    Zitat von Prof.Mobilux
    Ok, please deinstall the plugin. Then on the command line with putty:
    sudo apt-get purge influx influx-client
    Then please try to reinstall.
    Thanks. I tried it and got the following:
    loxberry@loxberry:~ $ sudo apt-get purge influx influx-client
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    E: Unable to locate package influx
    E: Unable to locate package influx-client
      I did try to test these guidelines. Removed the plugin, run the command above and installed the latest plugin from Github. Unfortunatelly no much progress. Screen captures added
        Further to the above post, re-installation of the plugin resulted in the same error message as before.
        • Leocap
          • 02.09.2021
          • 6
          #49
          Hi, I'm new to this forum; I'm having troubles connecting to loxwiki web page....I've tried from different connected devices but it seems it's off-line....
          are you able to help?
          thanks a lot in advance,
          Leonardo
            • 5374
            #50
            Gast Gast
            Sorry, command is maybe:
            apt-get purge influxdb influxdb-client
              I did look into the issue a bit further and to me it seems to be related to the fact that influxdb cannot get its https site up and running. I did install the latest loxberry version on a spare raspberry pi 3b I had in my drawers and then installed the package and there it works like a charm ...
            Gast Gast
            Thanks. This (partly) worked - please see attached. However, re-install was not successful again - the same error message :-( . Any other idea what to do...?
              I did some further investigation on my system as the messages indicate it cannot access the db health pages after install . So i checked the ports in use on my system using the command
              "netstat -lptn"
              and found that on my system port 8088 was used by my FHEM api and 8086 by a docker-proxy.
              I changed my api to another port in FHEM and Loxone, uninstalled the docker plugin and then followed by the command
              "apt-get purge docker-ce docker-ce-cli containerd.io"
              and now i have the stats4lox working on my system
            • 6357
            #52
            This is not a reinstall. It‘s only a fully remove. Now you have to install the plugin
              • 5374
              #53
              Moin,
              wir haben wieder ein paar graue Haare wegen Influx mehr Aber nun haben wir wieder zahlreiche Probleme mit Influx lösen können. Das sollte auch viele Installationsprobleme, die ihr uns hier gemeldet habt, mit beheben.
              Wir haben alle Änderungen in einer neuen Beta-Version 0.9.2-BETA zusammengefasst. Es sollte ein normales Upgrade des Plugins funktionieren.
              Download: https://github.com/mschlenstedt/LoxB...0.9.2-beta.zip
              • BUGFIX: Optimize Startup of Influx on slow systems
              • BUGFIX: Deactivated values are not grabbed annymore
              • BUGFIX: Optimize Influx installation: purge older version if installed, kill influxdb instances if they cannot be stopped by service)
              • BUGFIX: Config-handler status were not shown in WebUI, mess-up of config-changes-checks, system was frozen while oving database to new location)
              • BUGFIX: Import-Button is desabled now when no Loxone statistic exists
              • Gargamel
                Gargamel kommentierte
                Kann das von Lenardo bestätigen. Update ohne Probleme durchgelaufen, Daten kommen reibungslos an.
                Vielen Dank.
              • ThatRed
                ThatRed kommentierte
                Das Upgrade hat das Plugin ganz schön weit nach vorne gebracht! Danke!!
                Sieht alles deutlich besser aus:
                - Der Influx Dienst wird nicht mehr gestoppt und die PID bleibt gleich
                - die CPU Load ist zurückgegangen und damit auch die Core Temperatur
                - es scheint auch mehr freier RAM Speicher zur Verfügung zu stehen
                PS.: Gaaaanz kleiner Fehler, die Versionsnummer ist gleich geblieben
                Ach Mist - die Versionsnummer hab ich vergessen ;-) Ist jetzt korrigiert.
            • Houseruckiii
              • 31.10.2016
              • 91
              #54
              Tach,
              wie darf/soll man 0.9.2 installieren wenn 0.9.1 schon läuft?
              "Re-Check for Updates" im Plugin Management bringt nix neues...
              Mit dem Github-Zip-Link einfach drüber installieren?
              Oder vorher 0.9.1 deinstallieren? Konfiguration+Daten bleiben (normalerweise/BETA...) auch beim deinstallieren erhalten?
