Plugin: LoxBerry Backup
    Servus Johny,
    kannst du das Plugin mal auf DEBUG stellen, damit mehr geloggt wird.
    Ich hoffe nicht, dass der bei dir gezeigte Fehler, dass er irgendwas von Raspibackups Webseite nicht herunterladen kann, das Backup als fehlerhaft markiert…. Mal sehen.
    • Johny
      • 04.09.2016
      • 139
      #497
      Hallo Christian,
      hier mit DEBUG:
      HTML-Code:
      INFO: LoxBerry Version 2.2.2.2 ( is_raspberry.cfg )
      INFO: LoxBerry Backup Version 1.0.9
      INFO: Loglevel: 7
      OK: This backup is a Just-In-Time backup (not scheduled) -JIT options are used
      INFO: * JIT Backuptype is DDZ
      INFO: * JIT Destination is set to /opt/loxberry/system/storage/usb/000f1a84-01/backup
      INFO: Prepare JIT lock
      Reading config of backup type R::type = DDZ
      INFO: Try 1 to create destination directory
      INFO: Changing to directory /opt/loxberry/log/plugins/lbbackup
      OK: Starting backup
      INFO: sudo /usr/local/bin/raspiBackup.sh -N "fstab" -o ":" -a ":" -k 3 -t ddz -L current -l debug -m detailed -v /opt/loxberry/system/storage/usb/000f1a84-01/backup
      Script started on 2022-12-25 19:53:32+01:00 [ ]
      --- RBK0009I: loxberry: raspiBackup.sh V0.6.7-beta (2022-04-15/6f85dbe) started at Sun Dec 25 19:53:34 CET 2022.
      !!! RBK0165W: =========> NOTE <=========
      !!! RBK0165W: This is a betaversion and should not be used in production.
      --- RBK0116I: Using config file /usr/local/etc/raspiBackup.conf.
      --- RBK0031I: Checking whether a new version of raspiBackup.sh is available.
      ??? RBK0239E: Download of https://www.linux-tips-and-tricks.de/downloads/raspiBackup0613.properties/download?version=0.6.7-beta%1type=ddz%1mode=N%1keep=3%1func=B%1srs= failed. HTTP code: 404. RC: 0
      --- RBK0033I: Please wait until cleanup has finished.
      --- RBK0043I: Removing incomplete backup in /media/usb/000f1a84-01/backup/loxberry/loxberry-ddz-backup-20221225-195333. This may take some time. Please be patient.
      ??? RBK0005E: Backup failed. Check previous error messages for details.
      --- RBK0010I: loxberry: raspiBackup.sh V0.6.7-beta (6f85dbe) stopped at Sun Dec 25 19:53:39 CET 2022 with rc 135.
      --- RBK0026I: Debug logfile saved in /opt/loxberry/raspiBackup.log.
      Script done on 2022-12-25 19:53:39+01:00 [COMMAND_EXIT_CODE="135"]
      ERROR: Backup failed with error code 135
      INFO: Backup started at 25.12.2022 19:53:31 and finished at 25.12.2022 19:53:39
      INFO: Disk space info on /opt/loxberry/system/storage/usb/000f1a84-01/backup
      /dev/sda1 (/media/usb/000f1a84-01) | Size: 29.72 GB | Used: 13.02 GB | Free: 16.70 GB
      25.12.2022 19:53:41 TASK FINISHED
      Gruß, Johny
      • Johny
        • 04.09.2016
        • 139
        #498
        Ich glaub es hat sich erledigt. Ich habe gerade gesehen, dass in V 2.2.2 ein Backup mit dabei ist. Das hat auch funktioniert. Damit brauche ich das Plugin ja nicht mehr.
        Danke für die Hilfe!
        Gruß, Johny
        • meisterjäger
          • 15.06.2019
          • 75
          #499
          ich habe den prerelease von Loxberry 3.0 installiert und würde gern mit dem eingebaute Backup Plugin ein Backup auf einen USB Stick machen. Der Stick ist mit Windows auf NTFS formatiert. Wenn ich ihn in den Loxberry stecke kann ich ihn jedoch nicht im Backup Plugin auswählen es wird kein Eintrag angezeigt. Auch unter der Rubrik USB Storage taucht der Stick nicht auf (Keine USB Datenträger gefunden.). Wenn ich jedoch auf Formatieren gehe kann ich das USB Laufwerk auswählen. Habt ihr eine Idee? Für mich sieht es so aus als ob der Stick nicht gemountet wird aber das sollte ja automatisch funktionieren wie ich hier lesen konnte oder nicht?
