LoxBerry V3.0.0.0 RELEASE
  • MikeSeeH
    • 04.04.2021
    • 25
    #31
    Auch von mir ein großes Danke für die tolle Arbeit an v3! Ich bin gerade dabei eine frische Installation auf einem Raspberry Pi 4 Model B 2GB zu machen und erhalten immer den folgenden Fehler:
    [FAILED ] .... Could not set up PHP 7.4.
    Die Lösung war PHP manuell zu installieren (apt-get install php) und dann nochmals die Installation zu starten.
    • challo
      challo kommentierte
      Hatte auch diesen Fehler mit dietpi / proxmox.
      Danke für dann Tip, hast du danach dann das loxberry Setup nochmal laufen lassen?
    • MikeSeeH
      MikeSeeH kommentierte
      Genau. Danach den Shell Befehl für die Loxberry Installation nochmal ausführen. Bis jetzt klappt alles.
      Danke Euch - ist im Installerskript ergänzt.
  • TomekWaw
    • 25.07.2019
    • 444
    #32
    Hi, I've tried to upgrade 2.2.2.2 to 3.0.0.0 but first I was asked to make a backup with a new backup widget to make the boot sector larger.
    I was lot to optimistic that would it go smoothly (thats an image backup, right) and after creating an .img file, I burned it with BalenaEtcher to my current microSD card (on MacOS if this is relevant here). Unfortunately, RPI4 won't boot with it. I've tried several times burning in the image.
    I can't check why it doesn't boot as in this location I don't have any monitor to connect RPI to.
    Thankfully I have the old raspbi-based loxberry-backup-plugin backups of my LoxBerry, but with the tools I have here and format I was doing the backups with (tgz), it's not easy to restore it also.
    So I wonder: is there any way to "fix" new backup widget image or any other way to make it work?
    Zuletzt geändert von TomekWaw; 13.03.2023, 12:45.
    • TomekWaw
      TomekWaw kommentierte
      Never mind, I made a fresh install in dietPi
  • TomekWaw
    • 25.07.2019
    • 444
    #33
    But I have another problem, my SSD backup storage is not visible in USB Storages widget, despite is it mounted in the filesystem:
    root@loxberry:~# mount |grep usb
    /dev/sda1 on /media/usb/usb-backup type ext4 (rw,nosuid,nodev,noexec,relatime,stripe=8191)
    root@loxberry:~# ls -al /media/usb/usb-backup/
    total 40
    drwxr-xr-x 7 loxberry loxberry 4096 Mar 13 00:24 .
    drwxr-xr-x 3 root root 4096 Mar 13 14:35 ..
    drwxr-xr-x 22 loxberry loxberry 4096 Mar 12 15:30 001_Loxone
    drwxr-xr-x 2 loxberry loxberry 4096 Mar 12 17:18 Widget-Backup
    drwxr-xr-x 2 loxberry loxberry 4096 Mar 12 00:30 iobroker
    drwx------ 2 root root 16384 Mar 23 2022 lost+found
    drwxr-xr-x 16 root root 4096 Mar 12 01:30 loxberry
    I attach debuglog​
      Can you please connect the LoxBerry via Remote Support Widget and send me a PM with the URL and your WebUI, SSH and Root Passwords. I will then have a look.
      You are not the only one with a problem with the USB Widget, so we may have a bug there.
    • TomekWaw
      Done!
    • 4910
    #34
    TomekWaw Thanks for your support. We have a problem with the Symlink from /opt/loxberry/system/usb to /media/usb. Don't know why this happens sometimes. But it was not a symlink but a regular file, which does not work....
    I fixed it in your installation and will try to figure out why this sometimes happens with GIT.
    • TomekWaw
      Thank you very much! And thank you for the amazing work you do all to LoxBerry Project!
  • RiverRaid
    • 320
    #35
    Hi an Alle!
    Erstmals Danke für eure Arbeit und den Loxberry :-)
    - Ich habe mich auch an das Upgrade gewagt, allerdings hängt er in einer schleife... Deshalb werde ich mal auf das Backup zurück gehen und vielleicht in 2-3 tagen eine frische Installation wagen.
    Folgende Einträge im Log:
    <LOGSTART> 13.03.2023 23:00:44 TASK STARTED
    <LOGSTART> Update Reboot script /opt/loxberry/sbin/loxberryupdate/updatereboot_v3.0.0.pl started.
    <INFO> LoxBerry Version 3.0.0.1 ( is_arch_armv7l.cfg is_raspberry.cfg )
    <INFO> Loglevel: 7
    <INFO> Message : Doing system upgrade (envoked from upgrade to V3.0.0)
    <INFO> This script already started 6 times.
