Plugin: LoxBerry Backup
  • michael287
    • 369
    #91
    Hier noch das LOG-File der Netashares.cgi (ohne Passwörter)
    <LOGSTART> 15.11.2018 18:16:18 TASK STARTED
    <LOGSTART> netshares.cgi - debugging starts
    <INFO> LoxBerry Version 1.2.5.4 ( is_raspberry.cfg )
    <INFO> Loglevel: 7
    <ALERT> WARNING! THIS LOGFILE WILL CONTAIN YOUR NETSHARE CREDENTIALS!
    <INFO> Output of 'cat /etc/fstab':
    proc /proc proc defaults,nofail 0 0
    PARTUUID=4bd27daf-01 /boot vfat defaults,nofail 0 2
    PARTUUID=4bd27daf-02 / ext4 defaults,noatime,nofail 0 1
    #tmpfs /var/log tmpfs nodev,nosuid,size=50M,mode=755,uid=1,gid=1,nofail 0 0
    #tmpfs /var/tmp tmpfs nodev,nosuid,size=25M,nofail 0 0
    #tmpfs /tmp tmpfs nodev,nosuid,size=200M,nofail 0 0
    #tmpfs /opt/loxberry/log/plugins tmpfs nodev,nosuid,size=25M,mode=755,uid=1001,gid=1001,nofail 0 0
    #tmpfs /opt/loxberry/log/system_tmpfs tmpfs nodev,nosuid,size=25M,mode=755,uid=1001,gid=1001,nofail 0 0
    ,nofail   ,nofail
    10.1.1.10:/volume1/backup/loxberry /backup/loxberry nfs auto,uid=1032,gid=100,rsize=32768,wsize=32768,tcp,intr,nofail 0 0
    # a swapfile is not a swap partition, no line here
    #   use  dphys-swapfile swap[on|off]  for that
    <INFO> Output of 'mount':
    /dev/mmcblk0p2 on / type ext4 (rw,noatime,data=ordered)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=470116k,nr_inodes=117529,mode=755)
    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    proc on /proc type proc (rw,relatime)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
    tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
    cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
    cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
    cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
    cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
    cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
    cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
    cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
    mqueue on /dev/mqueue type mqueue (rw,relatime)
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
    debugfs on /sys/kernel/debug type debugfs (rw,relatime)
    configfs on /sys/kernel/config type configfs (rw,relatime)
    tmpfs on /var/log type tmpfs (rw,nosuid,nodev)
    tmpfs on /tmp type tmpfs (rw,nosuid,nodev)
    tmpfs on /var/tmp type tmpfs (rw,nosuid,nodev)
    tmpfs on /opt/loxberry/log/plugins type tmpfs (rw,nosuid,nodev)
    tmpfs on /opt/loxberry/log/system_tmpfs type tmpfs (rw,nosuid,nodev)
    /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
    /etc/auto.smb on /media/smb/10.1.1.10/backup type autofs (rw,relatime,fd=6,pgrp=18914,timeout=300,minproto=5,maxproto=5,offset)
    <INFO> Output of 'ls -l /etc/creds':
    lrwxrwxrwx 1 root root 38 Aug 20 08:38 /etc/creds -> /opt/loxberry/system/samba/credentials
    <INFO> Output of 'ls -l /opt/loxberry/system/samba/credentials':
    total 4
    -rw-r--r-- 1 loxberry loxberry 56 Nov 15 18:16 10.1.1.10
    <OK> Server: 10.1.1.10
    <INFO> Type: smb
    <INFO> PATH: /opt/loxberry/system/storage/smb/10.1.1.10
    <INFO> Output of 'cat /opt/loxberry/system/samba/credentials/10.1.1.10':
    uid=1001
    gid=1001
    username=loxberry
    password=
    <INFO> Output of '/etc/auto.smb 10.1.1.10'
    -fstype=cifs,file_mode=0664,dir_mode=0775,uid=$UID,gid=$GID,credentials=/etc/creds/10.1.1.10 \
         "/backup" "://10.1.1.10/backup" \
    <INFO> Output of 'smbclient -A /opt/loxberry/system/samba/credentials/10.1.1.10 -gL 10.1.1.10 --debuglevel=10':
    INFO: Current debug levels:
      all: 10
      tdb: 10
      printdrivers: 10
      lanman: 10
      smb: 10
      rpc_parse: 10
      rpc_srv: 10
      rpc_cli: 10
      passdb: 10
      sam: 10
      auth: 10
      winbind: 10
      vfs: 10
      idmap: 10
      quota: 10
      acls: 10
      locking: 10
      msdfs: 10
      dmapi: 10
      registry: 10
      scavenger: 10
      dns: 10
      ldb: 10
      tevent: 10
    lp_load_ex: refreshing parameters
    Initialising global parameters
    rlimit_max: increasing rlimit_max (8192) to minimum Windows limit (16384)
      all: 10
      tdb: 10
      printdrivers: 10
      lanman: 10
      smb: 10
      rpc_parse: 10
      rpc_srv: 10
      rpc_cli: 10
      passdb: 10
      sam: 10
      auth: 10
      winbind: 10
      vfs: 10
      idmap: 10
      quota: 10
      acls: 10
      locking: 10
      msdfs: 10
      dmapi: 10
      registry: 10
      scavenger: 10
      dns: 10
      ldb: 10
      tevent: 10
    Processing section "[global]"
    doing parameter workgroup = WORKGROUP
    doing parameter dns proxy = no
    doing parameter allow insecure wide links = yes
    doing parameter client max protocol = SMB3
    doing parameter log file = /var/log/samba/log.%m
    doing parameter max log size = 1000
    doing parameter panic action = /usr/share/samba/panic-action %d
    doing parameter server role = standalone server
    doing parameter passdb backend = tdbsam
    doing parameter obey pam restrictions = yes
    doing parameter unix password sync = no
    doing parameter passwd program = /usr/bin/passwd %u
    doing parameter passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
    doing parameter pam password change = yes
    doing parameter map to guest = bad user
    doing parameter usershare allow guests = no
    pm_process() returned Yes
    lp_servicenumber: couldn't find homes
    added interface wlan0 ip=10.1.1.107 bcast=10.1.1.255 netmask=255.255.255.0
    Netbios name list:-
    my_netbios_names[0]="LOXBERRY"
    Client started (version 4.5.12-Debian).
