  • windflyer
    • 03.11.2017
    • 55
    #436
    bei mir ähnlich… wollte das plugin heute installieren, leider läuft es nicht durch!
  • .:Chris:.
    • 05.01.2016
    • 202
    #437
    hier mein Fehlerprotokoll, ist identisch zu windflyer
    <INFO> Downloading https://github.com/mschlenstedt/LoxBerry-Plugin-Stats4Lox-NG/archive/refs/tags/0.9.8.zip ...
    We are in CGI mode.
    27.10.2022 07:54:53 <INFO> Statusfile: /tmp/ShXDJcgkkU.status
    27.10.2022 07:54:53 <INFO> Temp Folder: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU
    27.10.2022 07:54:53 <INFO> Logfile: /tmp/ShXDJcgkkU.log
    27.10.2022 07:54:53 <INFO> Locking plugininstall - delaying up to 10 minutes...
    27.10.2022 07:54:53 <OK> Lock successfully set.
    27.10.2022 07:54:53 <INFO> Starting Plugin installation.
    27.10.2022 07:54:53 <INFO> Extracting plugin archive
    27.10.2022 07:54:53 <INFO> Command: /usr/bin/sudo -n -u loxberry /usr/bin/unzip -d /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU.zip
    Archive:  /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU.zip
    56472a5d1ffd53c1e9c552d05eea31ee5a6bae09
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/.gitattributes
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/.gitignore
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/LICENSE
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/README.md
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/config-handler.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/create_element_langfiles.pl
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/debugging/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/debugging/debug_stats.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/debugging/showconfig.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/debugging/updatepanel.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/import_loxone.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/import_scheduler.pl
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Globals.pm
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Grafana.pm
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/GrafanaS4L.pm
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/GetLoxplan.pm
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/Import.pm
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/ParseXML.pm
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/unpack_loxcc.py
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/unpack_loxcc_py2_obsolete.py
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Stats4Lox.pm
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/filechangeTracker.php
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/getLineformat.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/getLoxplan.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/getTelegrafInternals.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/getValue.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/parseLocalLoxplan.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/parseLocalStatfile.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/searchReplace.sh
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/sendTelegraf.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/testTOML.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/testXML.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/testtimestamps.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/testtimestamps_workaround.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/loadLoxoneMiniserverStatistics.py
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/loadMiniserverConfigurationFile.py
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/lox2telegraf.pl
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/mqtt/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/mqtt/mqttlive.php
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/mqtt/phpMQTT.php
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/delete_datasource_influx.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/set_dashboard_provider.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/set_datasource_influx.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/update_dashboards.pl
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/s4linflux
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/startinflux.sh
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/cred.json
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/grafana.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/ldap.toml
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/dashboards/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/dashboards/sample.yaml
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/dashboards/stats4lox_static.yaml
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/datasources/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/datasources/sample.yaml
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/notifiers/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/notifiers/sample.yaml
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/plugins/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/plugins/sample.yaml
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/influxdb/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/influxdb/influxdb.conf
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/provisioning/
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/provisioning/dashboards/
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/provisioning/dashboards/.dummy
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/stats.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/stats4lox.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/sysctl.conf
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/systemd/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/systemd/00-stats4lox-grafana.conf
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/systemd/00-stats4lox-influxdb.conf
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/systemd/00-stats4lox-telegraf.conf
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.conf
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_debug.conf
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_internal.conf
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_loxberry.conf
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_loxone.conf
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_miniserver.conf
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_socketlistener_udp.conf
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_socketlistener_unix.conf
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.env
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/cron/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/cron/cron.reboot
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/plugininstall/
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/plugininstall/.dummy
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/system/
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/system/.dummy
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/user/
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/user/.dummy
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/grafana/
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/grafana/.dummy
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/import/
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/import/.dummy
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/influxdb/
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/influxdb/.dummy
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/telegraf/
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/telegraf/.dummy
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/dpkg/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/dpkg/apt
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/icons/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/icons/icon_128.png
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/icons/icon_256.png
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/icons/icon_512.png
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/icons/icon_64.png
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/plugin.cfg
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/postroot.sh
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/postupgrade.sh
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/preroot.sh
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/preupgrade.sh
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/sudoers/
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/sudoers/sudoers
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/chartengines.html
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/dashboards/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/dashboards/internals.json
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/templates/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/templates/Dashboard with 1 panel.txt
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/templates/template_defaultDashboard.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/templates/template_panel_graph.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/home.html
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/input_mqtt.html
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/language_en.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ca.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ca.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ch.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ch.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_cs.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_cs.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_de.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_de.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_en.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_en.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_es.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_es.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_fr.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_fr.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_hu.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_hu.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_it.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_it.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_nl.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_nl.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_no.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_no.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_pl.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_pl.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ro.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ro.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ru.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ru.json
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_sk.ini
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_sk.json
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/logs.html
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/loxone_import_report.html
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/mqttlive_loxone.html
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/output_influx.html
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/settings_loxone.html
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/uninstall/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/uninstall/uninstall
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/ajax.cgi
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/chartengines.cgi
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/grabber/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/grabber/grabber_loxone.cgi
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/grabber/grabber_miniserver.cgi
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_alert.png
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_alert_20.png
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_checked.png
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_checked_20.png
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_scheduled.psd
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_scheduled_20.png
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_unchecked.png
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_unchecked.psd
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_unchecked_20.png
     extracting: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/import_icon.png
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/index.cgi
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/input_mqtt.cgi
       creating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/home.js
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/input_mqtt.js
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/inputs_outputs_sub_navbar.js
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/loxone_import_report.js
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/loxone_sub_navbar.js
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/menu_structure (obsolete).js
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/mqttlive_loxone.js
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/settings_loxone.js
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/vue.global.js
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/logs.cgi
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/loxone_import_report.cgi
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/main_loxone.cgi
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/mqttlive_loxone.cgi
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/output_influx.cgi
      inflating: /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/test.pl
    27.10.2022 07:54:53 <OK> Plugin archive extracted successfully.
    27.10.2022 07:54:53 <INFO> Author:         The Stats4Lox Team
    27.10.2022 07:54:53 <INFO> Email:          Michael@loxberry.de
    27.10.2022 07:54:53 <INFO> Version:        0.9.8
    27.10.2022 07:54:53 <INFO> Name:           stats4lox
    27.10.2022 07:54:53 <INFO> Folder:         stats4lox
    27.10.2022 07:54:53 <INFO> Title:          Stats4Lox
    27.10.2022 07:54:53 <INFO> Autoupdate:     False
    27.10.2022 07:54:53 <INFO> Release:
    27.10.2022 07:54:53 <INFO> Prerelease:
    27.10.2022 07:54:53 <INFO> Reboot:         False
    27.10.2022 07:54:53 <INFO> Min LB Vers:    2.2.1.1
    27.10.2022 07:54:53 <INFO> Max LB Vers:    False
    27.10.2022 07:54:53 <INFO> Architecture:   False
    27.10.2022 07:54:53 <INFO> Custom Log:     True
    27.10.2022 07:54:53 <INFO> Interface:      2.0
    27.10.2022 07:54:53 <OK> All mandatory configuration parameters found.
    27.10.2022 07:54:53 <INFO> Current LoxBerry version: v2.2.1.2
    27.10.2022 07:54:53 <INFO> Installation limited from: v2.2.1.1
    27.10.2022 07:54:53 <OK> Current LoxBerry version is greater than minimal required LoxBerry version.
    27.10.2022 07:54:53 <INFO> Plugin is already installed -> proceeding with upgrade.
    27.10.2022 07:54:53 <OK> Found free database entry.
    27.10.2022 07:54:53 <INFO> Using plugin name: stats4lox
    27.10.2022 07:54:53 <INFO> Using installation folder: stats4lox
    27.10.2022 07:54:53 <INFO> Creating shadow version of plugindatabase.
    '/opt/loxberry/data/system/plugindatabase.json' -> '/opt/loxberry/data/system/plugindatabase.json-'
    27.10.2022 07:54:53 <INFO> Setting file permissions: /bin/chmod -v 644 /opt/loxberry/data/system/plugindatabase.json-
    mode of '/opt/loxberry/data/system/plugindatabase.json-' retained as 0644 (rw-r--r--)
    27.10.2022 07:54:53 <OK> File permissions set successfully.
    27.10.2022 07:54:53 <INFO> Setting file ownership: /bin/chown -v root.root /opt/loxberry/data/system/plugindatabase.json-
    ownership of '/opt/loxberry/data/system/plugindatabase.json-' retained as root:root
    27.10.2022 07:54:53 <OK> File ownership set successfully.
    '/opt/loxberry/data/system/plugindatabase.json' -> '/opt/loxberry/data/system/plugindatabase.json.bkp'
    27.10.2022 07:54:53 <INFO> Setting file permissions: /bin/chmod -v 644 /opt/loxberry/data/system/plugindatabase.json.bkp
    mode of '/opt/loxberry/data/system/plugindatabase.json.bkp' retained as 0644 (rw-r--r--)
    27.10.2022 07:54:53 <INFO> Setting file ownership: /bin/chown -v loxberry.loxberry /opt/loxberry/data/system/plugindatabase.json.bkp
    ownership of '/opt/loxberry/data/system/plugindatabase.json.bkp' retained as loxberry:loxberry
    27.10.2022 07:54:53 <INFO> Getting file list from /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8
    27.10.2022 07:54:53 <INFO> Found 153 files
    27.10.2022 07:54:53 <INFO> Filtering out binary files
    27.10.2022 07:54:54 <INFO>   20 textfiles found out of 20 files scanned...
    27.10.2022 07:54:54 <INFO>   40 textfiles found out of 40 files scanned...
    27.10.2022 07:54:55 <INFO>   59 textfiles found out of 60 files scanned...
