LoxBerry Plugin SqueezeLite
    Soweit ich weiß, basiert der BT-Treiber auf PulseAudio, d.h. wenn es gehen würde, müsstest du pulse als Ausgang wählen.
    Da ich mich bisher aber nur theoretisch damit befasst habe, und nicht selbst probiert, kann ich dir leider auch nicht weiterhelfen. Vielleicht hat das schon jemand anderer probiert.
    • Smotek7
      • 09.12.2017
      • 16
      #212
      Hello Christian,
      I will try to activate the GPIO in Squeezelite.
      If I enter GPIO for zone and restart in LMS I lose zone.
      What is the right process and setup?
      I do not speak German, I use a translator.
      Well thank you
        after you have enabled "Alternative binaries", you have to reboot LoxBerry.
        Then, you can enable the GPIOs.
        Is this working?
        Otherwise, I have to check that on my Pi.
        Regards, Christian
        • Smotek7
          • 09.12.2017
          • 16
          #214
          Hello,
          I tested it again.
          I have active alternatives binaries and reboot.
          If I select GPIO and save it does not work.
          But if I do reboot again, the LMS zone is lost and it does not even work from the UDP loxone.
          If the GPIO off and rebbot zone starts to work.
          I have installed version 0.4.1
          Thanks for help
            I saw in the log, that squeezelite did not start anymore with GPIO:
            Unable to determine hardware version. I see: Hardware    : BCM2835
             - expecting BCM2708 or BCM2709.
            If this is a genuine Raspberry Pi then please report this
            to projects@drogon.net. If this is not a Raspberry Pi then you
            are on your own as wiringPi is designed to support the
            Raspberry Pi ONLY.
            Prof.Mobilux meanwhile has pushed a new Squeezelite binary, and this one seems to work.
            Could you try this download: https://github.com/christianTF/LoxBe...hive/0.4.2.zip
            Install, reboot, and try again!
            Christian
            • Smotek7
              • 09.12.2017
              • 16
              #216
              0.4.2 The problem with the lost zone has been resolved.
              The second problem was with me.
              I did not use the "Speichern und neu starten" but "Speichern".
              Thank you all works
              What is the right update plugin procedure? Do not lose my settings?
                No, simply go to the Plugins page and install the new version. The settings are saved.
                • Smotek7
                  • 09.12.2017
                  • 16
                  #218
                  Maybe I did something wrong, the settings were lost.
                  I had to enter again.
                    Thanks for the info. Possibly there is a bug.
                      Hi Smotek7
                      indeed, there was a bug in backing up the config. I have fixed it and updated the archive. As nothing else changed, you don't need to update again.
                      Regards, Christian
                      • Smotek7
                        • 09.12.2017
                        • 16
                        #221
                        I did update again and the data was not deleted.
                        It is OK.
                        Thank you
                        • paddler
                          • 01.01.2018
                          • 5
                          #222
                          Guten Abend,
                          ich versuche mit dem Squezzelite Plugin eine sinnvolle Verbindung zwischen meinem Miniserver und meinem Squeezeboxen herzustellen.
                          Mittlerweile habe ich die das Plugin soweit am Laufen, bekomme bei "Eingänge und Ausgänge" aber leider ein " Fehler 500 :-( Internal Server Error"
                          Apache Error Logfiles sind leer. Verwende die 0.4.2.
                          Jemand einen Tipp?
                          Danke und Gruß
                          Patrick
                            Hallo Patrick,
                            das Apache Log liegt unter /opt/loxberry/system/apache2/error.log
                            Bist du auf einem Raspberry?
                            • paddler
                              • 01.01.2018
                              • 5
                              #224
                              Hi Christian,
                              ok, ich hatte im System Logs Verzeichnis gesucht.
                              Unter /opt/loxberry/system/apache2/ gibt es leider kein error.log (siehe Screen).
                              Ich bin auf Eurem Hyper-V Image unterwegs. Loxberry hat 0.2.3.
                              Danke für Deine Hilfe!
                              Patrick
                              • paddler
                                paddler kommentierte
                                Ich lese gerade Eure Neujahres Grüße.
                                Macht es für mich Sinn, einfach auf eine große neue Version von LoxBerry zu warten?
                              Sorry,
                              /opt/loxberry/logs/system/apache2/error.log
                              Schau mal dort - das Plugin selbst ändert sich durch den neuen LB ja nicht.
                              Es kann auch ein Image-Problem mit HyperV sein.
