HowTo: Logitech Media Server / Squeezebox Player mit Loxone steuern
  • J V
    • 385
    #121
    Small question... Suppose you have an album playing, and you want to select a different album. Using the remote control you would use the arrows, and when you have the album you want, you press play.
    I set a media controller with the cursor and other buttons, but the command "play" behaves differently: it does not start the selected album but "unpauses" the playing one if it was paused. Which command do you use to select the new album?
      iPeng ;-)
      • J V
        • 385
        #123
        I use the Logitech app, but having everything centralized in the Loxone app is just nicer. It is strange that the Squeezebox command "play" is not the same as the play button. I tried also to emulate the button press (using the command "button play") and the command "enter", but neither allows me to start the new album. For sure there must be some command that allows for it...
          Usually, with the CLI or within an App, you would search the album and send a "playlist play"-Command to insert the album to the playlist and start playing.
          The button-Commands emulate the navigation with an original Squeezebox.
          The problem is, that Loxone cannot communicate in an bidirectional way with the server.
          In an App, the App requests the album list with it's ID's, so an App knows, 'now I play ID 89', and if you press some album-change-button in the App, it sends 'now play ID 90'.
          As within Loxone you cannot bidirectionally interact, Loxone never knows that it's playing ID 89, so it cannot send the request for ID 90.
          The command to add an album to the playlist using an index is
          playlistcontrol cmd:load album_id:90
          Regards, Christian
          • J V
            • 385
            #125
            I found it! On this thread, they had the same question: http://forums.slimdevices.com/archiv...p/t-28579.html
            The solution is to send the IR code for the play button via CLI, so basically the command
            ir 768910ef 11073.575 \n
            I can confirm that it works. :-)
            • K.Clemens
              • 92
              #126
              I was wondering if somebody already starts automaticaly a playlist when for instance the front door is openend between certain hours?
              What I'm searching for is a command to start playing "playlist Cynthia", but always start at a different song, so shuffle the first song.
              Any ideas?
                This would be two commands, shuffle 1 and playlist play.
                • K.Clemens
                  K.Clemens kommentierte
                  Thanks for the fast reply. But if you shuffle, aren't you shuffling the entire list? Also shuffling 1, would that not only change the first song of the list?
                  I was thinking about starting somewhere in the list and continue playing the list.
                With shuffle on, it will jump around in the ordered playlist. So when you disable shuffling with a third command, it will continue in your defined order.
                • K.Clemens
                  • 92
                  #129
                  Thanks for the info. Will try it soon.
                    Hallo @all!
                    Da ich mitten in der Hausplanung bin und ich mich im Moment vorallem mit der Haussteuerung beschäftige, würde mich nun sehr interessieren, ob es mittlerweile schon möglich ist, einen Logitech Music Server anstelle des original Loxone Music Server voll zu integrieren.
                    Die Anbindung des Multiroom-Systems an Loxone wäre mir wichtig für:
                    -Visualisierung in nur einer App
                    -Hausklingel über Musikserver
                    -Sirene bei Alarm
                    Der originale Server ist mit fast 1400€ schon sehr teuer und ich brauche den Musikserver rein für die Zonen und als "Anbindung" an Loxone. Die Musikdateien habe ich sowieso auf einem Synology-NAS.
                    Viele Dank in Voraus und LG :-)
                      • 7665
                      #131
                      Wenn du die Loxone Visu unbedingt willst/brauchst führt kein Weg am Loxone Server vorbei.
                      für alles andere schau dir MusicServer4Lox hier im Forum an.
                        Hallo Leute,
                        nach dem erfolgten Update auf die Version 8.3 verweigern meine Squeeze´s die Zusammenarbeit mit dem Miniserver! Kein "ON" oder "OFF" - kein "play" nichts wird mehr akzeptiert...........
                        Woran könnte das liegen? Und...........bin ich der einzige mit diesem Problem?????
                        Thomas
                        • roadi
                          roadi kommentierte
                          Bei mir wird noch alles angezeigt
                        • 7665
                        #133
                        Dazu solltest mal deine Config zeigen, bei mir geht alles noch.
                        • ezi
                          • 15.10.2015
                          • 74
                          #134
                          bei mir gehts seit 8.1.11.11 nicht mehr
                          wollte auch schon mal hier posten, aber hatte noch keine Zeit um mir die Details anzusehen
                          edit:
                          screenshot der Config eingefügt.
                          Zuletzt geändert von ezi; 28.03.2017, 18:41.
                            Auch hier... postet mal Eure Config dafür.
                          Kann's sein, dass das Update das Leerzeichen nach der MAC-Adresse weggetrimmt hat?