    <INFO> Try to reach loxberry.de
    <OK> loxberry.de is reachable, so network seems to be up.
    <INFO> Stopping Apache2...
    <INFO> Stopping unattended-upgrades...
    <INFO> Stopping rpimonitor...
    <INFO> Starting simple update webserver...
    <OK> Started simple webserver successfully.
    <INFO> Change owner of /var/log to root:root...
    <INFO> Change permissions of /tmp to 1777...
    <INFO> (Re-)Set current date/time to make sure communication with apt-servers will be ok - seems to be a problem on VMs sometimes...
    <INFO> Checking Boot Partition...
    <INFO> Executing command 'findmnt /boot -b -J'...
    <OK> Command executed successfully. - Exitcode 0
       "filesystems": [
          {"target":"/boot", "source":"/dev/mmcblk0p1", "fstype":"vfat", "options":"rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro"}
    <OK> Apt packages autoremoved successfully.
    Get:1 https://repos.influxdata.com/debian bullseye InRelease [7,031 B]
    Get:2 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
    Hit:3 https://download.docker.com/linux/raspbian bullseye InRelease
    Get:4 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
    Hit:5 https://deb.nodesource.com/node_12.x bullseye InRelease
    Hit:6 https://dist-mirror.fem.tu-ilmenau.de/raspbian/raspbian bullseye InRelease
    Err:1 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Err:4 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    Reading package lists...
    W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    <ERROR> Error updating apt database - Error 100
    <INFO> Updating YARN key...
    <INFO> Updating NodeJS key...
    <INFO> Changing Rasbian mirror to http://packages.hs-regensburg.de/raspbian/
    Hit:1 https://download.docker.com/linux/raspbian bullseye InRelease
    Get:2 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
    Get:3 https://repos.influxdata.com/debian bullseye InRelease [7,031 B]
    Hit:4 http://packages.hs-regensburg.de/raspbian bullseye InRelease
    Get:6 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
    Err:2 https://packages.grafana.com/oss/deb stable InRelease
    Err:3 https://repos.influxdata.com/debian bullseye InRelease
    <INFO> Changing Rasbian mirror to http://ftp.halifax.rwth-aachen.de/raspbian/raspbian/
    <ERROR> Error updating apt database. All servers give an error. Internet connection available? Giving up.
    <OK> Apt cache cleaned successfully.
    <INFO> Update apt sources from buster to bullseye...
    <INFO> Cleaning up and updating apt databases...
    <INFO> No process is locking apt or dpkg. Fine.
    <INFO> Starting dpkg --configure...
    <OK> Configuring dpkg successfully.​
      • 4910
      #36
      Stats4Lox updaten - er hängt am Grafana Repo. Das muss aktualisiert werden.
      • RiverRaid
        RiverRaid kommentierte
        Ah, ok, sorry, mein Fehler:/ dann probiere ich das heute gleich nach der Arbeit
        Backup nicht vergessen ;-)
    • Ritterlanzelot
      • 15.08.2016
      • 10
      #37
      Morgen zusammen!
      Ich weiß nicht ob ich der Einzige bin, der dieses Problem (noch) hat, oder ob ich (nur) zu dumm bin es zu lösen:
      MQTT Gateway running (PID 896). Current status: MQTT Server state: No connection to MQTT Server localhost - Check host/port/user/pass and your connection.. Config state: Configfile present. UDP-IN state: UDP-IN socket connected. Could not connect to your configured MQTT Server.
      ==> MQTT Server kann nicht erreicht werden. Die Daten im MQTT-Setting stehen alle auf AUTO und sind 1 zu 1 dieselben wie vorher bei Version 2.2.2.2. Von den Gateway Settings Screenshot im Anhang . der Mosquitto ist "not running". Ich meine mich zu erinnern, dass dies mal ein Bug war, der gefixt wurde. Habe den Loxberry nun vom Backup aus nochmals neu auf 3.0.0.1 hoch, aber der Bug ist noch immer da.
      Kann mir vielleicht jemand einen Lösungsansatz geben?
      Vielen Dank & VG Johannes
        • 11245
        #38
        Servus Johannes,
        wenn du nochmal speicherst und Restart machst, ändert das wahrscheinlich auch nichts?
        • Ritterlanzelot
          Ritterlanzelot kommentierte
          Nein, mehrfach versucht - leider nicht!
        • 6337
        #39
        Der Mosquitto läuft nicht!
        Meine Vermutung ist, dass auch hier wegen Änderungen an der Mosquitto.conf diese durch das Update nicht ersetzt wurde und nun der Mosquitto mit der alten Config nicht mehr startet. Wir brauchen Logfiles etc. pp
        • lugg8
          lugg8 kommentierte
          habe das gleiche Problem festgestellt.