    27.10.2022 07:54:56 <INFO>   71 textfiles found out of 80 files scanned...
    27.10.2022 07:54:56 <INFO>   81 textfiles found out of 100 files scanned...
    27.10.2022 07:54:57 <INFO>   91 textfiles found out of 120 files scanned...
    27.10.2022 07:54:57 <INFO>   109 textfiles found out of 140 files scanned...
    27.10.2022 07:54:58 <INFO>   122 textfiles found out of 153 files scanned...
    27.10.2022 07:54:58 <OK> Found 122 files to be text files
    27.10.2022 07:54:58 <INFO> Checking for hardcoded paths to /opt/loxberry
    27.10.2022 07:54:58 <OK> No hardcoded paths to /opt/loxberry found
    27.10.2022 07:54:58 <INFO> Replacing environment strings.
    27.10.2022 07:54:58 <INFO> Running replacement for 122 files
    27.10.2022 07:55:00 <INFO>   20 of 122 finished ...
    27.10.2022 07:55:01 <INFO>   40 of 122 finished ...
    27.10.2022 07:55:03 <INFO>   60 of 122 finished ...
    27.10.2022 07:55:05 <INFO>   80 of 122 finished ...
    27.10.2022 07:55:07 <INFO>   100 of 122 finished ...
    27.10.2022 07:55:09 <INFO>   120 of 122 finished ...
    27.10.2022 07:55:09 <OK> Replace of 122 files finished
    27.10.2022 07:55:09 <INFO> Converting all plugin files (ASCII) to Unix fileformat.
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/preroot.sh to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/postupgrade.sh to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/README.md to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/plugin.cfg to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/LICENSE to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/postroot.sh to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/preupgrade.sh to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/loadLoxoneMiniserverStatistics.py to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/import_loxone.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/config-handler.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/lox2telegraf.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/loadMiniserverConfigurationFile.py to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/s4linflux to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/create_element_langfiles.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/startinflux.sh to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/import_scheduler.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/debugging/showconfig.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/debugging/debug_stats.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/debugging/updatepanel.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/delete_datasource_influx.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/set_datasource_influx.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/set_dashboard_provider.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/update_dashboards.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/mqtt/phpMQTT.php to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/mqtt/mqttlive.php to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Grafana.pm to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Stats4Lox.pm to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/filechangeTracker.php to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Globals.pm to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/GrafanaS4L.pm to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/testtimestamps.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/getValue.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/parseLocalLoxplan.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/testXML.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/getLoxplan.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/searchReplace.sh to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/testTOML.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/sendTelegraf.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/getTelegrafInternals.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/testtimestamps_workaround.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/parseLocalStatfile.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/getLineformat.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/Import.pm to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/unpack_loxcc.py to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/unpack_loxcc_py2_obsolete.py to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/ParseXML.pm to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/GetLoxplan.pm to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/cron/cron.reboot to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/sudoers/sudoers to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/uninstall/uninstall to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/input_mqtt.html to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/home.html to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/logs.html to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/output_influx.html to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/settings_loxone.html to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/mqttlive_loxone.html to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/chartengines.html to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/loxone_import_report.html to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_hu.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_es.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ch.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/language_en.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ru.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ro.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ca.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_nl.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_it.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_pl.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_de.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_no.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_en.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_cs.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_fr.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_sk.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/dashboards/internals.json to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/templates/Dashboard with 1 panel.txt to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/templates/template_defaultDashboard.json to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/templates/template_panel_graph.json to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/dpkg/apt to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/ajax.cgi to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/index.cgi to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/input_mqtt.cgi to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/mqttlive_loxone.cgi to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/test.pl to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/output_influx.cgi to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/chartengines.cgi to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/main_loxone.cgi to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/logs.cgi to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/loxone_import_report.cgi to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/grabber/grabber_loxone.cgi to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/grabber/grabber_miniserver.cgi to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/vue.global.js to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/menu_structure (obsolete).js to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/home.js to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/inputs_outputs_sub_navbar.js to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/loxone_sub_navbar.js to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/input_mqtt.js to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/mqttlive_loxone.js to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/settings_loxone.js to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/loxone_import_report.js to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/stats.json to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/sysctl.conf to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/influxdb/influxdb.conf to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/ldap.toml to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/grafana.ini to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/datasources/sample.yaml to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/plugins/sample.yaml to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/dashboards/stats4lox_static.yaml to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/dashboards/sample.yaml to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/notifiers/sample.yaml to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/systemd/00-stats4lox-influxdb.conf to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/systemd/00-stats4lox-grafana.conf to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/systemd/00-stats4lox-telegraf.conf to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.env to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.conf to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_loxone.conf to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_debug.conf to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_loxberry.conf to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_miniserver.conf to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_socketlistener_unix.conf to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_internal.conf to Unix format...
    dos2unix: converting file /opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_socketlistener_udp.conf to Unix format...
    27.10.2022 07:55:19 <INFO> Starting script PREROOT.
    27.10.2022 07:55:19 <INFO> Command: cd "/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8" && "/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/preroot.sh" "ShXDJcgkkU" "stats4lox" "stats4lox" "0.9.8" "/opt/loxberry" "/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8"
    mode of '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/preroot.sh' retained as 0755 (rwxr-xr-x)
    <INFO> Stopping InfluxDB, Grafana and Telegraf.
    /usr/bin/influxd: no process found
    <INFO> Adding/Updating Influx repository...
    OK
    deb https://repos.influxdata.com/debian buster stable
    <INFO> Using Influx Version 1.8.x...
    <INFO> Using Grafana Version 9.2.x...
    <INFO> Adding/Updating Grafana repository...
    OK
    deb https://packages.grafana.com/oss/deb stable main
    <INFO> Updating apt database...
    Reading package lists...
    Building dependency tree...
    Reading state information...
    0 upgraded, 0 newly installed, 0 to remove and 167 not upgraded.
    Hit:1 http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
    Hit:4 https://repos.influxdata.com/debian buster InRelease
    Hit:5 https://packages.grafana.com/oss/deb stable InRelease
    Hit:6 https://dl.yarnpkg.com/debian stable InRelease
    <INFO> Deactivating existing plugin configuration for Influx, Grafana and Telegraf...
    <INFO> Remove old Service DropIn Files...
    <INFO> Chown data files back to loxberry:loxberry for upgrading/backing up...
    27.10.2022 07:56:14 <OK> Script executed successfully.
    27.10.2022 07:56:14 <INFO> Starting script PREUPGRADE.
    27.10.2022 07:56:14 <INFO> Command: cd "/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8" && /usr/bin/sudo -n -u loxberry "/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/preupgrade.sh" "ShXDJcgkkU" "stats4lox" "stats4lox" "0.9.8" "/opt/loxberry" "/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8"
    mode of '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/preupgrade.sh' retained as 0755 (rwxr-xr-x)
    <INFO> Stopping services influxdb and telegraf for upgrade.
    <INFO> Stopping internal services for upgrade.
    <INFO> Creating temporary folders for upgrading.
    <INFO> Backing up existing config files.
    sending incremental file list
    cred.json
    stats.json
    stats4lox.json
    sysctl.conf
    grafana/
    grafana/grafana.ini
    grafana/ldap.toml
    grafana/provisioning/dashboards/stats4lox.yaml
    grafana/provisioning/datasources/stats4lox.yaml
    influxdb/
    influxdb/influxdb-selfsigned.crt
    influxdb/influxdb-selfsigned.key
    provisioning/
    provisioning/dashboards/defaultDashboard.json
    systemd/
    telegraf/
    telegraf/.cache/
    telegraf/.cache/snowflake/
    telegraf/.cache/snowflake/ocsp_response_cache.json
    sent 679,654 bytes  received 681 bytes  1,360,670.00 bytes/sec
    total size is 676,647  speedup is 0.99
    <INFO> Backing up existing log files.
    20221026_220024_171_AJAX.log
    20221026_220029_119_AJAX.log
    20221026_220034_104_AJAX.log
    20221026_220039_124_AJAX.log
    20221026_220044_138_AJAX.log
    20221026_220049_132_AJAX.log
    20221026_220054_158_AJAX.log
    20221026_220059_172_AJAX.log
    20221026_220104_168_AJAX.log
    20221026_220109_174_AJAX.log
    20221026_220114_195_AJAX.log
    20221026_220119_193_AJAX.log
    20221026_220124_210_AJAX.log
    20221026_220129_203_AJAX.log
    20221026_233140_254_AJAX.log
    20221026_233140_731_AJAX.log
    20221026_233142_240_AJAX.log
    20221026_233147_173_AJAX.log
    20221026_233152_219_AJAX.log
    20221026_233157_210_AJAX.log
    20221026_233202_155_AJAX.log
    20221026_233208_209_AJAX.log
    20221026_233213_165_AJAX.log
    20221026_233218_192_AJAX.log
    20221027_073416_047_AJAX.log
    20221027_073419_318_AJAX.log
    20221027_073424_290_AJAX.log
    20221027_073429_331_AJAX.log
    20221027_073434_358_AJAX.log
    20221027_073440_440_AJAX.log
    20221027_073457_453_AJAX.log
    20221027_073502_470_AJAX.log
    20221027_073507_456_AJAX.log
    20221027_073512_574_AJAX.log
    20221027_073517_585_AJAX.log
    20221027_073522_536_AJAX.log
    20221027_073528_432_AJAX.log
    20221027_073533_429_AJAX.log
    20221027_073538_479_AJAX.log
    20221027_073543_531_AJAX.log
    20221027_073548_545_AJAX.log
    20221027_073553_488_AJAX.log
    20221027_073559_455_AJAX.log
    20221027_073604_547_AJAX.log
    20221027_073609_471_AJAX.log
    20221027_073614_539_AJAX.log
    20221027_073619_496_AJAX.log
    20221027_073624_518_AJAX.log
    20221027_073631_328_AJAX.log
    import_scheduler.log
    mqttlive.log
    mqttlive.log.gz
    mqttlive_lox2telegraf.log
    sent 1,032,773 bytes  received 1,023 bytes  2,067,592.00 bytes/sec
    total size is 1,028,898  speedup is 1.00
    <INFO> Backing up existing data files.