    Connecting to 10.1.1.10 at port 445
    Socket options:
        SO_KEEPALIVE = 0
        SO_REUSEADDR = 0
        SO_BROADCAST = 0
        TCP_NODELAY = 1
        TCP_KEEPCNT = 9
        TCP_KEEPIDLE = 7200
        TCP_KEEPINTVL = 75
        IPTOS_LOWDELAY = 0
        IPTOS_THROUGHPUT = 0
        SO_REUSEPORT = 0
        SO_SNDBUF = 44800
        SO_RCVBUF = 341760
        SO_SNDLOWAT = 1
        SO_RCVLOWAT = 1
        SO_SNDTIMEO = 0
        SO_RCVTIMEO = 0
        TCP_QUICKACK = 1
        TCP_DEFER_ACCEPT = 0
     session request ok
    Doing spnego session setup (blob length=74)
    got OID=1.3.6.1.4.1.311.2.2.10
    got principal=not_defined_in_RFC4178@please_ignore
    GENSEC backend 'gssapi_spnego' registered
    GENSEC backend 'gssapi_krb5' registered
    GENSEC backend 'gssapi_krb5_sasl' registered
    GENSEC backend 'spnego' registered
    GENSEC backend 'schannel' registered
    GENSEC backend 'naclrpc_as_system' registered
    GENSEC backend 'sasl-EXTERNAL' registered
    GENSEC backend 'ntlmssp' registered
    GENSEC backend 'ntlmssp_resume_ccache' registered
    GENSEC backend 'http_basic' registered
    GENSEC backend 'http_ntlm' registered
    GENSEC backend 'krb5' registered
    GENSEC backend 'fake_gssapi_krb5' registered
    Starting GENSEC mechanism spnego
    Starting GENSEC submechanism ntlmssp
         negotiate: struct NEGOTIATE_MESSAGE
            Signature                : 'NTLMSSP'
            MessageType              : NtLmNegotiate (1)
            NegotiateFlags           : 0x62088215 (1644724757)
                   1: NTLMSSP_NEGOTIATE_UNICODE
                   0: NTLMSSP_NEGOTIATE_OEM
                   1: NTLMSSP_REQUEST_TARGET
                   1: NTLMSSP_NEGOTIATE_SIGN
                   0: NTLMSSP_NEGOTIATE_SEAL
                   0: NTLMSSP_NEGOTIATE_DATAGRAM
                   0: NTLMSSP_NEGOTIATE_LM_KEY
                   0: NTLMSSP_NEGOTIATE_NETWARE
                   1: NTLMSSP_NEGOTIATE_NTLM
                   0: NTLMSSP_NEGOTIATE_NT_ONLY
                   0: NTLMSSP_ANONYMOUS
                   0: NTLMSSP_NEGOTIATE_OEM_DOMAIN_SUPPLIED
                   0: NTLMSSP_NEGOTIATE_OEM_WORKSTATION_SUPPLIED
                   0: NTLMSSP_NEGOTIATE_THIS_IS_LOCAL_CALL
                   1: NTLMSSP_NEGOTIATE_ALWAYS_SIGN
                   0: NTLMSSP_TARGET_TYPE_DOMAIN
                   0: NTLMSSP_TARGET_TYPE_SERVER
                   0: NTLMSSP_TARGET_TYPE_SHARE
                   1: NTLMSSP_NEGOTIATE_EXTENDED_SESSIONSECURITY
                   0: NTLMSSP_NEGOTIATE_IDENTIFY
                   0: NTLMSSP_REQUEST_NON_NT_SESSION_KEY
                   0: NTLMSSP_NEGOTIATE_TARGET_INFO
                   1: NTLMSSP_NEGOTIATE_VERSION
                   1: NTLMSSP_NEGOTIATE_128
                   1: NTLMSSP_NEGOTIATE_KEY_EXCH
                   0: NTLMSSP_NEGOTIATE_56
            DomainNameLen            : 0x0000 (0)
            DomainNameMaxLen         : 0x0000 (0)
            DomainName               : *
                DomainName               : ''
            WorkstationLen           : 0x0000 (0)
            WorkstationMaxLen        : 0x0000 (0)
            Workstation              : *
                Workstation              : ''
            Version: struct ntlmssp_VERSION
                ProductMajorVersion      : NTLMSSP_WINDOWS_MAJOR_VERSION_6 (6)
                ProductMinorVersion      : NTLMSSP_WINDOWS_MINOR_VERSION_1 (1)
                ProductBuild             : 0x0000 (0)
                Reserved: ARRAY(3)
                    [0]                      : 0x00 (0)
                    [1]                      : 0x00 (0)
                    [2]                      : 0x00 (0)
                NTLMRevisionCurrent      : NTLMSSP_REVISION_W2K3 (15)
    Got challenge flags:
    Got NTLMSSP neg_flags=0x628a8215
    short string '', sent with NULL termination despite NOTERM flag in IDL
    NTLMSSP: Set final flags:
    Got NTLMSSP neg_flags=0x62088215
    NTLMSSP Sign/Seal - Initialising with flags:
    ntlmssp_check_packet: NTLMSSP signature OK !
    Domain=[DS713PLUS] OS=[] Server=[]
     session setup ok
    signed SMB2 message
    signed SMB2 message
     tconx ok
    Bind RPC Pipe: host 10.1.1.10 auth_type 0, auth_level 1
         &r: struct ncacn_packet
            rpc_vers                 : 0x05 (5)
            rpc_vers_minor           : 0x00 (0)
            ptype                    : DCERPC_PKT_BIND (11)
            pfc_flags                : 0x03 (3)
                   1: DCERPC_PFC_FLAG_FIRST
                   1: DCERPC_PFC_FLAG_LAST
                   0: DCERPC_PFC_FLAG_PENDING_CANCEL_OR_HDR_SIGNING
                   0: DCERPC_PFC_FLAG_CONC_MPX
                   0: DCERPC_PFC_FLAG_DID_NOT_EXECUTE
                   0: DCERPC_PFC_FLAG_MAYBE
                   0: DCERPC_PFC_FLAG_OBJECT_UUID
            drep: ARRAY(4)
                [0]                      : 0x10 (16)
                [1]                      : 0x00 (0)
                [2]                      : 0x00 (0)
                [3]                      : 0x00 (0)
            frag_length              : 0x0048 (72)
            auth_length              : 0x0000 (0)
            call_id                  : 0x00000001 (1)
            u                        : union dcerpc_payload(case 11)
            bind: struct dcerpc_bind
                max_xmit_frag            : 0x10b8 (4280)
                max_recv_frag            : 0x10b8 (4280)
                assoc_group_id           : 0x00000000 (0)
                num_contexts             : 0x01 (1)
                ctx_list: ARRAY(1)
                    ctx_list: struct dcerpc_ctx_list
                        context_id               : 0x0000 (0)
                        num_transfer_syntaxes    : 0x01 (1)
                        abstract_syntax: struct ndr_syntax_id
                            uuid                     : 4b324fc8-1670-01d3-1278-5a47bf6ee188
                            if_version               : 0x00000003 (3)
                        transfer_syntaxes: ARRAY(1)
                            transfer_syntaxes: struct ndr_syntax_id
                                uuid                     : 8a885d04-1ceb-11c9-9fe8-08002b104860
                                if_version               : 0x00000002 (2)
                auth_info                : DATA_BLOB length=0
    rpc_api_pipe: host 10.1.1.10
    rpc_read_send: data_to_read: 52
            rpc_vers                 : 0x05 (5)
            ptype                    : DCERPC_PKT_BIND_ACK (12)
            drep: ARRAY(4)
                [0]                      : 0x10 (16)
                [1]                      : 0x00 (0)
                [2]                      : 0x00 (0)
                [3]                      : 0x00 (0)
            frag_length              : 0x0044 (68)
            u                        : union dcerpc_payload(case 12)
            bind_ack: struct dcerpc_bind_ack
                assoc_group_id           : 0x000053f0 (21488)
                secondary_address_size   : 0x000d (13)
                secondary_address        : '\PIPE\srvsvc'
                _pad1                    : DATA_BLOB length=1
    [0000] 00                                                 .
                num_results              : 0x01 (1)
                ctx_list: ARRAY(1)
                    ctx_list: struct dcerpc_ack_ctx
                        result                   : DCERPC_BIND_ACK_RESULT_ACCEPTANCE (0)
                        reason                   : union dcerpc_bind_ack_reason(case 0)
                        value                    : DCERPC_BIND_ACK_REASON_NOT_SPECIFIED (0)
    rpc_api_pipe: got frag len of 68 at offset 0: NT_STATUS_OK
    rpc_api_pipe: host 10.1.1.10 returned 68 bytes.