        • herdan
          • 30.10.2021
          • 4
          #500
          Update 25.03.2023:
          Habe mich ein bisschen damit beschäftigt. Funktioniert nun doch. HIer kurz was die Lösung war. Vielleicht interessierts ja jemanden. Habe RaspiBackup nochmals nativ installiert um sicherzustellen, dass ich die neuste Version habe und alle anwählbahren Optionen/ Packete auch mitinstalliert werden. Die Ursprungsinstallation des raspiBackups gemacht via Plugin Loxberry habe ich vorgängig nicht gelöscht. Installations-/ resp. Ablageort nach meinem Verständis am gleichen Ort, da das ganze Plugin auch auf dem raspiBackup aufbaut. Dann die Datei /usr/local/bin/raspiBackup öffnen und unter misc other vars das Ganze wie im Bild ändern & auskommentieren.
          Nun kann auch mit einem Fremdystem, in meinem Fall ein Odroid N2+, ein Update via dem Loxone Plugin gemacht werden. Mit dem Plugin ist nicht das hauseigene, bereits installierte gemeint sondern das Plugin Loxberry Backup​. Ob das dann in jedem Fall funktioniert resp. das System nach dem Zurückspielen wieder läuft muss geprüft werden. Offizell gesupportet wird nur der Raspi. Wie gesagt, bei mir funzt das.
          Klicke auf die Grafik für eine vergrößerte Ansicht  Name: raspiBackup.jpg Ansichten: 0 Größe: 227,3 KB ID: 384206
          ​Hallo zusammen
          Habe eben Loxberry 3.0.0.2 auf einem Odroid N2+ aufgesetzt. Läuft super schnell (schneller als der Rasperri 4) mit passiver Kühlung. Finde das Ding auch bezüglich Stromverbrauch genial. Auch läuft alles soweit bis auf die Backups. Benutze sehr gerne das LoxBerry Backup- Plugin. Leider ist das aktuell das Einzige was ich nicht zum laufen bringe. Es kommt immer die untenstehende Meldung. Würde gerne die Option " --unsupportedEnvironment" nutzen. Weiss aber nicht wie.
          Leider geht auch die im Loxberry integrierte Backupfunktion nicht. Hier gibt es immer wieder Berechtigungsprobleme.
          Wäre genial, wenn mir jemand helfen könnte.
          Vielen Dank an dieser Stelle.
          Gruss
          Dan.03.2023 15:44:34 TASK STARTED
          LoxBerry Backup
          INFO: LoxBerry Version 3.0.0.2 ( is_arch_aarch64.cfg is_hwmodel_odroid_n2.cfg )
          INFO: Loglevel: 3
          Script started on 2023-03-21 15:44:35+01:00 [ ]
          ??? RBK0268E: Only Raspberries running Raspberry PI OS are supported. Use option --unsupportedEnvironment to invoke raspiBackup WITHOUT ANY SUPPORT.
          Script done on 2023-03-21 15:44:37+01:00 [COMMAND_EXIT_CODE="132"]
          ERROR: Backup failed with error code 132
          21.03.2023 15:44:37 TASK FINISHED
          Zuletzt geändert von herdan; 25.03.2023, 03:20.
          • framp
            • 31.08.2017
            • 47
            #501
            Ich hoffe Christian Fenzl kann Dir sagen wie Du die Option einpflegen kannst.
            Ansonsten bleibt Dir aus meiner Sicht nur uebrig raspiBackup native einzusetzen. Dort gibt es Moeglichkeiten diese Option in der Crontab einzupflegen. Du solltest aber vorher pruefen ob Backup und restore mir Odroid erfolgreich sind. Ich vermute aber das wird erfolgreich sein.
            • herdan
              herdan kommentierte
              Danke für die schnelle Antwort. Dann werde das ganze mal native ausprobieren. Ist halt etwas umständlicher aber geht sicherlich auch so.
