Beta Thread
  • Kuredu
    antwortet
    Hallo, ich habe ein Problem mit dem Beta Update. Bekomme nach dem Update immer noch die Alte Konfig Seite vom Ms4lox. Was könnte da schief gelaufen sein.
    Meine Hardware ist ein NUC7JYH2 mit Debian 10.4.0
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: Console.JPG Ansichten: 0 Größe: 119,0 KB ID: 263024Klicke auf die Grafik für eine vergrößerte Ansicht  Name: MS4LOX.JPG Ansichten: 0 Größe: 127,3 KB ID: 263025
    Zuletzt geändert von Kuredu; 29.08.2020, 07:52.
    Einen Kommentar schreiben:
  • stekkes
    antwortet
    Is there a known issue with the powermanager in 1.06 beta ?
    In 1.05 the powermanager was working fine. (I did do a clean install to 1.06)
    Now it only works +-2 times out of 10...when doing a TCPdump and analysis with wireshark nothing leaves from the music server to the relaycard (http)
    Tried several reboots but still same issue.
    Could do http output via the music block in Loxconfig, but prefer keeping it all in MS4L.
  • duncan
    antwortet
    heres my zone1 config
    antwortet
    Zitat von duncan
    my system is:
    intel i5 dell micro pc
    8gb ram
    ssd
    2 x csl usb 7.1 card
    9 internal zones
    10 external zones (real squeezebox players)
    started with a clean install of debian 10.3 and the first beta1, then upgraded through each beta update to the current 1.06
    as i said it all works beautifully except the equaliser which reverts to flat each time the squeezelite players are restarted via an update or machine restart/reboot
    So I think that I have an answer...
    Please post one of your zone config files... \opt\music_server\soundcard_cfg\zones\xxxx.cfg
    old look like that
    ## Zone 01
    pcm.zone_01 {
    type plug
    slave {
    pcm "multi"
    channels 16
    ttable.0.0 1
    ttable.1.0 1
    ttable.0.1 1
    ttable.1.1 1
    pcm.zone_01_eq {
    type plug
    slave.pcm {
    type equal
    slave.pcm "zone_01"
    controls "/opt/music_server/sq_cfg/eq/zone_01_mbeq.bin"
    library "/usr/lib/ladspa/mbeq_1197.so"
    module "mbeq"
    ctl.zone_01_eq {
    type equal
    module "mbeq"
    new look like that
    ## Zone 01
    pcm.zone_01 {
    type plug
    slave {
    pcm "multi"
    channels 16
    ttable.0.0 1
    ttable.1.0 1
    ttable.0.1 1
    ttable.1.1 1
    pcm.zone_01_eq {
    type plug
    slave.pcm {
    type equal
    slave.pcm "zone_01"
    controls "/opt/music_server/sq_cfg/eq/zone_01_eq.bin"
    ctl.zone_01_eq {
    type equal
    antwortet
    Zitat von winfium
    Good evening,
    I don't know but I'm trying the second night and still a wall problem when updating
    The reason is simple...
    I stopped download of the beta install/update.
    The reason is that may uninvited users install the beta, that is only for users that a part of the closed beta.
    It is hard enough to support all the different systems your use, and I can't do that also for the beta version.
    That is why I only share the beat with known users/systems.
    I will come soon with an release, that is open for everybody again.
  • winfium
    antwortet
    Good evening,
    root@MS4L:~# mstools update_ms_beta
    Musik-Server | UPDATE
    Version online: 1.0.6_beta
    Server / Player / PM /SQ2LOX STOP
    OK...
    Download Files
    Unzip Files
    unzip: cannot find or open /tmp/update_1.0.6_beta.zip, /tmp/update_1.0.6_beta.zip.zip or /tmp/update_1.0.6_beta.zip.ZIP.
    Pre-Update-Script
    not used...
    Copy Files...
    Set File Permissions...
    for System Scripts..
    for CONFIG...
    for WWW...
    for ALSA...
    for NETWORK SETTING...
    Create Soft-Links...
    After-Update-Script
    not used...
    MusicServer cleanup
    Server / Player / PM /SQ2LOX RESTART
    OK...
    SUCCESSFULLY UPDATED!
    write update to mysql...https://music-server.net/stat/stat.p...69dd7770dde5e4 34db8f4ea5edbb8af440d258eda0a9a632cc6&version=1.0. 6_beta&lang=de&distro=Debian_10&soundcards=1&chann els=2&zones_int=1&zones_ext=0&zones_total=1
    root@MS4L:~#
  • duncan
    antwortet
    my system is:
    8gb ram
    ssd
    9 internal zones
    kommentierte 's Antwort
    Tried everthing I could to find a connection to the from Squeezelite-Update to EQ Settings but din´t get any failures.
    I´m sure you send me before, but can you send me again the internal/external zones and soundcards you use. Thanks.
    tried to night a fresh installation on 10.4, from "net install iso" work like expected.
    So looks like the used iso was the issue.
    No, I add the languages. This is not an automated process
  • winfium
    more languages can be seen in the API documentation. Does that have anything to do with it?
    By your self you can't.
    I add the languages if I see a need.
  • winfium
    antwortet
    Hello, voicerss added new languages. How can I update the list in MS4L TSS. Thank you
  • duncan
    antwortet
    thanks
    it didnt lose settings when updating linux, and didnt lose settings when updating LMS, if thats any help, and restarting the server doesnt lose the equaliser settings either
    antwortet
    Zitat von duncan
    im currently running 1.06 beta and its very stable, but if i update squeezelite then all zones lose their current equaliser settings
    i can reload them from saved favourites which havnt got lost, just the current settings for each zone
    The Squeezelite-Update don´t do anything with settings. There is only stopping the Player compile the new Version from Git, replace the Squeezlite-Bin and start again all players.
    Have is no idea what could happen here, because the is not the smallest connection to EQ. Will try to find...