          Du könntest folgendes probieren: Backup 2.2.2.2 wieder einspielen. Das Gateway Plugin lässt Du installiert. Auf der Konsole deinstallierst Du Mosquitto: sudo apt-get purge mosquitto. Dann MQTT Plugin als Upgrade über das bestehende Plugin drüber installieren. Deine Einstellungen bleiben dann alle erhalten, Mosquitto wird dabei wieder frisch installiert. Dann Upgrade auf LoxBerry 3.x
        • lugg8
          lugg8 kommentierte
          Ich habe es wie o.g. Durchgeführt. Leider ist mosquitto immer noch nicht. „Not Running“.
          Was kann ich euch senden um bei der Fehlersuche zu unterstützen?
      • pumuckl
        • 11.03.2017
        • 80
        #40
        Ich habe ein Pi4 mit Dietpi und Loxberry neu installiert.
        Ging recht schnell und einfach.
        Danke dafür
        Seit dem Einrichten vom Mailer bekomme ich ständig diese Mails:
        zentral : Mar 14 08:57:43 : loxberry : problem with defaults entries ; PWD=/opt/loxberry/webfrontend/htmlauth/system/ajax ; USER=root ;​
        zentral : Mar 14 08:57:45 : root : unable to resolve host zentral: Name or service not known
        Den Hostnamen habe ich geändert,
        zu beiden Meldungen findet die sufu ich nur alte Geschichten.
          Bitte im Remote Widget die Verbindung starten und mir dann per PM die URL und Deine Passwörter (WebUI, SSH, Root) mitteilen. Ich muss drauf schauen.
        • 4910
        #41
        pumuckl Bitte mal das Update auf 3.0.0.2 einspielen. Dann den Hostnamen noch einmal neu setzen, damit er neu abgespeichert wird. Dann sollte es passen.
        • pumuckl
          pumuckl kommentierte
          Vielen Dank Prof.Mobilux,. Die Mails kommen nun nicht mehr.
      • scharrin
        • 328
        #42
        ich habe den LoxBerry 3.0.0.1 komplett neu installiert.
        Heute wollte ich das Update auf 3.0.0.2 installieren.
        Dies ist mit dem Fehler abgebrochen, dass zu wenig Speicher in / verfügbar ist.
        Ich habe daraufhin ein SD-Karten-Backup gemacht und neu geflachst (wie empfohlen).
        Trotzdem ist jetzt - auch nach mehreren Neustarts - das / Filesystem zu 100% voll.
        Wie kann ich das / filesystem vergrößern?
        Klicke auf die Grafik für eine vergrößerte Ansicht  Name: Bildschirm­foto 2023-03-15 um 19.49.30.png Ansichten: 0 Größe: 158,1 KB ID: 382948
Name: Bildschirm­foto 2023-03-15 um 19.51.19.png
Ansichten: 631
Größe: 143,0 KB
        Viele Grüße,
        Christian
          • 4910
          #43
          scharrin Per Putty einloggen und zu root werden. Dann folgenden Befehl eingeben:
          systemctl enable dietpi-fs_partition_resize
          reboot
          Hi, I installed DietPi on a 4GB SD card, set up everything, working fine. I made an image from the installed system than copied to a 16GB SD card. I know that the first step of the installation is that the installer expand the root file system to the maximum size of SD card but how can I do this after the migration? In raspbian config there is a setup of this but in dietpi config I haven’t seen. Is there any method to do this after the installation? Thanks! Regards, nemeth9
            • 18.09.2015
            • 2659
            #44
            im stats4Lox Plugin funktioniert bei mir anscheinend das Mouseover seit geraumer Zeit nicht mehr.
            Ich kann die Seite
            IP/admin/plugins/stats4lox/mqttlive_loxone.cgi
            nur per manueller Eingabe im Browser aufrufen.
            Ich finde sonst keinen Link, keine andere Möglichkeit auf MQTT Live zuzugreifen.
            Mouseover auf der linken Seite für das Standard Menü funktioniert ganz normal.
            Oder habe ich etwas verpasst und die MQTT Seiten sind nun woanders?
            Klicke auf die Grafik für eine vergrößerte Ansicht  Name: stats4lox_kein MQTT.png Ansichten: 0 Größe: 97,0 KB ID: 383020
            ich bin der Meinung, dass sich da ein Menü beim Überfahren von "Loxone and Import" aufklappte... oder?
              • 11245
              #45
              Ich hab das Submenü am 3. Jänner gefixt
              Das ist lt. Git drin in 0.9.10 und 0.9.10.1