          • toasty
            • 19.04.2017
            • 16
            #502
            Hi zusammen,
            bin hier etwas spät drüber gestolpert nachdem ich in github schon ein issue (
            https://github.com/christianTF/LoxBe...ckup/issues/38) eröffnet habe.
            Als workaround lokal bei mir habe ich die zeile 114 in
            /opt/loxberry/bin/plugins/lbbackup/runbackup.pl folgendermaßen geändert:
            @cmd = ("sudo",  "/usr/local/bin/raspiBackup.sh --unsupportedEnvironment");
            Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 262,9 KB ID: 385454
            Damit läuft bei mir das backup durch.
            Wäre natürlich cool wenn es zukünftig eine universelle Lösung gibt :-)
            Thorsten
            • toasty
              • 19.04.2017
              • 16
              #503
              hi zusammen,
              ich habe heute einen recovery test gemacht und kann (in meinem Setup) bestätigen, dass mein Raspberry Pi 3B (nicht B+) mit Loxberry V3.0.0.3 und DietPi v8.15.2 von einem Backup (DDZ) erfolgreich mit Win32DiskImager wiederhergestellt werden konnte.
              raspiBackup scheint also in der Kombi
              Raspberry Pi 3B / DietPi v8.15.2
              zu funktionieren.
              • Randy
                • 09.12.2020
                • 9
                #504
                Wollte gerade ein Backup machen (um das Problem mit dem Update zu lösen und die Boot-Partition zu erweitern) - backup läuft soweit durch, alles erfolgreich inkl. USB-Stick. Leider aber sagt die image-Datei stests "Daterträgerimagedatei bestchädigt" und kann auch nicht geöffnet werden von keinem Program. Jemand schonmal gehabt?
                • toasty
                  toasty kommentierte
                  Glaube das ist normal. vom windows pc kann man die img datei nicht öffnen. man bekommt die gleiche fehlermeldung wenn man z.B. die .img von DietPi direkt öffnet.
                • Randy
                  Randy kommentierte
                  Win32 kann aber ebenfalls das File nicht verifizieren - bekomme direkt diese Meldung, wenn ich versuche auf die neue Karte zu spielen. "Verification failed at sector: 0"
                Das Erweitern der Boot-Partition geht automatisch aber nur mit dem integrierten Backup-Widget, nicht mit dem LoxBerry Backup Plugin.
                Nicht dass du alles umsonst machst.
                • Mr.Willibald
                  • 14.10.2022
                  • 5
                  #506
                  Ich habe leider auch ein Problem mit den Backups. Zur Zeit habe ich einen USB-Stick am Loxberry hängen, auf den ich die Backups speichern lasse. Das funktioniert soweit problemlos.
                  Davor habe ich es allerdings mit dem Netzwerkshare einer FritzBox versucht, da hatte ich leider keinen Erfolg. Das Thema FritzBox ist aber auch mittlerweile abgehakt.
                  Deshalb baue mir jetzt aktuell ein NAS mit openmediavault auf und würde eigentlich die Backups gerne auf einen SMB-Share des NAS machen lassen. Das klonen der SD-Karte scheint soweit auch zu funktionieren, allerdings zerlegt es mir beim komprimieren den Zugriff auf das NAS. Es ist dann nicht mehr übers Netzwerk erreichbar. Erst nach einem Reboot kann ich wieder darauf zugreifen.
                  Gibt es da besondere Rechte, die ich fürs Backup und speziell fürs Komprimieren berücksichtigen muss? Was passiert beim Komprimieren, dass das NAS da so abschmieren kann?
                  Anbei habe ich noch das Log angehängt.
                  <LOGSTART> 18.04.2023 18:32:30 TASK STARTED
                  <LOGSTART> Clone SD card
                  <INFO> LoxBerry Version 3.0.0.5 ( is_raspberry.cfg is_arch_armv7l.cfg )
                  <INFO> Loglevel: 6
                  <INFO> Version of this script: 3.0.0.2
                  <INFO> Parameters: /opt/loxberry/system/storage/smb/openmediavault/LoxberryBackup/LoxberryBackup path 7z
                  <INFO> Executing user is root
                  <INFO> Executing command 'lsblk -b -O -J'...
                  <OK> Command executed successfully. - Exitcode 0
                  <INFO> Executing command 'findmnt / -b -J'...