    ms1.json
    backups/
    backups/plugininstall/20220918201307_backup_plugininstall.7z
    backups/plugininstall/20221026090417_backup_plugininstall.7z
    backups/plugininstall/20221027074510_backup_plugininstall.7z
    backups/system/
    backups/user/
    backups/user/.dummy
    grafana/
    grafana/.dummy
    grafana/grafana.db
    grafana/grafana.log
    grafana/grafana.log.2022-10-23.001
    grafana/grafana.log.2022-10-25.001
    grafana/grafana.log.2022-10-26.001
    grafana/alerting/
    grafana/alerting/1/
    grafana/alerting/1/__default__.tmpl
    grafana/csv/
    grafana/png/
    import/
    import/.dummy
    import/import_1_0f2bc193-021b-0653-ffffc9ef1f112e83.json
    import/import_1_0f2bc193-021b-0653-ffffc9ef1f112e83.json.log
    import/import_1_0f2bc19c-02a7-7bf2-ffffb01063838c24.json
    import/import_1_0f2bc19c-02a7-7bf2-ffffb01063838c24.json.log
    import/import_1_0f2bc19c-02a7-b6f8-ffffa3d109ca3902.json
    import/import_1_0f2bc19c-02a7-b6f8-ffffa3d109ca3902.json.log
    influxdb/
    influxdb/.dummy
    influxdb/data/
    influxdb/data/_internal/
    influxdb/data/_internal/_series/
    influxdb/data/_internal/_series/00/
    influxdb/data/_internal/_series/00/0000
    influxdb/data/_internal/_series/01/
    influxdb/data/_internal/_series/01/0000
    influxdb/data/_internal/_series/02/
    influxdb/data/_internal/_series/02/0000
    influxdb/data/_internal/_series/03/
    influxdb/data/_internal/_series/03/0000
    influxdb/data/_internal/_series/04/
    influxdb/data/_internal/_series/04/0000
    influxdb/data/_internal/_series/05/
    influxdb/data/_internal/_series/05/0000
    influxdb/data/_internal/_series/06/
    influxdb/data/_internal/_series/06/0000
    influxdb/data/_internal/_series/07/
    influxdb/data/_internal/_series/07/0000
    influxdb/data/_internal/monitor/
    influxdb/data/_internal/monitor/1/
    influxdb/data/_internal/monitor/1/fields.idx
    influxdb/data/stats4lox/
    influxdb/data/stats4lox/_series/
    influxdb/data/stats4lox/_series/00/
    influxdb/data/stats4lox/_series/00/0000
    influxdb/data/stats4lox/_series/01/
    influxdb/data/stats4lox/_series/01/0000
    influxdb/data/stats4lox/_series/02/
    influxdb/data/stats4lox/_series/02/0000
    influxdb/data/stats4lox/_series/03/
    influxdb/data/stats4lox/_series/03/0000
    influxdb/data/stats4lox/_series/04/
    influxdb/data/stats4lox/_series/04/0000
    influxdb/data/stats4lox/_series/05/
    influxdb/data/stats4lox/_series/05/0000
    influxdb/data/stats4lox/_series/06/
    influxdb/data/stats4lox/_series/06/0000
    influxdb/data/stats4lox/_series/07/
    influxdb/data/stats4lox/_series/07/0000
    influxdb/data/stats4lox/autogen/
    influxdb/data/stats4lox/autogen/2/
    influxdb/data/stats4lox/autogen/2/fields.idx
    influxdb/meta/
    influxdb/meta/meta.db
    influxdb/wal/
    influxdb/wal/_internal/
    influxdb/wal/_internal/monitor/
    influxdb/wal/_internal/monitor/1/
    influxdb/wal/_internal/monitor/1/_00001.wal
    influxdb/wal/stats4lox/
    influxdb/wal/stats4lox/autogen/
    influxdb/wal/stats4lox/autogen/2/
    influxdb/wal/stats4lox/autogen/2/_00001.wal
    telegraf/
    telegraf/.dummy
    sent 91,771,187 bytes  received 1,120 bytes  2,383,696.29 bytes/sec
    total size is 91,744,383  speedup is 1.00
    <INFO> Cleaning old temporary files
    27.10.2022 07:56:52 <OK> Script executed successfully.
    27.10.2022 07:56:52 <INFO> Removing old installation.
    27.10.2022 07:56:52 <INFO> Removing cron jobs
    27.10.2022 07:56:53 <INFO> Deleting uninstall file
    27.10.2022 07:57:02 <INFO> Deleting daemon
    27.10.2022 07:57:02 <INFO> Deleting sudoers file
    27.10.2022 07:57:03 <INFO> Deleting plugin folders
    27.10.2022 07:57:04 <INFO> Deleting plugin icons
    27.10.2022 07:57:04 <INFO> Installing configuration files.
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/cred.json' -> '/opt/loxberry/config/plugins/stats4lox/cred.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana' -> '/opt/loxberry/config/plugins/stats4lox/grafana'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning' -> '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/dashboards' -> '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/dashboards'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/dashboards/stats4lox_static.yaml' -> '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/dashboards/stats4lox_static.yaml'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/dashboards/sample.yaml' -> '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/dashboards/sample.yaml'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/datasources' -> '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/datasources'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/datasources/sample.yaml' -> '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/datasources/sample.yaml'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/notifiers' -> '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/notifiers'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/notifiers/sample.yaml' -> '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/notifiers/sample.yaml'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/plugins' -> '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/plugins'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/provisioning/plugins/sample.yaml' -> '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/plugins/sample.yaml'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/grafana.ini' -> '/opt/loxberry/config/plugins/stats4lox/grafana/grafana.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/grafana/ldap.toml' -> '/opt/loxberry/config/plugins/stats4lox/grafana/ldap.toml'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/influxdb' -> '/opt/loxberry/config/plugins/stats4lox/influxdb'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/influxdb/influxdb.conf' -> '/opt/loxberry/config/plugins/stats4lox/influxdb/influxdb.conf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/provisioning' -> '/opt/loxberry/config/plugins/stats4lox/provisioning'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/provisioning/dashboards' -> '/opt/loxberry/config/plugins/stats4lox/provisioning/dashboards'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/provisioning/dashboards/.dummy' -> '/opt/loxberry/config/plugins/stats4lox/provisioning/dashboards/.dummy'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/stats.json' -> '/opt/loxberry/config/plugins/stats4lox/stats.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/stats4lox.json' -> '/opt/loxberry/config/plugins/stats4lox/stats4lox.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/sysctl.conf' -> '/opt/loxberry/config/plugins/stats4lox/sysctl.conf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/systemd' -> '/opt/loxberry/config/plugins/stats4lox/systemd'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/systemd/00-stats4lox-influxdb.conf' -> '/opt/loxberry/config/plugins/stats4lox/systemd/00-stats4lox-influxdb.conf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/systemd/00-stats4lox-grafana.conf' -> '/opt/loxberry/config/plugins/stats4lox/systemd/00-stats4lox-grafana.conf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/systemd/00-stats4lox-telegraf.conf' -> '/opt/loxberry/config/plugins/stats4lox/systemd/00-stats4lox-telegraf.conf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf' -> '/opt/loxberry/config/plugins/stats4lox/telegraf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.env' -> '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.env'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.conf' -> '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.conf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d' -> '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_miniserver.conf' -> '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_miniserver.conf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_socketlistener_unix.conf' -> '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_socketlistener_unix.conf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_loxberry.conf' -> '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_loxberry.conf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_internal.conf' -> '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_internal.conf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_socketlistener_udp.conf' -> '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_socketlistener_udp.conf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_debug.conf' -> '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_debug.conf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/config/telegraf/telegraf.d/stats4lox_loxone.conf' -> '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_loxone.conf'
    27.10.2022 07:57:04 <OK> All file(s) were installed successfully.
    27.10.2022 07:57:04 <INFO> Setting file ownership: /bin/chown -Rv loxberry.loxberry /opt/loxberry/config/plugins/stats4lox
    ownership of '/opt/loxberry/config/plugins/stats4lox/stats4lox.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/cred.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/provisioning/dashboards/.dummy' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/provisioning/dashboards' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/provisioning' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/stats.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/influxdb/influxdb.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/influxdb' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/datasources/sample.yaml' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/datasources' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/plugins/sample.yaml' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/plugins' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/dashboards/stats4lox_static.yaml' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/dashboards/sample.yaml' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/dashboards' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/notifiers/sample.yaml' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning/notifiers' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana/provisioning' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana/ldap.toml' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana/grafana.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/grafana' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/systemd/00-stats4lox-influxdb.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/systemd/00-stats4lox-grafana.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/systemd/00-stats4lox-telegraf.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/systemd' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/sysctl.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.env' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_loxone.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_debug.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_loxberry.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_miniserver.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_socketlistener_unix.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_internal.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d/stats4lox_socketlistener_udp.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.d' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/telegraf/telegraf.conf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox/telegraf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/config/plugins/stats4lox' retained as loxberry:loxberry
    27.10.2022 07:57:04 <OK> File ownership set successfully.
    27.10.2022 07:57:04 <INFO> Installing bin files.