    check_bind_response: accepted!
    cli_rpc_pipe_open_noauth: opened pipe srvsvc to machine 10.1.1.10 and bound anonymously.
         srvsvc_NetShareEnumAll: struct srvsvc_NetShareEnumAll
            in: struct srvsvc_NetShareEnumAll
                server_unc               : *
                    server_unc               : '10.1.1.10'
                info_ctr                 : *
                    info_ctr: struct srvsvc_NetShareInfoCtr
                        level                    : 0x00000001 (1)
                        ctr                      : union srvsvc_NetShareCtr(case 1)
                        ctr1                     : *
                            ctr1: struct srvsvc_NetShareCtr1
                                count                    : 0x00000000 (0)
                                array                    : NULL
                max_buffer               : 0xffffffff (4294967295)
                resume_handle            : *
                    resume_handle            : 0x00000000 (0)
            rpc_vers                 : 0x05 (5)
            ptype                    : DCERPC_PKT_REQUEST (0)
            drep: ARRAY(4)
                [0]                      : 0x10 (16)
                [1]                      : 0x00 (0)
                [2]                      : 0x00 (0)
                [3]                      : 0x00 (0)
            frag_length              : 0x0018 (24)
            call_id                  : 0x00000002 (2)
            u                        : union dcerpc_payload(case 0)
            request: struct dcerpc_request
                alloc_hint               : 0x00000044 (68)
                opnum                    : 0x000f (15)
                object                   : union dcerpc_object(case 0)
                empty: struct dcerpc_empty
                _pad                     : DATA_BLOB length=0
                stub_and_verifier        : DATA_BLOB length=0
    rpc_read_send: data_to_read: 3560
            rpc_vers                 : 0x05 (5)
            ptype                    : DCERPC_PKT_RESPONSE (2)
            drep: ARRAY(4)
                [0]                      : 0x10 (16)
                [1]                      : 0x00 (0)
                [2]                      : 0x00 (0)
                [3]                      : 0x00 (0)
            frag_length              : 0x0df8 (3576)
            u                        : union dcerpc_payload(case 2)
            response: struct dcerpc_response
                alloc_hint               : 0x00000de0 (3552)
                cancel_count             : 0x00 (0)
                _pad                     : DATA_BLOB length=1
    [0000] 00                                                 .
                stub_and_verifier        : DATA_BLOB length=3552
    [0000] 01 00 00 00 01 00 00 00   0C 00 02 00 31 00 00 00   ........ ....1...
    [0010] 10 00 02 00 31 00 00 00   14 00 02 00 00 00 00 00   ....1... ........
    [0020] 18 00 02 00 1C 00 02 00   00 00 00 00 20 00 02 00   ........ .... ...
    [0030] 24 00 02 00 00 00 00 00   28 00 02 00 2C 00 02 00   $....... (...,...
    [0040] 00 00 00 00 30 00 02 00   34 00 02 00 00 00 00 00   ....0... 4.......
    [0050] 38 00 02 00 3C 00 02 00   00 00 00 00 40 00 02 00   8...<... ....@...
    [0060] 44 00 02 00 00 00 00 00   48 00 02 00 4C 00 02 00   D....... H...L...
    [0070] 00 00 00 00 50 00 02 00   54 00 02 00 00 00 00 00   ....P... T.......
    [0080] 58 00 02 00 5C 00 02 00   00 00 00 00 60 00 02 00   X...\... ....`...
    [0090] 64 00 02 00 00 00 00 00   68 00 02 00 6C 00 02 00   d....... h...l...
    [00A0] 00 00 00 00 70 00 02 00   74 00 02 00 00 00 00 00   ....p... t.......
    [00B0] 78 00 02 00 7C 00 02 00   00 00 00 00 80 00 02 00   x...|... ........
    [00C0] 84 00 02 00 00 00 00 00   88 00 02 00 8C 00 02 00   ........ ........
    [00D0] 00 00 00 00 90 00 02 00   94 00 02 00 00 00 00 00   ........ ........
    [00E0] 98 00 02 00 9C 00 02 00   00 00 00 00 A0 00 02 00   ........ ........
    [00F0] A4 00 02 00 00 00 00 00   A8 00 02 00 AC 00 02 00   ........ ........
    [0100] 00 00 00 00 B0 00 02 00   B4 00 02 00 00 00 00 00   ........ ........
    [0110] B8 00 02 00 BC 00 02 00   00 00 00 00 C0 00 02 00   ........ ........
    [0120] C4 00 02 00 00 00 00 00   C8 00 02 00 CC 00 02 00   ........ ........
    [0130] 00 00 00 00 D0 00 02 00   D4 00 02 00 00 00 00 00   ........ ........
    [0140] D8 00 02 00 DC 00 02 00   00 00 00 00 E0 00 02 00   ........ ........
    [0150] E4 00 02 00 00 00 00 00   E8 00 02 00 EC 00 02 00   ........ ........
    [0160] 00 00 00 00 F0 00 02 00   F4 00 02 00 00 00 00 00   ........ ........
    [0170] F8 00 02 00 FC 00 02 00   00 00 00 00 00 01 02 00   ........ ........
    [0180] 04 01 02 00 00 00 00 00   08 01 02 00 0C 01 02 00   ........ ........
    [0190] 00 00 00 00 10 01 02 00   14 01 02 00 00 00 00 00   ........ ........
    [01A0] 18 01 02 00 1C 01 02 00   00 00 00 00 20 01 02 00   ........ .... ...
    [01B0] 24 01 02 00 00 00 00 00   28 01 02 00 2C 01 02 00   $....... (...,...
    [01C0] 00 00 00 00 30 01 02 00   34 01 02 00 00 00 00 00   ....0... 4.......
    [01D0] 38 01 02 00 3C 01 02 00   00 00 00 00 40 01 02 00   8...<... ....@...
    [01E0] 44 01 02 00 00 00 00 00   48 01 02 00 4C 01 02 00   D....... H...L...
    [01F0] 00 00 00 00 50 01 02 00   54 01 02 00 00 00 00 00   ....P... T.......
    [0200] 58 01 02 00 5C 01 02 00   00 00 00 00 60 01 02 00   X...\... ....`...
    [0210] 64 01 02 00 00 00 00 00   68 01 02 00 6C 01 02 00   d....... h...l...
    [0220] 00 00 00 00 70 01 02 00   74 01 02 00 00 00 00 00   ....p... t.......
    [0230] 78 01 02 00 7C 01 02 00   00 00 00 00 80 01 02 00   x...|... ........
    [0240] 84 01 02 00 03 00 00 80   88 01 02 00 8C 01 02 00   ........ ........
    [0250] 00 00 00 00 90 01 02 00   94 01 02 00 00 00 00 00   ........ ........
    [0260] 98 01 02 00 06 00 00 00   00 00 00 00 06 00 00 00   ........ ........
    [0270] 61 00 6C 00 61 00 72 00   6D 00 00 00 06 00 00 00   a.l.a.r. m.......
    [0280] 00 00 00 00 06 00 00 00   61 00 6C 00 61 00 72 00   ........ a.l.a.r.
    [0290] 6D 00 00 00 07 00 00 00   00 00 00 00 07 00 00 00   m....... ........
    [02A0] 61 00 72 00 63 00 68 00   69 00 76 00 00 00 00 00   a.r.c.h. i.v.....
