Plugin: HaBridge
Hi guys. I have LoxBerry V1.2.5.5 and Sonos4lox: v3.5.9 and LoxBerry HA Bridge 0.3.1 + echod dot 1. generation currently, and all was working without problem before and all commands from allexa loxone did but now I can see there is no problem in case of alexa commands TURN ON or TURN OFF but problem is dimm commands. Behaviour in case of dimm commands to alexa is something like random...always is doing something different or it dont react even alexa confirm as "OK".Let me inform you also that if I am trying buttons directly in habridge webinterface like TEST ON, TEST OFF and TEST DIM all is working perfect without problem. Also all is working great in loxone config. Only problem is if I say alexa commands behavious is different. I have also tried some options in HA bridge as you can see in attached picture (red marked) but still is not correctly all working. Is there any change or how can I solve it please?thanksZuletzt geändert von ager; 12.02.2019, 13:20.Kommentar
Hi again.
LoxBerry V1.2.5.5
Ha Bridge version 5.2.0
I have change lightcontroller in loxone config from old one (Lighting Controller V1 OLD) to new one (Lighting Controller) and UUID from new controller isnt working in Habridge. Is there any change please or it is currently not working with new lighting blok from loxone? Please reply somebody shortly if it is working or not...Many thanksKommentar
Die Datei lässt sich problemlos Downloaden. Ihr wisst aber schon, dass Ihr im Forum angemeldet sein müsst um eine Datei zu laden?Miniserver; KNX; Vitogate; EnOcean (EnOceanPi); Loxone Air; Caldav-Kalenderanbindung; RaspberryPi und für keine Frickellösung zu schade :-)Kommentar
Oh mein Gott, bin ich ein N00b... Ich habe es in schöner Regelmäßigkeit versäumt, angemeldet zu sein, wenn ich den Download versucht habe und mich dann zum kommentieren angemeldet.
Sorry, funzt einwandfrei. Gleiches gilt für die Installation des Plugins.
Ein toller Einstand.
Merci und schönen Sonntag.
Guten Tag zusammen,
ich habe momentan folgendes Problem:
Wenn ich Befehele / Teilnehmer der HA Bridge hinzufügen und diese speicher "add" bleiben diese nur bis zu einem Neustart von Loxberry gespeichert.
Nach einem Neustart verschwinden diese einfach, jedoch drei Teilnhemer, die ich vor 5 Wochen bereits hinzugefügt habe bleiben dauerhaft bestehen.
Habt ihr eine Idee ?Kommentar
Hy,
etwas mehr Infos brauchen wir dann doch. Port geändert auf 80 ? http://loxberry:8080 kommt da etwas?
Häufig kommt dieser Fehler vor: https://www.loxforum.com/forum/proje...785#post149785
mich hab mir jetzt, wie alle hier, ein Echo dot 3 zugelegt und wollte diese mit meinem loxberry verbinden.
Aktuell hab ich die Plugins mit den aktuellen Versionen des FHEM und der habridge installiert.
Der Port vom loxberry hab ich auf 81 geändert.
Wenn ich jetzt die habridge webpage aufrufen will, dann komme ich immer auf der Kodi webpage heraus.
Kann mir einer helfen wie ich den Port von Kodi oder habridge so ändern kann, dass es funktioniert?
Ich hab schon diverse howtos probiert und komme nicht ans Ziel.
Falls Infos zur Fehlerbehebung Fehlern, dann schicke ich diese gern noch.
DANKE schon mal für eure Antworten.
VGKommentar