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/config-handler.pl' -> '/opt/loxberry/bin/plugins/stats4lox/config-handler.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/create_element_langfiles.pl' -> '/opt/loxberry/bin/plugins/stats4lox/create_element_langfiles.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/debugging' -> '/opt/loxberry/bin/plugins/stats4lox/debugging'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/debugging/updatepanel.pl' -> '/opt/loxberry/bin/plugins/stats4lox/debugging/updatepanel.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/debugging/debug_stats.pl' -> '/opt/loxberry/bin/plugins/stats4lox/debugging/debug_stats.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/debugging/showconfig.pl' -> '/opt/loxberry/bin/plugins/stats4lox/debugging/showconfig.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/import_loxone.pl' -> '/opt/loxberry/bin/plugins/stats4lox/import_loxone.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/import_scheduler.pl' -> '/opt/loxberry/bin/plugins/stats4lox/import_scheduler.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs' -> '/opt/loxberry/bin/plugins/stats4lox/libs'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/filechangeTracker.php' -> '/opt/loxberry/bin/plugins/stats4lox/libs/filechangeTracker.php'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone' -> '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/unpack_loxcc_py2_obsolete.py' -> '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/unpack_loxcc_py2_obsolete.py'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/ParseXML.pm' -> '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/ParseXML.pm'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/GetLoxplan.pm' -> '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/GetLoxplan.pm'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/unpack_loxcc.py' -> '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/unpack_loxcc.py'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Loxone/Import.pm' -> '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/Import.pm'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Globals.pm' -> '/opt/loxberry/bin/plugins/stats4lox/libs/Globals.pm'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/GrafanaS4L.pm' -> '/opt/loxberry/bin/plugins/stats4lox/libs/GrafanaS4L.pm'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/testtimestamps.pl' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing/testtimestamps.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/getValue.pl' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing/getValue.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/testTOML.pl' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing/testTOML.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/parseLocalStatfile.pl' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing/parseLocalStatfile.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/testXML.pl' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing/testXML.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/getLoxplan.pl' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing/getLoxplan.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/sendTelegraf.pl' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing/sendTelegraf.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/testtimestamps_workaround.pl' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing/testtimestamps_workaround.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/getTelegrafInternals.pl' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing/getTelegrafInternals.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/searchReplace.sh' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing/searchReplace.sh'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/parseLocalLoxplan.pl' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing/parseLocalLoxplan.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/testing/getLineformat.pl' -> '/opt/loxberry/bin/plugins/stats4lox/libs/testing/getLineformat.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Stats4Lox.pm' -> '/opt/loxberry/bin/plugins/stats4lox/libs/Stats4Lox.pm'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/libs/Grafana.pm' -> '/opt/loxberry/bin/plugins/stats4lox/libs/Grafana.pm'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/loadLoxoneMiniserverStatistics.py' -> '/opt/loxberry/bin/plugins/stats4lox/loadLoxoneMiniserverStatistics.py'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/loadMiniserverConfigurationFile.py' -> '/opt/loxberry/bin/plugins/stats4lox/loadMiniserverConfigurationFile.py'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/lox2telegraf.pl' -> '/opt/loxberry/bin/plugins/stats4lox/lox2telegraf.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/mqtt' -> '/opt/loxberry/bin/plugins/stats4lox/mqtt'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/mqtt/phpMQTT.php' -> '/opt/loxberry/bin/plugins/stats4lox/mqtt/phpMQTT.php'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/mqtt/mqttlive.php' -> '/opt/loxberry/bin/plugins/stats4lox/mqtt/mqttlive.php'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning' -> '/opt/loxberry/bin/plugins/stats4lox/provisioning'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/delete_datasource_influx.pl' -> '/opt/loxberry/bin/plugins/stats4lox/provisioning/delete_datasource_influx.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/set_datasource_influx.pl' -> '/opt/loxberry/bin/plugins/stats4lox/provisioning/set_datasource_influx.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/set_dashboard_provider.pl' -> '/opt/loxberry/bin/plugins/stats4lox/provisioning/set_dashboard_provider.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/provisioning/update_dashboards.pl' -> '/opt/loxberry/bin/plugins/stats4lox/provisioning/update_dashboards.pl'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/s4linflux' -> '/opt/loxberry/bin/plugins/stats4lox/s4linflux'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/bin/startinflux.sh' -> '/opt/loxberry/bin/plugins/stats4lox/startinflux.sh'
    27.10.2022 07:57:04 <INFO> Setting file permissions: /bin/chmod -Rv 755 /opt/loxberry/bin/plugins/stats4lox
    mode of '/opt/loxberry/bin/plugins/stats4lox' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/debugging' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/debugging/showconfig.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/debugging/debug_stats.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/debugging/updatepanel.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/loadLoxoneMiniserverStatistics.py' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/import_loxone.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/config-handler.pl' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/provisioning' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/provisioning/delete_datasource_influx.pl' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/provisioning/set_datasource_influx.pl' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/provisioning/set_dashboard_provider.pl' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/provisioning/update_dashboards.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/lox2telegraf.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/loadMiniserverConfigurationFile.py' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/mqtt' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/mqtt/phpMQTT.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/mqtt/mqttlive.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/s4linflux' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/create_element_langfiles.pl' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/startinflux.sh' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/testtimestamps.pl' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/getValue.pl' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/parseLocalLoxplan.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/testXML.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/getLoxplan.pl' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/searchReplace.sh' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/testTOML.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/sendTelegraf.pl' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/getTelegrafInternals.pl' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/testtimestamps_workaround.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/parseLocalStatfile.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/getLineformat.pl' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/Grafana.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/Stats4Lox.pm' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/filechangeTracker.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/Import.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/unpack_loxcc.py' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/unpack_loxcc_py2_obsolete.py' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/ParseXML.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/GetLoxplan.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/Globals.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/libs/GrafanaS4L.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/bin/plugins/stats4lox/import_scheduler.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    27.10.2022 07:57:04 <OK> File permissions set successfully.
    27.10.2022 07:57:04 <INFO> Setting file ownership: /bin/chown -Rv loxberry.loxberry /opt/loxberry/bin/plugins/stats4lox
    ownership of '/opt/loxberry/bin/plugins/stats4lox/debugging/showconfig.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/debugging/debug_stats.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/debugging/updatepanel.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/debugging' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/loadLoxoneMiniserverStatistics.py' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/import_loxone.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/config-handler.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/provisioning/delete_datasource_influx.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/provisioning/set_datasource_influx.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/provisioning/set_dashboard_provider.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/provisioning/update_dashboards.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/provisioning' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/lox2telegraf.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/loadMiniserverConfigurationFile.py' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/mqtt/phpMQTT.php' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/mqtt/mqttlive.php' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/mqtt' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/s4linflux' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/create_element_langfiles.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/startinflux.sh' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/testtimestamps.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/getValue.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/parseLocalLoxplan.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/testXML.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/getLoxplan.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/searchReplace.sh' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/testTOML.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/sendTelegraf.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/getTelegrafInternals.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/testtimestamps_workaround.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/parseLocalStatfile.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing/getLineformat.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/testing' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/Grafana.pm' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/Stats4Lox.pm' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/filechangeTracker.php' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/Import.pm' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/unpack_loxcc.py' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/unpack_loxcc_py2_obsolete.py' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/ParseXML.pm' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone/GetLoxplan.pm' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/Loxone' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/Globals.pm' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs/GrafanaS4L.pm' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/libs' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox/import_scheduler.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/bin/plugins/stats4lox' retained as loxberry:loxberry
    27.10.2022 07:57:04 <INFO> Installing template files.
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/chartengines.html' -> '/opt/loxberry/templates/plugins/stats4lox/chartengines.html'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana' -> '/opt/loxberry/templates/plugins/stats4lox/grafana'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/dashboards' -> '/opt/loxberry/templates/plugins/stats4lox/grafana/dashboards'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/dashboards/internals.json' -> '/opt/loxberry/templates/plugins/stats4lox/grafana/dashboards/internals.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/templates' -> '/opt/loxberry/templates/plugins/stats4lox/grafana/templates'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/templates/template_defaultDashboard.json' -> '/opt/loxberry/templates/plugins/stats4lox/grafana/templates/template_defaultDashboard.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/templates/template_panel_graph.json' -> '/opt/loxberry/templates/plugins/stats4lox/grafana/templates/template_panel_graph.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/grafana/templates/Dashboard with 1 panel.txt' -> '/opt/loxberry/templates/plugins/stats4lox/grafana/templates/Dashboard with 1 panel.txt'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/home.html' -> '/opt/loxberry/templates/plugins/stats4lox/home.html'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/input_mqtt.html' -> '/opt/loxberry/templates/plugins/stats4lox/input_mqtt.html'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang' -> '/opt/loxberry/templates/plugins/stats4lox/lang'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_hu.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_hu.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ro.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ro.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_it.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_it.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ca.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ca.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ru.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ru.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ch.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ch.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_sk.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_sk.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_cs.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_cs.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_en.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_en.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_de.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_de.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_fr.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_fr.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_en.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_en.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/language_en.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/language_en.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_es.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_es.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_fr.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_fr.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ch.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ch.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_hu.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_hu.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_de.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_de.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_it.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_it.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_pl.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_pl.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_nl.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_nl.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_cs.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_cs.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_no.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_no.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_no.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_no.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_pl.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_pl.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_nl.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_nl.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ro.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ro.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ca.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ca.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_ru.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ru.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_sk.json' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_sk.json'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/lang/loxelements_es.ini' -> '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_es.ini'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/logs.html' -> '/opt/loxberry/templates/plugins/stats4lox/logs.html'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/loxone_import_report.html' -> '/opt/loxberry/templates/plugins/stats4lox/loxone_import_report.html'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/mqttlive_loxone.html' -> '/opt/loxberry/templates/plugins/stats4lox/mqttlive_loxone.html'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/output_influx.html' -> '/opt/loxberry/templates/plugins/stats4lox/output_influx.html'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/templates/settings_loxone.html' -> '/opt/loxberry/templates/plugins/stats4lox/settings_loxone.html'
    27.10.2022 07:57:04 <INFO> Setting file ownership: /bin/chown -Rv loxberry.loxberry /opt/loxberry/templates/plugins/stats4lox
    ownership of '/opt/loxberry/templates/plugins/stats4lox/input_mqtt.html' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/home.html' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_hu.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_nl.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_es.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ch.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_en.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ch.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ro.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_it.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/language_en.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_no.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ru.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ro.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ca.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_nl.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ru.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_it.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_pl.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_pl.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_de.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_hu.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_no.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_en.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_de.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_cs.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_fr.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_sk.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_cs.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_es.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_sk.ini' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_ca.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang/loxelements_fr.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/lang' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/grafana/dashboards/internals.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/grafana/dashboards' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/grafana/templates/Dashboard with 1 panel.txt' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/grafana/templates/template_defaultDashboard.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/grafana/templates/template_panel_graph.json' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/grafana/templates' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/grafana' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/logs.html' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/output_influx.html' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/settings_loxone.html' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/mqttlive_loxone.html' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/chartengines.html' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox/loxone_import_report.html' retained as loxberry:loxberry
    ownership of '/opt/loxberry/templates/plugins/stats4lox' retained as loxberry:loxberry
    27.10.2022 07:57:04 <INFO> Installing cronjob files.