              Mit 0.9.1 hab ich auch im Proxmox nach einen Loxberry reboot erhöhte CPU Usage.
Name: Loxberry CPU Reboot 01.jpg
Ansichten: 1332
Größe: 80,3 KB
              • hme0354
                hme0354 kommentierte
                Den link von #53 nehmen und drüberinstallieren
              • Houseruckiii
                Houseruckiii kommentierte
                Ok, Danke, hat soweit funktioniert! :-)
            • Houseruckiii
              • 31.10.2016
              • 91
              #55
              Mit 0.9.1 (nach reboot Loxberry) startet influxdb dauernd neu,,,vmtl. daher auch Bad Gateway...?
              Die grüne Zeile scheint die Ursache zu nennen?
              [FONT=monospace][COLOR=#000000]root@Loxberry:~# journalctl -b -r [/COLOR]
              -- Logs begin at Sun 2021-09-05 16:05:37 CEST, end at Sun 2021-09-05 16:11:17 CEST. --
              Sep 05 16:11:17 Loxberry systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
              Sep 05 16:11:17 Loxberry systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
              Sep 05 16:11:17 Loxberry systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 32.
              Sep 05 16:11:17 Loxberry systemd[1]: [COLOR=#16a085][SIZE=18px][B]influxdb.service: Service RestartSec=100ms expired, scheduling restart[/B][/SIZE][SIZE=16px][B].[/B][/SIZE][/COLOR]
              Sep 05 16:11:16 Loxberry systemd[1]: [COLOR=#ff5454][B]Failed to start InfluxDB is an open-source, distributed, time series database.[/B][/COLOR]
              Sep 05 16:11:16 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Failed with result 'exit-code'.[/B][/COLOR]
              Sep 05 16:11:16 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Control process exited, code=exited, status=1/FAILURE[/B][/COLOR]
              Sep 05 16:11:06 Loxberry systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
              Sep 05 16:11:06 Loxberry systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
              Sep 05 16:11:06 Loxberry systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 31.
              Sep 05 16:11:06 Loxberry systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
              Sep 05 16:11:06 Loxberry systemd[1]: [COLOR=#ff5454][B]Failed to start InfluxDB is an open-source, distributed, time series database.[/B][/COLOR]
              Sep 05 16:11:06 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Failed with result 'exit-code'.[/B][/COLOR]
              Sep 05 16:11:06 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Control process exited, code=exited, status=1/FAILURE[/B][/COLOR]
              Sep 05 16:11:01 Loxberry CRON[3918]: pam_unix(cron:session): session closed for user loxberry
              Sep 05 16:11:01 Loxberry CRON[3919]: (loxberry) CMD (cd / && for f in /opt/loxberry/system/cron/cron.01min/*; do ($f cron=01min > /dev/nul
              Sep 05 16:11:01 Loxberry CRON[3918]: pam_unix(cron:session): session opened for user loxberry by (uid=0)
              Sep 05 16:10:56 Loxberry systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
              Sep 05 16:10:56 Loxberry systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
              Sep 05 16:10:56 Loxberry systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 30.
              Sep 05 16:10:56 Loxberry systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
              Sep 05 16:10:55 Loxberry systemd[1]: [COLOR=#ff5454][B]Failed to start InfluxDB is an open-source, distributed, time series database.[/B][/COLOR]
              Sep 05 16:10:55 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Failed with result 'exit-code'.[/B][/COLOR]
              Sep 05 16:10:55 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Control process exited, code=exited, status=1/FAILURE[/B][/COLOR]
              Sep 05 16:10:45 Loxberry systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
              Sep 05 16:10:45 Loxberry systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
              Sep 05 16:10:45 Loxberry systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 29.
              Sep 05 16:10:45 Loxberry systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
              Sep 05 16:10:45 Loxberry systemd[1]: [COLOR=#ff5454][B]Failed to start InfluxDB is an open-source, distributed, time series database.[/B][/COLOR]
              Sep 05 16:10:45 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Failed with result 'exit-code'.[/B][/COLOR]
              Sep 05 16:10:45 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Control process exited, code=exited, status=1/FAILURE[/B][/COLOR]
              Sep 05 16:10:35 Loxberry systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
              Sep 05 16:10:35 Loxberry systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
              Sep 05 16:10:35 Loxberry systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 28.