                  <INFO> Executing command 'findmnt /boot -b -J'...
                  <INFO> /     is on partition /dev/mmcblk0p2
                  <INFO> /boot is on partition /dev/mmcblk0p1
                  <INFO> Boot device is mmcblk0
                  <INFO> Your boot device (SOURCE of clone):
                  <INFO>    -> Partition mmcblk0p1 Size 256.0MB VFAT
                  <INFO>    -> Partition mmcblk0p2 Size 29.5GB EXT4
                  <INFO> Destination device is openmediavault::LoxberryBackup (938 GB) (/opt/loxberry/system/storage/smb/openmediavault/LoxberryBackup) available space 932.6GB
                  <INFO> Waiting 15s in case you changed your mind...
                  <INFO> Too late - let the game begin!
                  <INFO> Creating destination image file, size 4.6GB
                  <INFO> Executing command 'sudo -u loxberry dd if=/dev/zero of=/opt/loxberry/system/storage/smb/openmediavault/LoxberryBackup/LoxberryBackup/loxberry_image_20230418_183231.img bs=1 count=0 seek=4927874048'...
                  <INFO> Creating partiton table
                  <INFO> Executing command 'parted -s /opt/loxberry/system/storage/smb/openmediavault/LoxberryBackup/LoxberryBackup/loxberry_image_20230418_183231.img mklabel msdos'...
                  <INFO> Creating new boot partition
                  <INFO> Executing command 'parted -s /opt/loxberry/system/storage/smb/openmediavault/LoxberryBackup/LoxberryBackup/loxberry_image_20230418_183231.img mkpart primary fat32 4MiB 256MiB'...
                  <INFO> Creating new root partition
                  <INFO> Executing command 'parted -s /opt/loxberry/system/storage/smb/openmediavault/LoxberryBackup/LoxberryBackup/loxberry_image_20230418_183231.img mkpart primary ext4 256MiB 100%'...
                  <INFO> Create loop devices for all partitions in image file /opt/loxberry/system/storage/smb/openmediavault/LoxberryBackup/LoxberryBackup/loxberry_image_20230418_183231.img
                  <INFO> Executing command 'losetup -f --show -P /opt/loxberry/system/storage/smb/openmediavault/LoxberryBackup/LoxberryBackup/loxberry_image_20230418_183231.img'...
                  <INFO> Formatting fat32 boot partition (takes a second)
                  <INFO> Executing command 'mkfs.vfat -F 32 /dev/loop0p1'...
                  <INFO> Formatting ext4 data partition (takes a minute or two)
                  <INFO> Executing command 'mkfs.ext4 /dev/loop0p2'...
                  <INFO> Creating temporary mounts for copying the data
                  <INFO> Checking mounts (try 1)
                  <INFO> Mounting /media/dst2 to /dev/loop0p2
                  <INFO> Executing command 'mount /dev/loop0p2 /media/dst2'...
                  <INFO> Executing command 'findmnt /media/dst2 -b -J'...
                  <INFO> Mounting /media/src1 to /dev/mmcblk0p1
                  <INFO> Executing command 'mount /dev/mmcblk0p1 /media/src1'...
                  <INFO> Executing command 'findmnt /media/src1 -b -J'...
                  <INFO> Mounting /media/src2 to /dev/mmcblk0p2
                  <INFO> Executing command 'mount /dev/mmcblk0p2 /media/src2'...
                  <INFO> Executing command 'findmnt /media/src2 -b -J'...
                  <INFO> Mounting /media/dst1 to /dev/loop0p1
                  <INFO> Executing command 'mount /dev/loop0p1 /media/dst1'...
                  <INFO> Executing command 'findmnt /media/dst1 -b -J'...
                  <INFO> Copy data of boot partition (this will take some seconds only)
                  <INFO> Executing command 'cd /media/src1 && tar cSp --numeric-owner --warning='no-file-ignored' --exclude='swap' -f - . | (cd /media/dst1 && tar xSpf - )'...
                  <INFO> Copy data of root partition (this may take a long time... Please be patient.)
                  <INFO> Executing command 'cd /media/src2 && tar cSp --numeric-owner --warning='no-file-ignored' --exclude='swap' -f - . | (cd /media/dst2 && tar xSpf - )'...