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/cron/cron.reboot' -> '/opt/loxberry/system/cron/cron.reboot/stats4lox'
    27.10.2022 07:57:04 <INFO> Setting file permissions: /bin/chmod -Rv 755 /opt/loxberry/system/cron/cron.reboot
    mode of '/opt/loxberry/system/cron/cron.reboot' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/system/cron/cron.reboot/1-wire-ng' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/system/cron/cron.reboot/stats4lox' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/system/cron/cron.reboot/alexa2lox' retained as 0755 (rwxr-xr-x)
    27.10.2022 07:57:04 <INFO> Setting file ownership: /bin/chown -Rv loxberry.loxberry /opt/loxberry/system/cron/cron.reboot
    ownership of '/opt/loxberry/system/cron/cron.reboot/1-wire-ng' retained as loxberry:loxberry
    ownership of '/opt/loxberry/system/cron/cron.reboot/stats4lox' retained as loxberry:loxberry
    ownership of '/opt/loxberry/system/cron/cron.reboot/alexa2lox' retained as loxberry:loxberry
    ownership of '/opt/loxberry/system/cron/cron.reboot' retained as loxberry:loxberry
    27.10.2022 07:57:04 <INFO> Installing data files.
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups' -> '/opt/loxberry/data/plugins/stats4lox/backups'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/plugininstall' -> '/opt/loxberry/data/plugins/stats4lox/backups/plugininstall'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/plugininstall/.dummy' -> '/opt/loxberry/data/plugins/stats4lox/backups/plugininstall/.dummy'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/system' -> '/opt/loxberry/data/plugins/stats4lox/backups/system'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/system/.dummy' -> '/opt/loxberry/data/plugins/stats4lox/backups/system/.dummy'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/user' -> '/opt/loxberry/data/plugins/stats4lox/backups/user'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/backups/user/.dummy' -> '/opt/loxberry/data/plugins/stats4lox/backups/user/.dummy'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/grafana' -> '/opt/loxberry/data/plugins/stats4lox/grafana'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/grafana/.dummy' -> '/opt/loxberry/data/plugins/stats4lox/grafana/.dummy'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/import' -> '/opt/loxberry/data/plugins/stats4lox/import'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/import/.dummy' -> '/opt/loxberry/data/plugins/stats4lox/import/.dummy'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/influxdb' -> '/opt/loxberry/data/plugins/stats4lox/influxdb'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/influxdb/.dummy' -> '/opt/loxberry/data/plugins/stats4lox/influxdb/.dummy'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/telegraf' -> '/opt/loxberry/data/plugins/stats4lox/telegraf'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/data/telegraf/.dummy' -> '/opt/loxberry/data/plugins/stats4lox/telegraf/.dummy'
    27.10.2022 07:57:05 <OK> All file(s) were installed successfully.
    27.10.2022 07:57:05 <INFO> Setting file ownership: /bin/chown -Rv loxberry.loxberry /opt/loxberry/data/plugins/stats4lox
    ownership of '/opt/loxberry/data/plugins/stats4lox/backups/system/.dummy' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/backups/system' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/backups/plugininstall/.dummy' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/backups/plugininstall' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/backups/user/.dummy' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/backups/user' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/backups' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/influxdb/.dummy' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/influxdb' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/grafana/.dummy' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/grafana' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/import/.dummy' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/import' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/telegraf/.dummy' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox/telegraf' retained as loxberry:loxberry
    ownership of '/opt/loxberry/data/plugins/stats4lox' retained as loxberry:loxberry
    27.10.2022 07:57:05 <OK> File ownership set successfully.
    27.10.2022 07:57:05 <INFO> Installing htmlauth files.
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/ajax.cgi' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/ajax.cgi'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/chartengines.cgi' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/chartengines.cgi'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/grabber' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/grabber'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/grabber/grabber_loxone.cgi' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/grabber/grabber_loxone.cgi'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/grabber/grabber_miniserver.cgi' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/grabber/grabber_miniserver.cgi'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_alert.png' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_alert.png'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_alert_20.png' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_alert_20.png'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_checked.png' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_checked.png'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_checked_20.png' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_checked_20.png'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_scheduled.psd' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_scheduled.psd'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_scheduled_20.png' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_scheduled_20.png'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_unchecked.png' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_unchecked.png'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_unchecked.psd' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_unchecked.psd'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/checkbox_unchecked_20.png' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_unchecked_20.png'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/images/import_icon.png' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/import_icon.png'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/index.cgi' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/index.cgi'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/input_mqtt.cgi' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/input_mqtt.cgi'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/vue.global.js' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/vue.global.js'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/menu_structure (obsolete).js' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/menu_structure (obsolete).js'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/loxone_sub_navbar.js' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/loxone_sub_navbar.js'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/settings_loxone.js' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/settings_loxone.js'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/input_mqtt.js' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/input_mqtt.js'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/mqttlive_loxone.js' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/mqttlive_loxone.js'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/inputs_outputs_sub_navbar.js' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/inputs_outputs_sub_navbar.js'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/loxone_import_report.js' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/loxone_import_report.js'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/js/home.js' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/home.js'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/logs.cgi' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/logs.cgi'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/loxone_import_report.cgi' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/loxone_import_report.cgi'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/main_loxone.cgi' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/main_loxone.cgi'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/mqttlive_loxone.cgi' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/mqttlive_loxone.cgi'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/output_influx.cgi' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/output_influx.cgi'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/webfrontend/htmlauth/test.pl' -> '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/test.pl'
    27.10.2022 07:57:05 <INFO> Setting file permissions: /usr/bin/find /opt/loxberry/webfrontend/htmlauth/plugins/stats4lox -iregex '.*\.cgi\|.*\.pl\|.*\.sh' -exec /bin/chmod -v 755 {} \;
    mode of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/ajax.cgi' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/index.cgi' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/input_mqtt.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/mqttlive_loxone.cgi' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/grabber/grabber_loxone.cgi' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/grabber/grabber_miniserver.cgi' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/test.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/output_influx.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/chartengines.cgi' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/main_loxone.cgi' retained as 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/logs.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
    mode of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/loxone_import_report.cgi' retained as 0755 (rwxr-xr-x)
    27.10.2022 07:57:05 <OK> File permissions set successfully.
    27.10.2022 07:57:05 <INFO> Setting file ownership: /bin/chown -Rv loxberry.loxberry /opt/loxberry/webfrontend/htmlauth/plugins/stats4lox
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/ajax.cgi' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/index.cgi' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/input_mqtt.cgi' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/mqttlive_loxone.cgi' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/grabber/grabber_loxone.cgi' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/grabber/grabber_miniserver.cgi' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/grabber' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_unchecked.psd' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/import_icon.png' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_scheduled.psd' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_alert_20.png' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_alert.png' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_checked_20.png' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_scheduled_20.png' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_checked.png' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_unchecked.png' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images/checkbox_unchecked_20.png' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/images' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/test.pl' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/output_influx.cgi' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/chartengines.cgi' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/main_loxone.cgi' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/logs.cgi' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/loxone_import_report.cgi' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/vue.global.js' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/menu_structure (obsolete).js' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/home.js' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/inputs_outputs_sub_navbar.js' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/loxone_sub_navbar.js' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/input_mqtt.js' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/mqttlive_loxone.js' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/settings_loxone.js' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js/loxone_import_report.js' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox/js' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/htmlauth/plugins/stats4lox' retained as loxberry:loxberry
    27.10.2022 07:57:05 <INFO> Installing icon files.
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/icons/icon_128.png' -> '/opt/loxberry/webfrontend/html/system/images/icons/stats4lox/icon_128.png'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/icons/icon_256.png' -> '/opt/loxberry/webfrontend/html/system/images/icons/stats4lox/icon_256.png'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/icons/icon_512.png' -> '/opt/loxberry/webfrontend/html/system/images/icons/stats4lox/icon_512.png'
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/icons/icon_64.png' -> '/opt/loxberry/webfrontend/html/system/images/icons/stats4lox/icon_64.png'
    27.10.2022 07:57:05 <OK> Icons installed successfully.
    27.10.2022 07:57:05 <INFO> Setting file ownership: /bin/chown -Rv loxberry.loxberry /opt/loxberry/webfrontend/html/system/images/icons/stats4lox
    ownership of '/opt/loxberry/webfrontend/html/system/images/icons/stats4lox/icon_64.png' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/html/system/images/icons/stats4lox/icon_256.png' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/html/system/images/icons/stats4lox/icon_128.png' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/html/system/images/icons/stats4lox/icon_512.png' retained as loxberry:loxberry
    ownership of '/opt/loxberry/webfrontend/html/system/images/icons/stats4lox' retained as loxberry:loxberry
    27.10.2022 07:57:05 <INFO> Installing uninstall script.