    [02B0] 07 00 00 00 00 00 00 00   07 00 00 00 61 00 72 00   ........ ....a.r.
    [02C0] 63 00 68 00 69 00 76 00   00 00 00 00 0F 00 00 00   c.h.i.v. ........
    [02D0] 00 00 00 00 0F 00 00 00   61 00 72 00 7A 00 74 00   ........ a.r.z.t.
    [02E0] 72 00 65 00 63 00 68 00   6E 00 75 00 6E 00 67 00   r.e.c.h. n.u.n.g.
    [02F0] 65 00 6E 00 00 00 00 00   0F 00 00 00 00 00 00 00   e.n..... ........
    [0300] 0F 00 00 00 61 00 72 00   7A 00 74 00 72 00 65 00   ....a.r. z.t.r.e.
    [0310] 63 00 68 00 6E 00 75 00   6E 00 67 00 65 00 6E 00   c.h.n.u. n.g.e.n.
    [0320] 00 00 00 00 05 00 00 00   00 00 00 00 05 00 00 00   ........ ........
    [0330] 61 00 75 00 74 00 6F 00   00 00 00 00 05 00 00 00   a.u.t.o. ........
    [0340] 00 00 00 00 05 00 00 00   61 00 75 00 74 00 6F 00   ........ a.u.t.o.
    [0350] 00 00 00 00 07 00 00 00   00 00 00 00 07 00 00 00   ........ ........
    [0360] 62 00 61 00 63 00 6B 00   75 00 70 00 00 00 00 00   b.a.c.k. u.p.....
    [0370] 01 00 00 00 00 00 00 00   01 00 00 00 00 00 00 00   ........ ........
    [0380] 06 00 00 00 00 00 00 00   06 00 00 00 62 00 6F 00   ........ ....b.o.
    [0390] 6F 00 6B 00 73 00 00 00   01 00 00 00 00 00 00 00   o.k.s... ........
    [03A0] 01 00 00 00 00 00 00 00   07 00 00 00 00 00 00 00   ........ ........
    [03B0] 07 00 00 00 63 00 6F 00   64 00 69 00 6E 00 67 00   ....c.o. d.i.n.g.
    [03C0] 00 00 00 00 07 00 00 00   00 00 00 00 07 00 00 00   ........ ........
    [03D0] 63 00 6F 00 64 00 69 00   6E 00 67 00 00 00 00 00   c.o.d.i. n.g.....
    [03E0] 07 00 00 00 00 00 00 00   07 00 00 00 64 00 65 00   ........ ....d.e.
    [03F0] 62 00 65 00 6B 00 61 00   00 00 00 00 07 00 00 00   b.e.k.a. ........
    [0400] 00 00 00 00 07 00 00 00   64 00 65 00 62 00 65 00   ........ d.e.b.e.
    [0410] 6B 00 61 00 00 00 00 00   07 00 00 00 00 00 00 00   k.a..... ........
    [0420] 07 00 00 00 64 00 65 00   6E 00 69 00 73 00 65 00   ....d.e. n.i.s.e.
    [0430] 00 00 00 00 07 00 00 00   00 00 00 00 07 00 00 00   ........ ........
    [0440] 64 00 65 00 6E 00 69 00   73 00 65 00 00 00 00 00   d.e.n.i. s.e.....
    [0450] 09 00 00 00 00 00 00 00   09 00 00 00 64 00 6F 00   ........ ....d.o.
    [0460] 77 00 6E 00 6C 00 6F 00   61 00 64 00 00 00 00 00   w.n.l.o. a.d.....
    [0470] 01 00 00 00 00 00 00 00   01 00 00 00 00 00 00 00   ........ ........
    [0480] 0A 00 00 00 00 00 00 00   0A 00 00 00 64 00 6F 00   ........ ....d.o.
    [0490] 77 00 6E 00 6C 00 6F 00   61 00 64 00 73 00 00 00   w.n.l.o. a.d.s...
    [04A0] 01 00 00 00 00 00 00 00   01 00 00 00 00 00 00 00   ........ ........
    [04B0] 08 00 00 00 00 00 00 00   08 00 00 00 64 00 72 00   ........ ....d.r.
    [04C0] 6F 00 70 00 62 00 6F 00   78 00 00 00 01 00 00 00   o.p.b.o. x.......
    [04D0] 00 00 00 00 01 00 00 00   00 00 00 00 09 00 00 00   ........ ........
    [04E0] 00 00 00 00 09 00 00 00   66 00 69 00 6E 00 61 00   ........ f.i.n.a.
    [04F0] 6E 00 7A 00 65 00 6E 00   00 00 00 00 09 00 00 00   n.z.e.n. ........
    [0500] 00 00 00 00 09 00 00 00   66 00 69 00 6E 00 61 00   ........ f.i.n.a.
    [0510] 6E 00 7A 00 65 00 6E 00   00 00 00 00 0B 00 00 00   n.z.e.n. ........
    [0520] 00 00 00 00 0B 00 00 00   67 00 65 00 73 00 75 00   ........ g.e.s.u.
    [0530] 6E 00 64 00 68 00 65 00   69 00 74 00 00 00 00 00   n.d.h.e. i.t.....
    [0540] 0B 00 00 00 00 00 00 00   0B 00 00 00 67 00 65 00   ........ ....g.e.
    [0550] 73 00 75 00 6E 00 64 00   68 00 65 00 69 00 74 00   s.u.n.d. h.e.i.t.
    [0560] 00 00 00 00 0C 00 00 00   00 00 00 00 0C 00 00 00   ........ ........
    [0570] 67 00 6F 00 6F 00 67 00   6C 00 65 00 64 00 72 00   g.o.o.g. l.e.d.r.
    [0580] 69 00 76 00 65 00 00 00   01 00 00 00 00 00 00 00   i.v.e... ........
    [0590] 01 00 00 00 00 00 00 00   05 00 00 00 00 00 00 00   ........ ........
    [05A0] 05 00 00 00 68 00 61 00   75 00 73 00 00 00 00 00   ....h.a. u.s.....
    [05B0] 01 00 00 00 00 00 00 00   01 00 00 00 00 00 00 00   ........ ........
    [05C0] 06 00 00 00 00 00 00 00   06 00 00 00 68 00 6F 00   ........ ....h.o.
    [05D0] 6D 00 65 00 73 00 00 00   0A 00 00 00 00 00 00 00   m.e.s... ........
    [05E0] 0A 00 00 00 75 00 73 00   65 00 72 00 20 00 68 00   ....u.s. e.r. .h.
    [05F0] 6F 00 6D 00 65 00 00 00   0A 00 00 00 00 00 00 00   o.m.e... ........
    [0600] 0A 00 00 00 68 00 6F 00   6D 00 65 00 73 00 68 00   ....h.o. m.e.s.h.
    [0610] 61 00 72 00 65 00 00 00   01 00 00 00 00 00 00 00   a.r.e... ........
    [0620] 01 00 00 00 00 00 00 00   0A 00 00 00 00 00 00 00   ........ ........
    [0630] 0A 00 00 00 68 00 6F 00   6D 00 65 00 76 00 69 00   ....h.o. m.e.v.i.
    [0640] 64 00 65 00 6F 00 00 00   01 00 00 00 00 00 00 00   d.e.o... ........
    [0650] 01 00 00 00 00 00 00 00   06 00 00 00 00 00 00 00   ........ ........
    [0660] 06 00 00 00 6B 00 6C 00   61 00 75 00 73 00 00 00   ....k.l. a.u.s...