                  <INFO> Resize SDcard after first boot again
                  <INFO> Change the PTUUID of destination card to 4bd27daf
                  <INFO> Checking the clone...
                  <INFO> Checking if your destination device/path still exists.
                  <OK> That looks good.
                  <INFO> Checking if all destination mountpoints still exist.
                  <INFO> Find mountpoint /media/dst2
                  <INFO> Find mountpoint /media/src1
                  <INFO> Find mountpoint /media/src2
                  <INFO> Find mountpoint /media/dst1
                  <INFO> Checking image size: 4927874048 Bytes, target was 4927874048 Bytes.
                  <INFO> Checking correct PTUUID.
                  <INFO> Try to remount boot partition in image.
                  <INFO> Executing command 'mkdir -p /media/test_loxberrybackup'...
                  <INFO> Executing command 'mount /dev/loop0p1 /media/test_loxberrybackup'...
                  <INFO> Executing command 'umount -f /media/test_loxberrybackup'...
                  <INFO> Try to remount root partition in image.
                  <INFO> Executing command 'mount /dev/loop0p2 /media/test_loxberrybackup'...
                  <INFO> Compressing your image. This may take a long time... Please be patient.
                  <INFO> Executing command 'sudo -u loxberry 7z a /opt/loxberry/system/storage/smb/openmediavault/LoxberryBackup/LoxberryBackup/loxberry_image_20230418_183231.img.7z /opt/loxberry/system/storage/smb/openmediavault/LoxberryBackup/LoxberryBackup/loxberry_image_20230418_183231.img -mx3'...
                  <ERROR> ERROR executing command - Exitcode 2
                  <ERROR> Something went wrong while compressing the image. I keep the uncompressed image.
                  <INFO> You have to flash the created image onto an empty SDcard!
                  <INFO> If it fails to boot, connect a display to Raspberry to check what happens.
                  <LOGEND> Finished
                  <LOGEND> 18.04.2023 19:01:43 TASK FINISHED
                  • Noschvie
                    Noschvie kommentierte
                    Hast du schon mal „Komprimiertes DD-Image (DDZ)“ probiert?
                    Mr.Willibald
                    Wenn du weitere Hilfe brauchst, ichvhabe für das Backup Widget einen eigenen Thread erstellt: https://www.loxforum.com/forum/proje...-backup-widget
                  • Mr.Willibald
                    Mr.Willibald kommentierte
                    Christian hat Recht, meine Frage bezieht sich eigentlich auf das Backup Widget.
                    Ich habe jetz mal den Pfad verändert und den Unterordner "LoxberryBackup", der genauso heißt, wie der SMB-Share, weggelassen und jetzt gehts.
                    Vielen Dank aber für eure Hilfe.
                  Das Komprimieren liest und schreibt Daten auf deinen Share.
                  Wenn es dabei dein NAS zerlegt, müsstest du dort mal auf Fehlersuche gehen.
                  Das unkomprimierte Image müsste aber laut Log da sein.
                  LG Christian
                    Fragen zum in LoxBerry integrierten Backup Widget bitte hier: https://www.loxforum.com/forum/proje...-backup-widget
                    Das LoxBerry Backup Plugin hat mit dem Backup Widget überhaupt nichts gemein, es ist ein komplett anderer Code.
                    • schildkroete
                      • 22.09.2021
                      • 64
                      #509
                      Moin,
                      ich wollte gerade das Backup konfigurieren, nutze allerdings Loxberry auf einem Odroid C4.
                      Dazu gibt es auch einen PR (https://github.com/christianTF/LoxBe...Backup/pull/39).
                      Hat der PR eine Chance?
                      Und gibt es Erfahrungswerte, wie gut das mit einem Restore auf "unsupported Environments" funktioniert?
                      • framp
                        • 31.08.2017
                        • 47
                        #510
                        Mir fehlt es an einem Odroid C4 um raspiBackup auf der HW und SW zu testen. Getestet und supported ist nur RaspbianOS auf einer Raspberry. Nutze einfach die Option um raspiBackup auf Deiner HW zu starten und pruefe ob der Backup und Restore erfolgreich ist. Ich denke es wird funktionieren - aber weiss es mangels HW natuerlich nicht.