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/uninstall/uninstall' -> '/opt/loxberry/data/system/uninstall/stats4lox'
    27.10.2022 07:57:05 <INFO> Setting file permissions: /bin/chmod -v 755 /opt/loxberry/data/system/uninstall/stats4lox
    mode of '/opt/loxberry/data/system/uninstall/stats4lox' retained as 0755 (rwxr-xr-x)
    27.10.2022 07:57:05 <INFO> Setting file ownership: /bin/chown -v root.root /opt/loxberry/data/system/uninstall/stats4lox
    ownership of '/opt/loxberry/data/system/uninstall/stats4lox' retained as root:root
    27.10.2022 07:57:05 <INFO> Installing sudoers file.
    '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/sudoers/sudoers' -> '/opt/loxberry/system/sudoers/stats4lox'
    27.10.2022 07:57:05 <INFO> Setting file permissions: /bin/chmod -v 644 /opt/loxberry/system/sudoers/stats4lox
    mode of '/opt/loxberry/system/sudoers/stats4lox' retained as 0644 (rw-r--r--)
    27.10.2022 07:57:05 <INFO> Setting file ownership: /bin/chown -v root.root /opt/loxberry/system/sudoers/stats4lox
    ownership of '/opt/loxberry/system/sudoers/stats4lox' retained as root:root
    27.10.2022 07:57:06 <INFO> Installing additional software packages.
    27.10.2022 07:57:06 <INFO> Command: /usr/bin/dpkg --configure -a --force-confdef
    27.10.2022 07:57:07 <INFO> Command: APT_LISTCHANGES_FRONTEND=none DEBIAN_FRONTEND=noninteractive /usr/bin/apt-get -y -q --allow-unauthenticated --fix-broken --reinstall --allow-downgrades --allow-remove-essential --allow-change-held-packages --purge autoremove
    Reading package lists...
    Building dependency tree...
    Reading state information...
    0 upgraded, 0 newly installed, 0 to remove and 167 not upgraded.
    27.10.2022 07:57:10 <INFO> Command: APT_LISTCHANGES_FRONTEND=none DEBIAN_FRONTEND=noninteractive /usr/bin/apt-get --no-install-recommends -q -y --allow-unauthenticated --fix-broken --reinstall --allow-downgrades --allow-remove-essential --allow-change-held-packages install  influxdb telegraf grafana libtoml-parser-perl
    0 upgraded, 0 newly installed, 4 reinstalled, 0 to remove and 167 not upgraded.
    Need to get 0 B/183 MB of archives.
    After this operation, 0 B of additional disk space will be used.
    (Reading database ...
    (Reading database ... 5%
    (Reading database ... 10%
    (Reading database ... 15%
    (Reading database ... 20%
    (Reading database ... 25%
    (Reading database ... 30%
    (Reading database ... 35%
    (Reading database ... 40%
    (Reading database ... 45%
    (Reading database ... 50%
    (Reading database ... 55%
    (Reading database ... 60%
    (Reading database ... 65%
    (Reading database ... 70%
    (Reading database ... 75%
    (Reading database ... 80%
    (Reading database ... 85%
    (Reading database ... 90%
    (Reading database ... 95%
    (Reading database ... 100%
    (Reading database ... 91866 files and directories currently installed.)
    Preparing to unpack .../libtoml-parser-perl_0.91-1_all.deb ...
    Unpacking libtoml-parser-perl (0.91-1) over (0.91-1) ...
    Preparing to unpack .../grafana_9.2.2_armhf.deb ...
    Unpacking grafana (9.2.2) over (9.2.2) ...
    Preparing to unpack .../influxdb_1.8.10-1_armhf.deb ...
    Unpacking influxdb (1.8.10-1) over (1.8.10-1) ...
    Preparing to unpack .../telegraf_1.24.2-1_armhf.deb ...
    [0;1;31mWarning:[0m The unit file, source configuration file or drop-ins of telegraf.service changed on disk. Run 'systemctl daemon-reload' to reload units.
    Unpacking telegraf (1.24.2-1) over (1.24.2-1) ...
    Setting up libtoml-parser-perl (0.91-1) ...
    Setting up influxdb (1.8.10-1) ...
    Setting up telegraf (1.24.2-1) ...
    Setting up grafana (9.2.2) ...
    Restarting grafana-server service... OK
    Processing triggers for man-db (2.8.5-2) ...
    Processing triggers for systemd (241-7~deb10u7+rpi1) ...
    27.10.2022 08:01:08 <OK> Package installed successfully.
    27.10.2022 08:01:08 <INFO> Updating skels for Logfiles in tmpfs.
    27.10.2022 08:01:08 <OK> Script executed successfully.
    27.10.2022 08:01:08 <INFO> Starting script POSTUPGRADE.
    27.10.2022 08:01:08 <INFO> Command: cd "/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8" && /usr/bin/sudo -n -u loxberry "/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/postupgrade.sh" "ShXDJcgkkU" "stats4lox" "stats4lox" "0.9.8" "/opt/loxberry" "/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8"
    mode of '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/postupgrade.sh' retained as 0755 (rwxr-xr-x)
    27.10.2022 08:01:08 <INFO> Starting script POSTROOT.
    27.10.2022 08:01:08 <INFO> Command: cd "/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8" && "/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/postroot.sh" "ShXDJcgkkU" "stats4lox" "stats4lox" "0.9.8" "/opt/loxberry" "/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8"
    mode of '/opt/loxberry/data/system/tmp/uploads/ShXDJcgkkU/LoxBerry-Plugin-Stats4Lox-NG-0.9.8/postroot.sh' retained as 0755 (rwxr-xr-x)
    <INFO> Stopping InfluxDB and Telegraf.
    <INFO> Adding user loxberry to groups influxdb, telegraf, grafana...
    <INFO> Adding user influxdb to group loxberry...
    <INFO> Adding user telegraf to group loxberry...
    <INFO> Adding user grafana to group loxberry...
    <INFO> We are in Upgrade mode. Use existing database and credentials.
    sending incremental file list
    20221026_220024_171_AJAX.log
    20221026_220029_119_AJAX.log
    20221026_220034_104_AJAX.log
    20221026_220039_124_AJAX.log
    20221026_220044_138_AJAX.log
    20221026_220049_132_AJAX.log
    20221026_220054_158_AJAX.log
    20221026_220059_172_AJAX.log
    20221026_220104_168_AJAX.log
    20221026_220109_174_AJAX.log
    20221026_220114_195_AJAX.log
    20221026_220119_193_AJAX.log
    20221026_220124_210_AJAX.log
    20221026_220129_203_AJAX.log
    20221026_233140_254_AJAX.log
    20221026_233140_731_AJAX.log
    20221026_233142_240_AJAX.log
    20221026_233147_173_AJAX.log
    20221026_233152_219_AJAX.log
    20221026_233157_210_AJAX.log
    20221026_233202_155_AJAX.log
    20221026_233208_209_AJAX.log
    20221026_233213_165_AJAX.log
    20221026_233218_192_AJAX.log
    20221027_073416_047_AJAX.log
    20221027_073419_318_AJAX.log
    20221027_073424_290_AJAX.log
    20221027_073429_331_AJAX.log
    20221027_073434_358_AJAX.log
    20221027_073440_440_AJAX.log
    20221027_073457_453_AJAX.log
    20221027_073502_470_AJAX.log
    20221027_073507_456_AJAX.log
    20221027_073512_574_AJAX.log
    20221027_073517_585_AJAX.log
    20221027_073522_536_AJAX.log
    20221027_073528_432_AJAX.log
    20221027_073533_429_AJAX.log
    20221027_073538_479_AJAX.log
    20221027_073543_531_AJAX.log
    20221027_073548_545_AJAX.log
    20221027_073553_488_AJAX.log
    20221027_073559_455_AJAX.log
    20221027_073604_547_AJAX.log
    20221027_073609_471_AJAX.log
    20221027_073614_539_AJAX.log
    20221027_073619_496_AJAX.log
    20221027_073624_518_AJAX.log
    20221027_073631_328_AJAX.log
    import_scheduler.log
    mqttlive.log
    mqttlive.log.gz
    mqttlive_lox2telegraf.log
    sent 1,032,773 bytes  received 1,023 bytes  2,067,592.00 bytes/sec
    total size is 1,028,898  speedup is 1.00
    ms1.json
    backups/
    backups/plugininstall/20220918201307_backup_plugininstall.7z
    backups/plugininstall/20221026090417_backup_plugininstall.7z
    backups/plugininstall/20221027074510_backup_plugininstall.7z
    backups/system/
    backups/user/
    backups/user/.dummy
    grafana/
    grafana/.dummy
    grafana/grafana.db
    grafana/grafana.log
    grafana/grafana.log.2022-10-23.001
    grafana/grafana.log.2022-10-25.001
    grafana/grafana.log.2022-10-26.001
    grafana/alerting/
    grafana/alerting/1/
    grafana/alerting/1/__default__.tmpl
    grafana/csv/
    grafana/png/
    import/
    import/.dummy
    import/import_1_0f2bc193-021b-0653-ffffc9ef1f112e83.json
    import/import_1_0f2bc193-021b-0653-ffffc9ef1f112e83.json.log
    import/import_1_0f2bc19c-02a7-7bf2-ffffb01063838c24.json
    import/import_1_0f2bc19c-02a7-7bf2-ffffb01063838c24.json.log
    import/import_1_0f2bc19c-02a7-b6f8-ffffa3d109ca3902.json
    import/import_1_0f2bc19c-02a7-b6f8-ffffa3d109ca3902.json.log
    influxdb/