    [0670] 01 00 00 00 00 00 00 00   01 00 00 00 00 00 00 00   ........ ........
    [0680] 04 00 00 00 00 00 00 00   04 00 00 00 6C 00 62 00   ........ ....l.b.
    [0690] 76 00 00 00 04 00 00 00   00 00 00 00 04 00 00 00   v....... ........
    [06A0] 6C 00 62 00 76 00 00 00   06 00 00 00 00 00 00 00   l.b.v... ........
    [06B0] 06 00 00 00 6D 00 75 00   73 00 69 00 63 00 00 00   ....m.u. s.i.c...
    [06C0] 1D 00 00 00 00 00 00 00   1D 00 00 00 53 00 79 00   ........ ....S.y.
    [06D0] 73 00 74 00 65 00 6D 00   20 00 64 00 65 00 66 00   s.t.e.m.  .d.e.f.
    [06E0] 61 00 75 00 6C 00 74 00   20 00 73 00 68 00 61 00   a.u.l.t.  .s.h.a.
    [06F0] 72 00 65 00 64 00 20 00   66 00 6F 00 6C 00 64 00   r.e.d. . f.o.l.d.
    [0700] 65 00 72 00 00 00 00 00   0A 00 00 00 00 00 00 00   e.r..... ........
    [0710] 0A 00 00 00 4E 00 65 00   74 00 42 00 61 00 63 00   ....N.e. t.B.a.c.
    [0720] 6B 00 75 00 70 00 00 00   1D 00 00 00 00 00 00 00   k.u.p... ........
    [0730] 1D 00 00 00 53 00 79 00   73 00 74 00 65 00 6D 00   ....S.y. s.t.e.m.
    [0740] 20 00 64 00 65 00 66 00   61 00 75 00 6C 00 74 00    .d.e.f. a.u.l.t.
    [0750] 20 00 73 00 68 00 61 00   72 00 65 00 64 00 20 00    .s.h.a. r.e.d. .
    [0760] 66 00 6F 00 6C 00 64 00   65 00 72 00 00 00 00 00   f.o.l.d. e.r.....
    [0770] 04 00 00 00 00 00 00 00   04 00 00 00 70 00 64 00   ........ ....p.d.
    [0780] 66 00 00 00 01 00 00 00   00 00 00 00 01 00 00 00   f....... ........
    [0790] 00 00 00 00 06 00 00 00   00 00 00 00 06 00 00 00   ........ ........
    [07A0] 70 00 68 00 6F 00 74 00   6F 00 00 00 1D 00 00 00   p.h.o.t. o.......
    [07B0] 00 00 00 00 1D 00 00 00   53 00 79 00 73 00 74 00   ........ S.y.s.t.
    [07C0] 65 00 6D 00 20 00 64 00   65 00 66 00 61 00 75 00   e.m. .d. e.f.a.u.
    [07D0] 6C 00 74 00 20 00 73 00   68 00 61 00 72 00 65 00   l.t. .s. h.a.r.e.
    [07E0] 64 00 20 00 66 00 6F 00   6C 00 64 00 65 00 72 00   d. .f.o. l.d.e.r.
    [07F0] 00 00 00 00 07 00 00 00   00 00 00 00 07 00 00 00   ........ ........
    [0800] 70 00 75 00 62 00 6C 00   69 00 63 00 00 00 00 00   p.u.b.l. i.c.....
    [0810] 1D 00 00 00 00 00 00 00   1D 00 00 00 53 00 79 00   ........ ....S.y.
    [0820] 73 00 74 00 65 00 6D 00   20 00 64 00 65 00 66 00   s.t.e.m.  .d.e.f.
    [0830] 61 00 75 00 6C 00 74 00   20 00 73 00 68 00 61 00   a.u.l.t.  .s.h.a.
    [0840] 72 00 65 00 64 00 20 00   66 00 6F 00 6C 00 64 00   r.e.d. . f.o.l.d.
    [0850] 65 00 72 00 00 00 00 00   0B 00 00 00 00 00 00 00   e.r..... ........
    [0860] 0B 00 00 00 72 00 65 00   63 00 68 00 6E 00 75 00   ....r.e. c.h.n.u.
    [0870] 6E 00 67 00 65 00 6E 00   00 00 00 00 0B 00 00 00   n.g.e.n. ........
    [0880] 00 00 00 00 0B 00 00 00   72 00 65 00 63 00 68 00   ........ r.e.c.h.
    [0890] 6E 00 75 00 6E 00 67 00   65 00 6E 00 00 00 00 00   n.u.n.g. e.n.....
    [08A0] 08 00 00 00 00 00 00 00   08 00 00 00 72 00 65 00   ........ ....r.e.
    [08B0] 7A 00 65 00 70 00 74 00   65 00 00 00 08 00 00 00   z.e.p.t. e.......
    [08C0] 00 00 00 00 08 00 00 00   72 00 65 00 7A 00 65 00   ........ r.e.z.e.
    [08D0] 70 00 74 00 65 00 00 00   05 00 00 00 00 00 00 00   p.t.e... ........
    [08E0] 05 00 00 00 73 00 63 00   61 00 6E 00 00 00 00 00   ....s.c. a.n.....
    [08F0] 01 00 00 00 00 00 00 00   01 00 00 00 00 00 00 00   ........ ........
    [0900] 07 00 00 00 00 00 00 00   07 00 00 00 73 00 63 00   ........ ....s.c.
    [0910] 68 00 75 00 6C 00 65 00   00 00 00 00 01 00 00 00   h.u.l.e. ........
    [0920] 00 00 00 00 01 00 00 00   00 00 00 00 07 00 00 00   ........ ........
    [0930] 00 00 00 00 07 00 00 00   73 00 64 00 63 00 6F 00   ........ s.d.c.o.
    [0940] 70 00 79 00 00 00 00 00   01 00 00 00 00 00 00 00   p.y..... ........
    [0950] 01 00 00 00 00 00 00 00   07 00 00 00 00 00 00 00   ........ ........
    [0960] 07 00 00 00 73 00 65 00   72 00 69 00 65 00 6E 00   ....s.e. r.i.e.n.
    [0970] 00 00 00 00 01 00 00 00   00 00 00 00 01 00 00 00   ........ ........
    [0980] 00 00 00 00 06 00 00 00   00 00 00 00 06 00 00 00   ........ ........
    [0990] 73 00 68 00 61 00 72 00   65 00 00 00 01 00 00 00   s.h.a.r. e.......
    [09A0] 00 00 00 00 01 00 00 00   00 00 00 00 09 00 00 00   ........ ........
    [09B0] 00 00 00 00 09 00 00 00   73 00 6F 00 66 00 74 00   ........ s.o.f.t.
    [09C0] 77 00 61 00 72 00 65 00   00 00 00 00 01 00 00 00   w.a.r.e. ........
    [09D0] 00 00 00 00 01 00 00 00   00 00 00 00 06 00 00 00   ........ ........
    [09E0] 00 00 00 00 06 00 00 00   73 00 6F 00 6E 00 6F 00   ........ s.o.n.o.
    [09F0] 73 00 00 00 06 00 00 00   00 00 00 00 06 00 00 00   s....... ........
    [0A00] 73 00 6F 00 6E 00 6F 00   73 00 00 00 06 00 00 00   s.o.n.o. s.......
    [0A10] 00 00 00 00 06 00 00 00   73 00 70 00 6C 00 65 00   ........ s.p.l.e.
