Beta Thread
    • 5372
    #106
    hismastersvoice Passt, deswegen hatte ich den Code auch nur in den PN Thread gepostet.
    Bei dem LMSPlugin für den LoxBerry musste ich damals explizit die arm-Version nehmen, die war damals im All-Paket nicht enthalten. Vielleicht haben sie das mittlerweile geändert, habe ich aber gar nicht probiert.
    • querex
      • 14.07.2020
      • 184
      #107
      hismastersvoice can't find on the forum if it's already a known issue or not...
      But will post it over here for you information (low prio bug as it's easy to correct with vi afterwards).
      My mini computer has 2 network ports, which results into an incorrect "interfaces" modification by the installation script.
      Output of "ip -o link show":
      1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000\ link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
      2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000\ link/ether 00:e0:67:1f:a1:84 brd ff:ff:ff:ff:ff:ff
      3: enp2s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000\ link/ether 00:e0:67:1f:a1:85 brd ff:ff:ff:ff:ff:ff
      Which results into an "interfaces" file:
      ## NETWORK SETTINGS CREATE BY MUSICSERVER4LOX
      auto lo
      iface lo inet loopback
      auto enp1s0
      enp2s0
      iface enp1s0
      enp2s0 inet dhcp
      Smart home: Miniserver Gen2, 2xRelay ext, 2xDimmer ext, 4xExtensions, Tree ext, Air base ext, RGBW dimmer tree, 13xTouch tree, 6xMotion sensor tree, 9xEsylux PD-C 360i 8UC, 15xValve actuator tree, 9xSmoke detector air, 4xSmart socket air, IR control air, Remote air, SDM630 modbus kWh
        • 7631
        #108
        auto lo
        auto enp1s0
        enp2s0
        iface enp1s0
        enp2s0 inet dhcp
        I know that the help side is at the moment only in german, and english is not translated full.
        Read here -> https://music-server.net/help/Networkchange.html
        The system don´t work if two Network-Cards are active.
        I don´t change that behavior, becouse the Music-Server don´t need the second Network-Card.
        So turn off one card in the Bios.
        Zuletzt geändert von hismastersvoice; 14.07.2020, 14:05.
          • 7631
          #109
          Have opend a crowdfunding for a Loxone MusikServer to undestand the interface between Musik and MiniServer.
          I somebody like to help...
          AKTUELLER STAND: 1330,50€ SPENDER: 38 Da ich etwas mehr über die Anbindung des MusikServer zum MiniServer lernen möchte, würde ich gerne eine Loxone MusikServer kaufen. Bis jetzt habe ich alle Test-Hardware etc. selber gekauft, aber 1500€ finde ich dieses mal etwas viel. Wer dich also beteiligen möchte, darf gerne
            I tried in new version 1.0.6 use the volume controls for every channel on both my cards but it didn`t work for me. I had to set the volume for each channel through alsamixer command on my NUC computer with Debian.
              • 7631
              #111
              The Alsa Volume should be ~100%
              The channel volume is not comparable to the alsa direct, so if you only go down 5% you will not hear a difference.
              Try to go reset alsa to 100% and the channel to 50% than you will hear a big difference.
              More Info about your System is needed. Also a screenshot from the Zone-Settings
              Please show me the soundcard config
              #cat /opt/music_server/soundcard_cfg/zones/zone_XX.cfg
              Change XX with zone number 01,02,03...
              • roadi
                • 561
                #112
                Kurze Frage, wobei ich nicht sicher bin ob das ein Problem vom Musikserver ist oder von Loxone selbst.
                Wenn 1 Zone läuft, und ich im Zentral Baustein ganz oben auf pause drücke, schaltet sich die eine Zone ab, aber alle anderen ein. Das kann doch so nicht richtig sein.
                lg.
                Fritzbox: 7490
                  • 7631
                  #113
                  lg.
                  Mir gefällt das Verhalten auch nicht, aber der MiniServer gibt das Signal genau so weiter.
                  orli
                  Ist das beim org. auch so? Denke schon, der MusikServer bekommt ja die gleichen Signale, bin mir aber nicht sicher.
                    • 2604
                    #114
                    Nein, Steuerung im Zentralbaustein arbeitet wie erwartet. Schalte ich eine Zone aus, geht auch nur diese aus.
                      Missverständnis...
                      Er meint die Zentrale Bedienung über den Zonen die alle Zonen Play/Pause/leiser/lauter steuert.
                      Ist eine Zone auf Play, und ich drücke Pause ohne das ich eine Zone angewählt habe, geht die Zone auf Pause, die anderen aber auf Play.
                      Bei Play passt das, alle Zonen gehen auf Play, nur bei Pause scheint quasi ein State wechsel zu passieren.
                      orli kommentierte
                      Nein, auch dann nicht @roadi:
                      Eine Zone spielt ab -> grünes II (Pause) Symbol im Zentralbaustein Musik. Klicke ich nun im oberen Feld das "alle Zonen II (Pause)" Symbol geht auch nur diese Zone aus, alle anderen bleiben aus. Drücke ich hingegen das "alle Zonen Play Symbol" gehen natürlich alle Zonen an.
                      Spielen bei mir 5 Zonen und ich wähle das "alle Zonen II (Pause) Symbol, gehen auch nur diese 5 Zonen aus, keine andere an.
                      BTW @hismastersvoice: Welches Spotify Plugin verwendest du im LMS? Der originale Musikserver verwendet ein altes Spotify Plugin von Triode (Version 2.3.9), welches wohl schon länger durch Spotty (?) abgelöst wurde? Lese mich da gerade etwas ein, da bei mir einige Playlisten haken, via Spotify App aber tadellos laufen.