    influxdb/.dummy
    influxdb/data/
    influxdb/data/_internal/
    influxdb/data/_internal/_series/
    influxdb/data/_internal/_series/00/
    influxdb/data/_internal/_series/00/0000
    influxdb/data/_internal/_series/01/
    influxdb/data/_internal/_series/01/0000
    influxdb/data/_internal/_series/02/
    influxdb/data/_internal/_series/02/0000
    influxdb/data/_internal/_series/03/
    influxdb/data/_internal/_series/03/0000
    influxdb/data/_internal/_series/04/
    influxdb/data/_internal/_series/04/0000
    influxdb/data/_internal/_series/05/
    influxdb/data/_internal/_series/05/0000
    influxdb/data/_internal/_series/06/
    influxdb/data/_internal/_series/06/0000
    influxdb/data/_internal/_series/07/
    influxdb/data/_internal/_series/07/0000
    influxdb/data/_internal/monitor/
    influxdb/data/_internal/monitor/1/
    influxdb/data/_internal/monitor/1/fields.idx
    influxdb/data/stats4lox/
    influxdb/data/stats4lox/_series/
    influxdb/data/stats4lox/_series/00/
    influxdb/data/stats4lox/_series/00/0000
    influxdb/data/stats4lox/_series/01/
    influxdb/data/stats4lox/_series/01/0000
    influxdb/data/stats4lox/_series/02/
    influxdb/data/stats4lox/_series/02/0000
    influxdb/data/stats4lox/_series/03/
    influxdb/data/stats4lox/_series/03/0000
    influxdb/data/stats4lox/_series/04/
    influxdb/data/stats4lox/_series/04/0000
    influxdb/data/stats4lox/_series/05/
    influxdb/data/stats4lox/_series/05/0000
    influxdb/data/stats4lox/_series/06/
    influxdb/data/stats4lox/_series/06/0000
    influxdb/data/stats4lox/_series/07/
    influxdb/data/stats4lox/_series/07/0000
    influxdb/data/stats4lox/autogen/
    influxdb/data/stats4lox/autogen/2/
    influxdb/data/stats4lox/autogen/2/fields.idx
    influxdb/meta/
    influxdb/meta/meta.db
    influxdb/wal/
    influxdb/wal/_internal/
    influxdb/wal/_internal/monitor/
    influxdb/wal/_internal/monitor/1/
    influxdb/wal/_internal/monitor/1/_00001.wal
    influxdb/wal/stats4lox/
    influxdb/wal/stats4lox/autogen/
    influxdb/wal/stats4lox/autogen/2/
    influxdb/wal/stats4lox/autogen/2/_00001.wal
    telegraf/
    telegraf/.dummy
    sent 91,771,187 bytes  received 1,120 bytes  2,913,406.57 bytes/sec
    total size is 91,744,383  speedup is 1.00
    cred.json
    stats.json
    stats4lox.json
    grafana/
    grafana/grafana.ini
    grafana/ldap.toml
    grafana/provisioning/
    grafana/provisioning/dashboards/
    grafana/provisioning/dashboards/sample.yaml
    grafana/provisioning/dashboards/stats4lox.yaml
    grafana/provisioning/dashboards/stats4lox_static.yaml
    grafana/provisioning/datasources/
    grafana/provisioning/datasources/sample.yaml
    grafana/provisioning/datasources/stats4lox.yaml
    grafana/provisioning/notifiers/
    grafana/provisioning/notifiers/sample.yaml
    grafana/provisioning/plugins/
    grafana/provisioning/plugins/sample.yaml
    influxdb/
    influxdb/influxdb-selfsigned.crt
    influxdb/influxdb-selfsigned.key
    influxdb/influxdb.conf
    provisioning/
    provisioning/dashboards/.dummy
    provisioning/dashboards/defaultDashboard.json
    systemd/
    telegraf/
    telegraf/telegraf.conf
    telegraf/telegraf.env
    telegraf/.cache/
    telegraf/.cache/snowflake/
    telegraf/.cache/snowflake/ocsp_response_cache.json
    telegraf/telegraf.d/
    telegraf/telegraf.d/stats4lox_debug.conf
    telegraf/telegraf.d/stats4lox_internal.conf
    telegraf/telegraf.d/stats4lox_loxberry.conf
    telegraf/telegraf.d/stats4lox_loxone.conf
    telegraf/telegraf.d/stats4lox_miniserver.conf
    telegraf/telegraf.d/stats4lox_socketlistener_udp.conf
    telegraf/telegraf.d/stats4lox_socketlistener_unix.conf
    sent 679,055 bytes  received 605 bytes  1,359,320.00 bytes/sec
    total size is 676,342  speedup is 1.00
    7-Zip [32] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
    p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,32 bits,4 CPUs LE)
    Scanning the drive:
    63 folders, 125 files, 82000675 bytes (79 MiB)
    Creating archive: 20221027080109_backup_plugininstall.7z
    Items to compress: 188
    Files read from disk: 115
    Archive size: 3959917 bytes (3868 KiB)
    Everything is Ok
    <INFO> Activating my own InfluxDB configuration.
    <INFO> Found SSL certificates for InfluxDB. I will not create new ones.
    <INFO> Set permissions for user influxdb for all config/data folders: /opt/loxberry/data/plugins/stats4lox/influxdb /opt/loxberry/config/plugins/stats4lox/influxdb
    <INFO> Current file permisssions in /opt/loxberry/data/plugins/stats4lox/influxdb:
    total 12
    drwxr-xr-x 4 influxdb loxberry 4096 Sep 18 14:08 data
    drwxr-xr-x 2 influxdb loxberry 4096 Sep 18 14:08 meta
    drwx------ 4 influxdb loxberry 4096 Sep 18 14:08 wal
    <INFO> Current file permisssions in /opt/loxberry/config/plugins/stats4lox/influxdb
    total 32
    -rw-rw---- 1 influxdb loxberry  1257 Sep 18 14:08 influxdb-selfsigned.crt
    -rw-rw---- 1 influxdb loxberry  1708 Sep 18 14:08 influxdb-selfsigned.key
    -rw-r--r-- 1 influxdb loxberry 21812 Sep 18 18:36 influxdb.conf
    <INFO> Enlarge Unix receive buffer limit...
    net.unix.max_dgram_qlen = 10000
    <INFO> Install Drop-In for Influx and Telegraf and Grafana systemd services...
    <INFO> Starting InfluxDB...
    Job for influxdb.service failed because the service did not take the steps required by its unit configuration.
    See "systemctl status influxdb.service" and "journalctl -xe" for details.
    <FAIL> Seems that InfluxDB could not be started. Giving up.
    27.10.2022 08:02:29 <FAIL> Script fails. Installation cannot be continued.
    Use of uninitialized value in concatenation (.) or string at /opt/loxberry/sbin/plugininstall.pl line 1810.
    Use of uninitialized value in concatenation (.) or string at /opt/loxberry/sbin/plugininstall.pl line 1811.
    ● influxdb.service - InfluxDB is an open-source, distributed, time series databa
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset:
      Drop-In: /etc/systemd/system/influxdb.service.d
               └─00-stats4lox-influxdb.conf
       Active: activating (start) since Sat 2022-10-29 09:47:42 CEST; 1s ago
         Docs: https://docs.influxdata.com/influxdb/
    Cntrl PID: 10720 (startinflux.sh)
        Tasks: 2 (limit: 2200)
       Memory: 568.0K
       CGroup: /system.slice/influxdb.service
               ├─10720 /bin/bash -e /opt/loxberry/bin/plugins/stats4lox/startinflux.
               └─10722 sleep 10​
    die journalctl -xe hat keine Einträge
    Zuletzt geändert von .:Chris:.; 29.10.2022, 09:50.
    • .:Chris:.
      .:Chris:. kommentierte
      kann uns hierbei niemand unterstüzen?
    • 5165
    #438
    .:Chris:. Versuchst Du von der alten Version 0.9.7 upzudaten? Ich kann das Problem hier nicht nachstellen, daher brauche ich ein paar mehr Infos:
    - Von welcher Version versuchst Du upzugraden?
    - Wo liegt Deine Influx-Datenbank?
    Und dann mal bitte per Putty zum Loxberry verbinden und mit "su -" zu root werden. Anschließend folgenden Befehl eingeben und schauen, ob es eine Fehlermeldung gibt:
    sudo -u influxdb -g influxdb /usr/bin/influxd -config /etc/influxdb/influxdb.conf
    Zuletzt geändert von Prof.Mobilux; 29.10.2022, 21:06.
    • .:Chris:.
      moin, also wie es aussieht habe ich den Fehler an der falschen Stelle gesucht. Habe einen USB-Stick mit ext4 für die Daten. Diese scheint beschädigt zu sein und wird vom loxberry nicht mehr gemounted. Versuche gerade über einen anderen Raspberry an die Daten zu kommen und diese auf einen anderen Stick zu kopieren.
      Ich melde mich, sobald ich die Daten wieder verfügbar habe.
      Wird über Loxberry oder im plugin überprüft, ob das Datenziel noch verfügbar ist? Eine entsprechende Meldung hatte ich nicht erhalten.
      Nein, das ist Sache von Influx. Findet Influx die Datenbank nicht, beendet es sich wieder. Bei dem obigen Aufruf hätte er dir das dann aber auch angezeigt.
  • Sunny
    • 02.12.2015
    • 39
    #439
    Was kann ich denn zur Lösung meines Problems bei steuern? Bei läuft ja der Telegraf nicht mehr nach dem update (#433).
    Ich kann auch gerne eine Neuinstallation des Plugins probieren, wenn ich weiß wo ich meine Einstellungen sichern und zurückspielen kann.