    [0A20] 78 00 00 00 01 00 00 00   00 00 00 00 01 00 00 00   x....... ........
    [0A30] 00 00 00 00 06 00 00 00   00 00 00 00 06 00 00 00   ........ ........
    [0A40] 73 00 70 00 6F 00 72 00   74 00 00 00 01 00 00 00   s.p.o.r. t.......
    [0A50] 00 00 00 00 01 00 00 00   00 00 00 00 0D 00 00 00   ........ ........
    [0A60] 00 00 00 00 0D 00 00 00   73 00 75 00 72 00 76 00   ........ s.u.r.v.
    [0A70] 65 00 69 00 6C 00 6C 00   61 00 6E 00 63 00 65 00   e.i.l.l. a.n.c.e.
    [0A80] 00 00 00 00 1D 00 00 00   00 00 00 00 1D 00 00 00   ........ ........
    [0A90] 53 00 79 00 73 00 74 00   65 00 6D 00 20 00 64 00   S.y.s.t. e.m. .d.
    [0AA0] 65 00 66 00 61 00 75 00   6C 00 74 00 20 00 73 00   e.f.a.u. l.t. .s.
    [0AB0] 68 00 61 00 72 00 65 00   64 00 20 00 66 00 6F 00   h.a.r.e. d. .f.o.
    [0AC0] 6C 00 64 00 65 00 72 00   00 00 00 00 0C 00 00 00   l.d.e.r. ........
    [0AD0] 00 00 00 00 0C 00 00 00   74 00 69 00 6D 00 65 00   ........ t.i.m.e.
    [0AE0] 6D 00 61 00 63 00 68 00   69 00 6E 00 65 00 00 00   m.a.c.h. i.n.e...
    [0AF0] 01 00 00 00 00 00 00 00   01 00 00 00 00 00 00 00   ........ ........
    [0B00] 06 00 00 00 00 00 00 00   06 00 00 00 74 00 76 00   ........ ....t.v.
    [0B10] 72 00 65 00 63 00 00 00   01 00 00 00 00 00 00 00   r.e.c... ........
    [0B20] 01 00 00 00 00 00 00 00   07 00 00 00 00 00 00 00   ........ ........
    [0B30] 07 00 00 00 75 00 72 00   6C 00 61 00 75 00 62 00   ....u.r. l.a.u.b.
    [0B40] 00 00 00 00 07 00 00 00   00 00 00 00 07 00 00 00   ........ ........
    [0B50] 75 00 72 00 6C 00 61 00   75 00 62 00 00 00 00 00   u.r.l.a. u.b.....
    [0B60] 08 00 00 00 00 00 00 00   08 00 00 00 75 00 73 00   ........ ....u.s.
    [0B70] 62 00 63 00 6F 00 70 00   79 00 00 00 01 00 00 00   b.c.o.p. y.......
    [0B80] 00 00 00 00 01 00 00 00   00 00 00 00 0F 00 00 00   ........ ........
    [0B90] 00 00 00 00 0F 00 00 00   76 00 65 00 72 00 73 00   ........ v.e.r.s.
    [0BA0] 69 00 63 00 68 00 65 00   72 00 75 00 6E 00 67 00   i.c.h.e. r.u.n.g.
    [0BB0] 65 00 6E 00 00 00 00 00   0F 00 00 00 00 00 00 00   e.n..... ........
    [0BC0] 0F 00 00 00 76 00 65 00   72 00 73 00 69 00 63 00   ....v.e. r.s.i.c.
    [0BD0] 68 00 65 00 72 00 75 00   6E 00 67 00 65 00 6E 00   h.e.r.u. n.g.e.n.
    [0BE0] 00 00 00 00 09 00 00 00   00 00 00 00 09 00 00 00   ........ ........
    [0BF0] 76 00 65 00 74 00 72 00   61 00 65 00 67 00 65 00   v.e.t.r. a.e.g.e.
    [0C00] 00 00 00 00 09 00 00 00   00 00 00 00 09 00 00 00   ........ ........
    [0C10] 76 00 65 00 74 00 72 00   61 00 65 00 67 00 65 00   v.e.t.r. a.e.g.e.
    [0C20] 00 00 00 00 06 00 00 00   00 00 00 00 06 00 00 00   ........ ........
    [0C30] 76 00 69 00 64 00 65 00   6F 00 00 00 1D 00 00 00   v.i.d.e. o.......
    [0C40] 00 00 00 00 1D 00 00 00   53 00 79 00 73 00 74 00   ........ S.y.s.t.
    [0C50] 65 00 6D 00 20 00 64 00   65 00 66 00 61 00 75 00   e.m. .d. e.f.a.u.
    [0C60] 6C 00 74 00 20 00 73 00   68 00 61 00 72 00 65 00   l.t. .s. h.a.r.e.
    [0C70] 64 00 20 00 66 00 6F 00   6C 00 64 00 65 00 72 00   d. .f.o. l.d.e.r.
    [0C80] 00 00 00 00 04 00 00 00   00 00 00 00 04 00 00 00   ........ ........
    [0C90] 77 00 65 00 62 00 00 00   1D 00 00 00 00 00 00 00   w.e.b... ........
    [0CA0] 1D 00 00 00 53 00 79 00   73 00 74 00 65 00 6D 00   ....S.y. s.t.e.m.
    [0CB0] 20 00 64 00 65 00 66 00   61 00 75 00 6C 00 74 00    .d.e.f. a.u.l.t.
    [0CC0] 20 00 73 00 68 00 61 00   72 00 65 00 64 00 20 00    .s.h.a. r.e.d. .
    [0CD0] 66 00 6F 00 6C 00 64 00   65 00 72 00 00 00 00 00   f.o.l.d. e.r.....
    [0CE0] 05 00 00 00 00 00 00 00   05 00 00 00 49 00 50 00   ........ ....I.P.
    [0CF0] 43 00 24 00 00 00 00 00   0F 00 00 00 00 00 00 00   C.$..... ........
    [0D00] 0F 00 00 00 49 00 50 00   43 00 20 00 53 00 65 00   ....I.P. C. .S.e.
    [0D10] 72 00 76 00 69 00 63 00   65 00 20 00 28 00 29 00   r.v.i.c. e. .(.).
    [0D20] 00 00 00 00 0E 00 00 00   00 00 00 00 0E 00 00 00   ........ ........
    [0D30] 7A 00 65 00 69 00 74 00   73 00 63 00 68 00 72 00   z.e.i.t. s.c.h.r.
    [0D40] 69 00 66 00 74 00 65 00   6E 00 00 00 0E 00 00 00   i.f.t.e. n.......
    [0D50] 00 00 00 00 0E 00 00 00   7A 00 65 00 69 00 74 00   ........ z.e.i.t.
    [0D60] 73 00 63 00 68 00 72 00   69 00 66 00 74 00 65 00   s.c.h.r. i.f.t.e.
    [0D70] 6E 00 00 00 05 00 00 00   00 00 00 00 05 00 00 00   n....... ........
    [0D80] 68 00 6F 00 6D 00 65 00   00 00 00 00 1B 00 00 00   h.o.m.e. ........
    [0D90] 00 00 00 00 1B 00 00 00   48 00 6F 00 6D 00 65 00   ........ H.o.m.e.
    [0DA0] 20 00 64 00 69 00 72 00   65 00 63 00 74 00 6F 00    .d.i.r. e.c.t.o.
