center/L            FE' 'Front+Surround+Center/LFE+Back'
        Item0: 'Front+Surround'
      root@MusicServer:~# amixer -c 1
        Mono: Playback [on]
      Simple mixer control 'IEC958',1
        Mono: Playback [on]
      Simple mixer control 'IEC958',2
        Mono: Playback [on]
      Simple mixer control 'IEC958',3
        Mono: Playback [on]
      root@MusicServer:~# amixer -c 2
        Limits: Playback 0 - 64
        Mono: Playback 44 [69%] [-20.00dB] [on]
        Mono:
        Front Left: Playback 64 [100%] [0.00dB] [on]
        Front Right: Playback 64 [100%] [0.00dB] [on]
      Simple mixer control 'Front',0
        Mono:
        Limits: Playback 0 - 31
        Mono:
        Front Left: Playback 0 [0%] [-34.50dB] [off]
        Front Right: Playback 0 [0%] [-34.50dB] [off]
      Simple mixer control 'Front Mic Boost',0
        Capabilities: volume
        Limits: 0 - 3
        Front Left: 0 [0%] [0.00dB]
        Front Right: 0 [0%] [0.00dB]
      Simple mixer control 'Surround',0
        Mono:
      Simple mixer control 'Center',0
        Mono: Playback 64 [100%] [0.00dB] [on]
      Simple mixer control 'LFE',0
      Simple mixer control 'Side',0
        Mono:
        Mono:
      Simple mixer control 'Line Boost',0
        Limits: 0 - 3
      Simple mixer control 'IEC958 Default PCM',0
        Mono: Playback [on]
      Simple mixer control 'Capture',0
        Capabilities: cvolume cswitch
        Limits: Capture 0 - 46
        Front Left: Capture 28 [61%] [12.00dB] [on]
        Front Right: Capture 28 [61%] [12.00dB] [on]
      Simple mixer control 'Capture',1
        Front Left: Capture 0 [0%] [-16.00dB] [off]
        Front Right: Capture 0 [0%] [-16.00dB] [off]
      Simple mixer control 'Auto-Mute Mode',0
        Capabilities: enum
        Items: 'Disabled' 'Enabled'
        Item0: 'Enabled'
      Simple mixer control 'Input Source',0
        Capabilities: cenum
        Items: 'Front Mic' 'Rear Mic' 'Line'
        Item0: 'Front Mic'
      Simple mixer control 'Input Source',1
        Capabilities: cenum
        Item0: 'Front Mic'
      Simple mixer control 'Loopback Mixing',0
        Capabilities: enum
        Item0: 'Disabled'
      Simple mixer control 'Rear Mic',0
        Mono:
      Simple mixer control 'Rear Mic Boost',0
        Limits: 0 - 3
      root@MusicServer:~#
      Zuletzt geändert von hismastersvoice; 08.01.2023, 12:01.
    • digi77
      digi77 kommentierte
      screen shot of Soundcard Settings (WebUI) attached below main message
      Zuletzt geändert von digi77; 08.01.2023, 11:52.
    • 7664
    #137
    Zitat von digi77
    More playing - Swapped back to Loxone HDD and all works fine Trigger card only starts amp when music started. On MS4Home Sdd as soon as I see dietpi code on plugged in monitor the amp is fired up and stays on a longs as the server is active.
    Can you send me please the Terminal output of...
    sensors-detect --auto
    Thanks.
      Thanks again...
      Maybe I change the additional setting in "Amp all" and activate directly after install the card. Have to think about.
      Will check why the PowerButton don't work.
      Found the issue please try
      apt -y install acpi acpi-support
      After that the PowerButton should work like expected.
      If it work also for you I will pack it into install and update-script
    • digi77
      digi77 kommentierte
      Thanks fixed now
  • digi77
    • 24.09.2019
    • 38
    #138
    Could'nt work out how to add photo in comments see attached screen shot
    Music server had been off a little while and started up quiet again, this is as per nothing touched.
    Zuletzt geändert von digi77; 08.01.2023, 11:51.
    • digi77
      digi77 kommentierte
      Did it again after 2hr off
      Ran your command and it goes to 100%
      Interesting, Alsa stores the Volume Values normally.
      Also what I don't understand is that it only loos the values for the Motherboard Soundcard and not for the Xonar.
      Will investigate.
      One additional question... Is still 100% in the WebUI fot the MD-Soundcard, or is there 69% ?
    • digi77
      digi77 kommentierte
      Both WebUI cards are set to 100%
    • 7664
    #139
    digi77
    If think the best option is to write additional the values to a file and set it every boot of the system.
    The failure is only after a reboot, during the uptime there is no change in volume by them self, right?
    • digi77
      digi77 kommentierte
      Thanks update applied will run for a few days see how it goes
    • digi77
      digi77 kommentierte
      Not had the low volume problem since the update think its fixed now, Thanks
      Thanks for feedback.
    • 18.09.2015
    • 2677
    #140
    Sorry for my late response, have had several things to do on the weekend...
    How can I help now?
    When I start any zone via app or via T5 touch the zone starts very quiet.
    I have set the volumes to 90% (as suggested in the manual)
Ansichten: 508
Größe: 141,1 KB
    -have set the volume setting for each zone to 100%
    -"activate Channel-Volume"
Ansichten: 438
Größe: 133,5 KB
    When I now start playing music e.g. via T5 or via app it should get the volume settings from the MSG (if I am not wring) or if not, than it should start with the 100% pre-setting.
    In the loxconfig the start up volume "Vd" is set to 25 so it should be not too quite.
    with the original MuS it was much louder... now it is so quite, that you nearly do not hear that music is switched on.
    output from amixer:
    in next post
      simon_hh kommentierte
      Super...
      Es ist nicht so laut, wie beim originalen MuS (was eigentlich nicht sein kann), aber wesentlich besser... passe dem Wert Vd an und gut!
      Danke dir Dieter.
      Eigentlich kann es nicht sein, 100% sind bei Ubuntu und Debian Alsa 100%
      Ist nur die interne Soundkarte leiser oder beide?
      muss ich Ende der Woche nochmal schauen
    • 18.09.2015
    • 2677
    #141
    root@Musicserver:~# amixer -c 0
      Mono:
      Front Left: Playback 243 [90%] [-6.00dB] [on]
      Front Right: Playback 243 [90%] [-6.00dB] [on]
      Rear Left: Playback 243 [90%] [-6.00dB] [on]
      Rear Right: Playback 243 [90%] [-6.00dB] [on]
      Front Center: Playback 243 [90%] [-6.00dB] [on]
      Woofer: Playback 243 [90%] [-6.00dB] [on]
      Side Left: Playback 243 [90%] [-6.00dB] [on]
      Side Right: Playback 243 [90%] [-6.00dB] [on]
      Mono:
      Mono: Capture [off]
      Mono: Capture [on]
      Mono: Capture [off]
    root@Musicserver:~# amixer -c 1
      Mono: Playback 58 [91%] [-6.00dB] [on]
      Mono:
      Mono:
      Mono:
      Limits: 0 - 3
      Mono:
      Mono:
      Mono:
      Limits: 0 - 3
      Mono: Playback [on]
      Capabilities: cenum
      Item0: 'Front Mic'
      Capabilities: cenum
      Item0: 'Front Mic'
      Capabilities: enum
      Item0: 'Disabled'
      Mono:
      Limits: 0 - 3
    root@Musicserver:~#