    • ma2regs@gmail.com
      • 17.10.2022
      • 2
      #440
      Super Plugin! Vielen Dank!
      Ich nutze in Loxone den "Energiemonitor" Baustein. Für die Ausgänge des Bausteins gibt es in der Detailansicht nur bei "Default" das "Import-Symbol". Nach dem Importieren der Datensätze gibt es folglich in InfluxDB auch nur Daten bei "Default", die in die Vergangenheit zurück reichen.
      Interessant ist ja, dass auf dem Miniserver die Werte der Statistiken des Energiemonitors nicht 1:1 den Ausgängen des Bausteins enstprechen.
      Die XML Files auf http://miniserver_IP/stats haben folgendes Format bzw. Struktur:
      <?xml version="1.0" encoding="utf-8"?>
      <Statistics Name="Energiemonitor" NumOutputs="9" Outputs="Leistung Produktion,Leistung Verbrauch,Leistung Energieversorger,Leistung Batterie,Ladestand Batterie,Zähler Produktion,Zähler Verbrauch,Zähler Lieferung,Zähler Bezug">
      <S T="2022-10-01 00:00:00" V="0.000" V2="0.794" V3="0.794" V4="0.000" V5="0.000" V6="90585.298" V7="94787.293" V8="51797.420" V9="55953.300"/>
      Vergleicht man diese Outputs mit den Ausgängen am Baustein ergibt in etwa das folgende Mapping:
      [Ausgang am Baustein] <-> [Outputs im XML]
      Ppwr <-> Leistung Produktion
      Pd <-> ?
      Pm <-> ?
      Py <-> ?
      Ptot <-> Zähler Produktion
      Cpwr <-> Leistung Verbrauch
      Cd <-> ?
      Cm <-> ?
      Cy <-> ?
      Ctot <-> Zähler Verbrauch
      Ed <-> ?
      Em <-> ?
      Ey <-> ?
      Etot <-> Zähler Lieferung
      Yd <-> ?
      Ym <-> ?
      Yy <-> ?
      Ytot <-> ?
      Sci <-> ?
      Eci <-> ?
      Gpwer <-> Leistung Energieversorger
      Spwer <-> Leistung Batterie
      SoC <-> Ladestand Batterie
      AC <-> ?
      ? <-> Zähler Bezug
      Hat das jemand irgendwie gelöst?​ Ich möchte die Energie-Statistiken über die Jahre miteinander vergleichen und suche nach einer guten Lösung..
      • .:Chris:.
        • 05.01.2016
        • 202
        #441
        Hallo Leute,
        so wie es sich bei mir dargestellt hat, war der USB-Stick defekt und konnte daher über influx nicht mehr angesprochen werden.
        Habe sämtliche Schritte zur Datensicherung und -wiederherstellung hier zusammengefasst:
        https://wiki.loxberry.de/plugins/sta..._sd-card/start
        Viel Erfolg
        .:Chris:.
        Zuletzt geändert von .:Chris:.; 04.11.2022, 20:02. Grund: link angepasst
        • ChrisR
          ChrisR kommentierte
          Super Idee, aber leider...."Diese Seite existiert nicht mehr"
        • .:Chris:.
          haben wim Wiki noch was angepasst, der Link ist korrigiert.
        • 5165
        #442
        Iksi Sunny und bei allen anderen, bei denen der Telegraf nicht mehr läuft:
        1. Macht ein komplettes Backup eures LoxBerry mit dem LBBackup Plugin (nur zur Sicherheit)
        2. Alle Services im Plugin in der Übersicht stoppen
        3. Per Putty verbinden und zu root werden mit "su -"
        4. Folgende Befehle ausführen:
        mv /opt/loxberry/config/plugins/stats4lox/grafana/grafana.ini /opt/loxberry/config/plugins/stats4lox/grafana/grafana.ini.bkp
        mv /opt/loxberry/config/plugins/stats4lox/telegraf /opt/loxberry/config/plugins/stats4lox/telegraf.bkp
        5. Plugin in Version 0.9.8 als Update neu installieren (also über das installierte Plugin drüber installieren)
        6. Beten dass es klappt :-)
          Prima! :-)
        • Iksi
          Iksi kommentierte
          Bei mir läuft es jetzt auch wieder.
          Danke Michael ;-)
        • .:Chris:.
          Guten Morgen zusammen,
          nach dem Einspielen des Backups-Images ist bei mir Telegraf ebenfalls nicht mehr gelaufen. Danke des hier beschriebenen workaround läuft nun alles wieder.
          VG
          .:Chris:.
      • Gargamel
        • 16.12.2018
        • 756
        #443
        Bin gerade dabei das Grafana Dashboard ordentlich einzurichten.
        Auf der Grafana Seite gibt es noch einige interessante Plugins wie zB. das Sonnen und Mondverlauf Plugin das man einbinden könnte. Ist es möglich so ein Plugin einzubinden?
        Besten Dank schon mal
      • Speed
        • 12.12.2018
        • 23
        #444
        Plugin funktioniert super, vielen Dank dafür!
        Ich habe versucht das Plugin auch für externe Sensoren zu verwenden. Ich habe noch einen Home Assistant Container laufen über welchen ich verschiedene Sensoren abfrage. Ich habe es geschafft die Daten an den MQTT Server zu schicken und könnte sie auch wieder via Loxone Server auslesen. Gibt es eine Möglichkeit die Daten auch an die Influx DB weiterzugeben?
        Ich habe als Topic "s4l/mqttlive/1/..." angegeben aber in Influx taucht nichts auf. Im MQTT Live Tab scheint "UNKNOWN: <Topicname> not found" auf. Habt ihr vielleicht einen Tip für mich?
        Danke!
          Speed Mir ist nicht ganz klar, von wo du was wohin schickst.
          Es gibt MQTT Live und den MQTT Collector - das eine für Daten vom MS, das andere ohne MS.
          Für ersteres muss ein Statistik-Abruf vom MS zumindest einmal eingerichtet worden sein.
          • Speed
            • 12.12.2018
            • 23
            #446
            Danke Christian Fenzl, genau den MQTT Collector habe ich gesucht!
            • HRA
              • 1037
              #447
              nachdem ich nun durch Eigenverschulden mite Statistiekn eingebüst habe, bin ich gerade dabei das PlugIn neu aufzusetzen.
              Wollte sowieso einige Änderungen haben und somit fallen auch gleich die Leichen raus.
              Habe aber nun zwei Probleme, mit dem ich nicht richtig weiterkomme
              Ich habe derzeit nur sehr wenige Daten vom MS und möchte mehr autarkt von Lox, direkt mittels MQTT mitloggen.
              Dazu nutze ich den MQTT-Colector, soweit so gut
              1. Problem Vitoconnect-PlugIn über MQTT -> ich kann die digitalen (true/false bzw. 0/1) Variablen nicht im Grafana anzeigen, muss ich da noch irgendeinen Umweg gehen?
              2. Die Daten vom Shelly1pm werden nicht aktualisiert, habe sie einmal beim erstellen drin aber es erfolgt keine Aktualisierung, im MQTT incoming werden die Daten aktualisiert
Ansichten: 523
Größe: 170,5 KB
ID: 366016 Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 504
Größe: 103,6 KB
Ansichten: 510
Größe: 121,0 KB
ID: 366015 Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 555
Größe: 146,3 KB
              Gruß HRA
                Kannst du in Grafana mal auf Table View stellen, welche Daten da sind?
                Von MQTT Live/Collector gibt es auch ein Log, wo sichtbar sein sollte, wenn Daten hereinkommen.
                LG, Christian
                • .:Chris:.
                  • 05.01.2016
                  • 202
                  #449
                  HRA:
                  zu deiner ersten Frage
Ansichten: 368
Größe: 3,0 KB
                  Sollte funktionieren.
                  VG
                  .:Chris:.
                  • HRA
                    HRA kommentierte
                    Hallo, danke für die Hilfe
                    Leider funktioniert es trotzdem nicht, er bringt mir immer No Data, wenn ich ein "Bit" anwähle
                    Habe ich evtl. igreneine Einstellung übersehen?
                    Beim Collector muss da der Hakeb rein für Wert bzw. String?
                    Habe eigentlich alle Versionen versucht ohne einen Unterschied zu finden , oder übersehen.
                    Im MQTT incomming sehe ich die Werte mit 0 bzw.
                    Was mir noch aufgefalen ist, die Variable im MQTT heisst z.B. vitoconnect_heating_burners_0_active mit dem Wert 0 oder 1
                    Bei der Auswahl im Grafana gibt mir die Vorlage die Auswaqhl auf vitoconnect/heating/burners/0 und bei select field "activ"
                • HRA
                  • 1037
                  #450
                  Christian Fenzl
                  Es scheint als ob garkeine Daten über den Collector reincommen.
                  Im MQTT incomming sind die Daten aktuell.
                  Wo finde ich den Log vom MQTT Live? Unter Log gibt es Gruppen AJAX/Config-Handler/Import-Stats/Grabber-loxone/grabber-miniserver
                  Unter AJAX stehe minütlich (habe Level auf Info gestellt) Reguest getstatsconfig drin (ohne Fehler)
                  Klicke auf die Grafik für eine vergrößerte Ansicht  Name: shelly 2.png Ansichten: 0 Größe: 24,8 KB ID: 366114 Klicke auf die Grafik für eine vergrößerte Ansicht  Name: shelly 1.png Ansichten: 0 Größe: 106,4 KB ID: 366115
                  Gleiches gilt auch bei meinem zweiten ShellyPlugS, da sind die Daten auch nur einmalig vorhanden.
                  Muss ich ggf. irgendwo eine Aktualisierung anstarten/einstellen?
                  Hatte vorher alles über MS laufen, da hat es funktionert
                  Zuletzt geändert von HRA; 14.11.2022, 10:25.
                  Gruß HRA