    [0DB0] 72 00 79 00 20 00 6F 00   66 00 20 00 6C 00 6F 00   r.y. .o. f. .l.o.
    [0DC0] 78 00 62 00 65 00 72 00   72 00 79 00 00 00 00 00   x.b.e.r. r.y.....
    [0DD0] 31 00 00 00 9C 01 02 00   00 00 00 00 00 00 00 00   1....... ........
    Got pdu len 3576, data_len 3552
    rpc_api_pipe: got frag len of 3576 at offset 0: NT_STATUS_OK
    rpc_api_pipe: host 10.1.1.10 returned 3552 bytes.
            out: struct srvsvc_NetShareEnumAll
                info_ctr                 : *
                        ctr1                     : *
                                count                    : 0x00000031 (49)
                                array                    : *
                                    array: ARRAY(49)
                                        array: struct srvsvc_NetShareInfo1
                                            type                     : STYPE_DISKTREE (0x0)
                                            comment                  : *
                                                comment                  : 'alarm'
                                            comment                  : *
                                                comment                  : 'archiv'
                                            comment                  : *
                                                comment                  : 'arztrechnungen'
                                            comment                  : *
                                                comment                  : 'auto'
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : 'coding'
                                            comment                  : *
                                                comment                  : 'debeka'
                                            comment                  : *
                                                comment                  : 'denise'
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : 'finanzen'
                                            comment                  : *
                                                comment                  : 'gesundheit'
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : 'user home'
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : 'lbv'
                                            comment                  : *
                                                comment                  : 'System default shared folder'
                                            comment                  : *
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                            comment                  : *
                                            comment                  : *
                                                comment                  : 'rechnungen'
                                            comment                  : *
                                                comment                  : 'rezepte'
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : 'sonos'
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : 'urlaub'
                                            comment                  : *
                                                comment                  : ''
                                            comment                  : *
                                                comment                  : 'versicherungen'
                                            comment                  : *
                                                comment                  : 'vetraege'
                                            comment                  : *
                                            comment                  : *
                                            type                     : STYPE_IPC_HIDDEN (0x80000003)
                                            comment                  : *
                                                comment                  : 'IPC Service ()'
                                            comment                  : *
                                                comment                  : 'zeitschriften'
                                            comment                  : *
                                                comment                  : 'Home directory of loxberry'
                totalentries             : *
                    totalentries             : 0x00000031 (49)
                resume_handle            : *
                result                   : WERR_OK
    Connecting to 10.1.1.10 at port 139
    Socket options:
        SO_KEEPALIVE = 0
        SO_REUSEADDR = 0
        SO_BROADCAST = 0
        TCP_NODELAY = 1
        TCP_KEEPCNT = 9
        TCP_KEEPIDLE = 7200
        TCP_KEEPINTVL = 75
        IPTOS_LOWDELAY = 0
        SO_REUSEPORT = 0
        SO_SNDBUF = 44800
        SO_RCVBUF = 341760
        SO_SNDLOWAT = 1
        SO_RCVLOWAT = 1
        SO_SNDTIMEO = 0
        SO_RCVTIMEO = 0
        TCP_QUICKACK = 1
     session request ok
            DomainName               : *
                DomainName               : ''
            Workstation              : *
                Workstation              : ''
                Reserved: ARRAY(3)
                    [0]                      : 0x00 (0)
                    [1]                      : 0x00 (0)
                    [2]                      : 0x00 (0)
     session setup ok
    signed SMB2 message
    signed SMB2 message
     tconx ok
    num_setup=0, max_setup=0, param_total=36, this_param=36, max_param=8, data_total=0, this_data=0, max_data=65535, param_offset=92, param_pad=2, param_disp=0, data_offset=128, data_pad=0, data_disp=0
    map_errno_from_nt_status: 32 bit codes: code=c0000059
    Disk|backup|
    • Scrati
      • 219
      #92
      10.1.1.10:/volume1/backup/loxberry /backup/loxberry nfs auto,uid=1032,gid=100,rsize=32768,wsize=32768,tcp, intr,nofail 0 0
      Das rote muss raus. Der Pfad zum Einhängen muss, wenn ich mich recht entsinne, auf /backup
      Du kannst auch mal das probieren, das funzt bei mir: 10.1.1.10:/volume1/backup/loxberry /backup nfs4 rw,soft,rsize=32768,wsize=32768 0 2
      Zuletzt geändert von Scrati; 15.11.2018, 22:09.
      • Hesch@
        Hesch@ kommentierte
        Hi Scrati,
        dein Vorschlag (10.1.1.10:/volume1/backup/loxberry /backup nfs4 rw,soft,rsize=32768,wsize=32768 0 2) funzt jetzt auch bei mir.
        Danke für den richtigen Tip.
        Jetzt läuft das Loxberry-Backup mit Auto-Mount auf eine Synology-NAS (bei mir eine DS216) wie es soll.
        @Sven: Wäre in deiner sehr guten Plugin-Beschreibung zu erwähnen.
        Zuletzt geändert von Hesch@; 17.11.2018, 08:14.
      • Scrati
        Scrati kommentierte
        @Hesch@ Ich habe das im wiki ergänzt. Danke für die Rückmeldung
      • michael287
        michael287 kommentierte
        Scrati Danke, hat bei mir jetzt auch funktioniert!
    • Liver_64
      • 07.09.2015
      • 628
      #93
      entweder "/volume1/Share1/Backup" oder "/volume1/Share2/Backup", je nachdem auf welche Platte
      • michael287
        Ok, versuche ich nachher.
      • 6366
      #94
      Ich will ja nicht schlau daherkommen, da das sicher alles überprüft wurde, aber Michael hat mal geschrieben dass er die Beiden Platten als RAID Verbund hat. Wenn dem so ist, dann sieht aber das system nur 1 Volume. Da kann nichts mehr auf einzelne Platten schreiben. Ich kenne die Synology nicht, aber bei einem realen RAID ist das so.
      • michael287
        So ist das, daher hatte ich mich auch explizit auf volume1 berufen. Für das System sieht es aus wie eine Platte, sich wenn physisch zwei drin stecken.
      • Hesch@
        Hesch@ kommentierte
        kann Michael und Sven auch nur recht geben. Ich habe auch eine Synology mit zwei Platten als Raid-System.
        Man sieht definitiv nur Volume1. Wiederspricht ja sonst auch einem Raid-System.
        Habe das Auto-Mounten übrigens leider auch noch nicht hinbekommen.
      • Liver_64
        Liver_64 kommentierte
        Das /Volume1 bei Synology ist nichts anderes als ein logical drive. Ich hatte nur irgendwann mal Probleme mit dem uralten Sonos PHP script auf die NAS zuzugreifen und bei der Recherche stieß ich dann irgendwie auf das Thema. Da mein Syn nur eine Platte hat, kann ich es nicht testen, aber wenn mal mal nach "Synology /volume1/share1" googelt findet man einiges. Von daher nehme ich an das dem so ist, aber keine Garantie dafür.
    • michael287
      • 369
      #95
      Erledigt!
      Lösung in Beitrag # 92.2 https://www.loxforum.com/forum/proje...943#post176943
      • Scrati
        Scrati kommentierte
        Danke für die Rückmeldung. Ist jetzt auch im wiki für die nächsten.
    • pat
      • 19.10.2015
      • 27
      #96
      ich hab irgendwie das Problem, dein mein Loxberry Backup Plugin nicht beendet wird (ist auffällig beim 2. Backup nach einem Neustart gewesen. Neu gestartet hatte ich den Loxberry ebenfalls, weil ich das Gefühl hatte, dass das Plugin nicht zu Ende durchläuft).