                      Zuletzt geändert von orli; 20.07.2020, 10:55.
                      OK, der Fehler ist das Pause nur ausgeführt werden darf wenn der Player auch auf Play steht, und nicht immer.
                      Bis jetzt reiche ich Pause einfach an den LMS weiter, da muss vorher noch ein Check rein ob die Zone auch spielt.
                      Mach ich für das nächste Update.
                    • 7631
                    #115
                    roadi
                    habe das gefixed
                    Nächste Version dauert aber noch ein wenig.
                    Will die erste Version von KNX-Connect mit drin haben.
                    • roadi
                      roadi kommentierte
                      Hat keinen Stress.
                      lg.
                    • 7631
                    #116
                    Gast
                    Not nice to get now answer... Does it work now?
                      I'm OK with the clarification as the same is for using my headphone amplifier. Set SW volume to 100% and regulate on the amplifier. Same is working here but didnt tried the change on channel volume in MS4L as I'm ok now with setting of proper aplifier gain and setting volume in squeezelite clients. Sorry for delay but I am on vacation lol.
                  • f.hien
                    • 392
                    #117
                    Hallo zusammen, leider ist meine Installation irgendwie in die Wüste gegangen! Wollte auf Version 0.7.4 Update das ging schief danach hatte er einen appache2 Fehler. Gibt es die Möglichkeit irgendwie ein Backup vom Music Server zu machen gerne auch über ssh. nur wegen der ganzen einstellungen. und alles einfach neu zu installieren! LMS sollte auch gebackut werden.
                    Wäre super wenn mir jemand helfen könnte!
                      • 7631
                      #118
                      mstools backup_ms -> kpl. MusikServer
                      mstools backup_ms_set -> MusikServer Settings
                      mstoolsbackup_lms -> LogitechMediaServer
                      mstools backup_lms_fav -> LMS Favoriten
                      mstools backup_lms_pl -> LMS Playlists
                      Die Zeile am Ende das eine txt-Datei nicht geschrieben werden kann einfach ignorieren, kommt daher da normal das WebUI diese Datei liefert.
                      Einspielen am besten über WebUI
                      Der Fehler könnte in der "etc/apache2/sites-enabled/000-default.conf" liegen.
                      Sollte so aussehen...
                      <VirtualHost *:80>
                      # The ServerName directive sets the request scheme, hostname and port that
                      # the server uses to identify itself. This is used when creating
                      # redirection URLs. In the context of virtual hosts, the ServerName
                      # specifies what hostname must appear in the request's Host: header to
                      # match this virtual host. For the default virtual host (this file) this
                      # value is not decisive as it is used as a last resort host regardless.
                      # However, you must set it for any further virtual host explicitly.
                      #ServerName www.example.com
                      ServerAdmin webmaster@localhost
                      DocumentRoot /var/www
                      # Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
                      # error, crit, alert, emerg.
                      # It is also possible to configure the loglevel for particular
                      # modules, e.g.
                      #LogLevel info ssl:warn
                      ErrorLog ${APACHE_LOG_DIR}/error.log
                      CustomLog ${APACHE_LOG_DIR}/access.log combined
                      # For most configuration files from conf-available/, which are
                      # enabled or disabled at a global level, it is possible to
                      # include a line for only one particular virtual host. For example the
                      # following line enables the CGI configuration for this host only
                      # after it has been globally disabled with "a2disconf".
                      #Include conf-available/serve-cgi-bin.conf
                      </VirtualHost>
                      # vim: syntax=apache ts=4 sw=4 sts=4 sr noet
                      • f.hien
                        f.hien kommentierte
                        Danke für die Hilfe Super Arbeit, leider hat das alles nichts gebracht! habs neu installiert und die alte SSD an den PC angeschlossen, so konnt ich zumindest die Einstellungen aus den Dateine Rauslesen! funktioniert alles wieder besten, und nun auf Debian!
                        Was mich aber zu meiner nächsten Frage bringt. gibt es eine Möglichkeit die Einstellung vom MS kpl MS, und die LMS einstellungen und Favoriten zu sichern, automatisch. per Job. Die Music daten liege eh nicht auf dem Server, diese Liegen auf einer NAS somit kein Problem
                    • duncan
                      • 351
                      #119
                      i now cant get a working installation of the beta on any of my previously working hardware
                      windows and/or linux install fully working without a hitch - using debian 10.4
                      ms4l beta installs
                      i can find and configure the usb csl sound cards
                      lms is up and running
                      when i create an internal zone, the system crashes the web server/interface and i see messages relating to mysql errors
                      the hardware is dell micro, i5, 8gb ram, 500gb sata ssd, csl 7.1 usb sound cards
                      it crashes whether using 1 or 2 sound cards
                      after the crash, the system reports having an internal zone, but the icon stays red and wont start
                      if i try to alter/delete the zone i get another crash
                      i have another PC exactly the same hardware which works with the 1st beta of 1 and debian 10.3 and has been upgraded to lastest software and its still working fine - all very odd
                      i also have a fujitsu intel i7 laptop 10gb ram and 500gb ssd that was working fine with the release version/ubuntu, but now i get the same problems of crashing with debian 10.4/ beta ms4l
                      Zuletzt geändert von duncan; 24.07.2020, 20:55.
                      • duncan
                        • 351
                        #120
                        answering my own problem here - i just went back to debian 10.3 iso net install and all my hardware now works perfectly! - must be an issue with 10.4 or the dvd1 iso i downloaded
                          tried to night a fresh installation on 10.4, from "net install iso" work like expected.
                          So looks like the used iso was the issue.