      Das noch zu laufen Logfile beinhaltet aktuell folgende Informationen:
      17.11.2018 06:00:01 TASK STARTED
      LoxBerry Backup
      INFO: LoxBerry Version 1.2.5.4 ( is_raspberry.cfg )
      INFO: LoxBerry Backup Version 1.0.4
      INFO: Loglevel: 3
      Script started on Sat 17 Nov 2018 06:00:02 CET
      --- RBK0009I: loxberry: raspiBackup.sh V0.6.4.1-beta (54710f7) started at Sat 17 Nov 06:00:03 CET 2018.
      !!! RBK0165W: =========> NOTE <=========
      !!! RBK0165W: This is a betaversion and should not be used in production.
      --- RBK0031I: Checking whether a new version of raspiBackup.sh is available.
      --- RBK0151I: Using backuppath /backup.
      !!! RBK0157W: No services to stop.
      --- RBK0085I: Backup of type ddz started. Please be patient.
      Im ersten "CRITICAL" File steht folgendes:
      18.11.2018 06:00:01 TASK STARTED
      LoxBerry Backup
      INFO: Loglevel: 3
      CRITICAL: Could not lock LoxBerry Backup after 120 tries (3 min. each) . It seems that another backup is running. Giving up.
      18.11.2018 12:00:04 TASK FINISHED
      Liegt es am Plugin oder habe ihc etwas falsch eingestellt? Lt. Zeitplan mache ich täglich um 06:00 einkomprimiertes DD-Image (DDZ) auf meinen Synology NAS.
        Das Backup vom 17.11. ist in der Tat hängen geblieben - und einen Tag später noch nicht beendet gewesen, schätze ich.
        Stell mal den Loglevel auf DEBUG, dann gibt RaspiBackup mehr aus. Danach Reboot, damit alles clean ist.
          PS: ... wobei bei DDZ grundsätzlich nichts nach „Please be patient“ ausgegeben wird. Solange das DDZ läuft, ist Stille.
          Evt. kannst du in der Situation auf der Shell mit top oder ps aux nachsehen, was noch läuft.
        • pat
          pat kommentierte
          Ich hab in der Shell mit top und ps aux nachgesehen aber mit meinen nicht vorhandenen Linux Kenntnissen nichts auffälliges gesehen...
          Soll ich die vielen Ergebniszeilen trotzdem hier mal rein posten oder lieber das Ergebnis der Variante 1 (Loglevel auf DEBUG...)?
        ps aux
        und das gesamte Ergebnis in einem Textfile hochladen.
        So kann man‘s am besten lesen.
        Wenn allerdings dd oder gzip einfach hängen bleibt, kann ich auch nichts unternehmen.
        lg Christian
        • pat
          • 19.10.2015
          • 27
          #99
          Anbei das Textfile (top und ps aux enthalten).
          Parallel läuft gerade die andere Variante (Loglevel Debug, loxberry neu gestartet und ich hab soeben manuell ein Backup-Vorgang angestoßen). Mal schauen was passiert...
          Schon einmal vielen Dank im Voraus.
          Gruß, Patrick
            Ich habe Das Plugin unter lb 1.2.5.5 installiert, soweit nur mit einer Warning durchgelaufen " WARNING: *** DEPRECIATED *** This Plugin uses the outdated PLUGIN Interface V1.0. It will be compatible with this Version of LoxBerry but may not work with the next Major LoxBerry release! Please inform the PLUGIN Author at git@loxberry.woerstenfeld.de"
            Allerdings tut sich beim Backup gar nichts.
            Ist das bekannt mit dem letzten LB Release?
              pat
              Definitiv läuft hier noch raspiBackup mit dd und gzip:
              loxberry 3911 0.0 0.0 1900 372 ? Ss Nov17 0:00 /bin/sh -c /opt/loxberry/bin/plugins/lbbackup/runbackup
              root 3952 0.0 0.3 7228 3280 pts/0 S+ Nov17 0:00 sudo /usr/local/bin/raspiBackup.sh -N fstab disk temp -
              root 4200 0.0 0.2 4500 2520 pts/0 S+ Nov17 0:03 dd if=/dev/mmcblk0 bs=1MB
              root 4201 0.0 0.1 2072 1256 pts/0 D+ Nov17 4:25 gzip
              Aus Sicht von top macht aber weder dd noch gzip etwas.
              Wahrscheinlich hängt eines der Programme bei irgendeiner Abfrage - da kann ich aber leider nicht sagen, was das ist....
              • pat
                pat kommentierte
                Hallo Christian,
                nach einem Neustart habe ich das Backup mal manuell gestartet und parallel den Zeitplan deaktiviert (zuvor war ein tägliches Backup für 6 Uhr eingestellt).
                Siehe da, das Backup läuft durch:
                24.11.2018 12:25: LoxBerry Backup has successfully finished.
                Backup started at 21.11.2018 23:34:36 and finished at 24.11.2018 12:25:29
                Disk space info on /backup
                192.168.178.17:/volume1/Timmen/SmartHome/LoxBerry/Backup (/backup) | Size: 2.68 TB | Used: 731.08 GB | Free: 1.97 TB
                Daher würde ich vermuten, dass das Plugin sozusagen in eine Endlosschleife läuft, da bereits ein neues Backup angestoßen wird, obwohl das erste Backup noch gar nicht fertig ist.
                Kann man diese Konstellation ggf. abfangen? Und würdest du es als "normal" ansehen, dass die Backuperstellung mehrere Tage benötigt?
              Gast Zu wenig Input.
              Hat's vorher funktioniert? Was geht nicht? Was steht im Log?
              Die Pluginentwickler stecken viel Zeit in ihrer Freizeit in die Programmierung der Plugins. Noch mehr Zeit kostet der Support der eigenen Plugins! Ihr solltet das
                @Christian: Danke für die schnelle Rückmeldung und sorry für zuwenig Input.
                Es ist die erste Installation, Log wie folgt. Plugin Version 0.21, Loxberry 1.2.5.5
                Log nach Start des Backups, zusätzlich zu der oben beschriebenen Warnung:
                OK: 2018-11-21 22:38:36 : 1 Miniserver insgesamt - Starte Backup mit Script /opt/loxberry/webfrontend/cgi/plugins/miniserverbackup/bin/createmsbackup.pl (Version V0.21)
                OK: 2018-11-21 22:38:36 Miniserver #1: Starte Backup von Miniserver 1
                OK: 2018-11-21 22:38:36 Miniserver #1: Versuche Miniserver-Firmware-Version auszulesen
                OK: 2018-11-21 22:38:37 Miniserver #1: Miniserver-Version:10.0.9.24
                OK: 2018-11-21 22:38:37 Miniserver #1: Versuche lokale Miniserver-IP auszulesen
                OK: 2018-11-21 22:38:37 Miniserver #1: Miniserver-IP (LAN/lokal):
                OK: 2018-11-21 22:38:37 Miniserver #1: Benutze folgenden FTP-Port:21
                In diesem Zustand bleibt es dann und es passiert nichts weiter.
                Danke und LG
                  Das schaut grundsätzlich ja mal nicht so schlecht aus, nur bist du im Thread des falschen Plugins! 😉
                  --> Miniserverbackup
                    Verstehe nicht ganz, hier geht es mir um das Backup vom MS?!
                    Trotzdem Danke und LG