              Sep 05 16:10:35 Loxberry systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
              Sep 05 16:10:34 Loxberry systemd[1]: [COLOR=#ff5454][B]Failed to start InfluxDB is an open-source, distributed, time series database.[/B][/COLOR]
              Sep 05 16:10:34 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Failed with result 'exit-code'.[/B][/COLOR]
              Sep 05 16:10:34 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Control process exited, code=exited, status=1/FAILURE[/B][/COLOR]
              Sep 05 16:10:24 Loxberry systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
              Sep 05 16:10:24 Loxberry systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
              Sep 05 16:10:24 Loxberry systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 27.
              Sep 05 16:10:24 Loxberry systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
              Sep 05 16:10:24 Loxberry systemd[1]: [COLOR=#ff5454][B]Failed to start InfluxDB is an open-source, distributed, time series database.[/B][/COLOR]
              Sep 05 16:10:24 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Failed with result 'exit-code'.[/B][/COLOR]
              Sep 05 16:10:24 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Control process exited, code=exited, status=1/FAILURE[/B][/COLOR]
              Sep 05 16:10:14 Loxberry systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
              Sep 05 16:10:14 Loxberry systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
              Sep 05 16:10:14 Loxberry systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 26.
              Sep 05 16:10:14 Loxberry systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
              Sep 05 16:10:13 Loxberry systemd[1]: [COLOR=#ff5454][B]Failed to start InfluxDB is an open-source, distributed, time series database.[/B][/COLOR]
              Sep 05 16:10:13 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Failed with result 'exit-code'.[/B][/COLOR]
              Sep 05 16:10:13 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Control process exited, code=exited, status=1/FAILURE[/B][/COLOR]
              Sep 05 16:10:03 Loxberry systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
              Sep 05 16:10:03 Loxberry systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
              Sep 05 16:10:03 Loxberry systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 25.
              Sep 05 16:10:03 Loxberry systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
              Sep 05 16:10:03 Loxberry systemd[1]: [COLOR=#ff5454][B]Failed to start InfluxDB is an open-source, distributed, time series database.[/B][/COLOR]
              Sep 05 16:10:03 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Failed with result 'exit-code'.[/B][/COLOR]
              Sep 05 16:10:03 Loxberry systemd[1]: [COLOR=#000000][B]influxdb.service: Control process exited, code=exited, status=1/FAILURE[/B][/COLOR][/FONT]
              • Houseruckiii
                Nice, mit 0.9.2 tritt das Problem mit höherer CPU Last nach reboot hier nicht auf :-)
            • guenther.wimmer@kt-net.at
              • 20.09.2015
              • 34
              #56
              Ich bekomme folgende Fehlermeldung wenn ich auf "Loxone and Import" gehe.
              Fetching Loxone Config from Miniservers...
              LoxBerry v. 2.2.1.2 (VM HyperV)
              Stats4Lox v. 0.9.2
              Verbindungstests zu den Miniservern funktioniert (2x Miniserver 1x Miniserver)
              OK: Loxone::GetLoxplan::getLoxplan--> Finished
              OK: Loxplan for MS1 found, parsing now...
              INFO: loxplan2json started
              INFO: Reading local Loxplan json
              INFO: Reading LoxBerry Miniserver list
              MS1: Added serial 504F941154B7
              INFO: Removing BOM of LoxPLAN input
              CRITICAL: import.cgi: Cannot parse LoxPLAN XML file: :119: parser error : attributes construct error
              7AB918E1383D8AC99291D24D1D2F7C4808422C5FDAA49D41B1 627359028A8229101BCA08E6C45r="
              :119: parser error : Couldn't find end of Start Tag C line 119
              :120: parser error : Char 0x0 out of allowed range
              963ist V12C4214" LD2AD1EC21-07685U="09a758BDA="20w
              :120: parser error : Premature end of data in tag C line 71
              :120: parser error : Premature end of data in tag C line 16
              :120: parser error : Premature end of data in tag C line 3
              :120: parser error : Premature end of data in tag ControlList line 2
              CRITICAL: Error parsing XML
              OK: Parameters ok - responding with HTTP 200
              06.09.2021 20:43:03 TASK FINISHED
                Wir haben ein Known Issue mit dem Lesen des LoxPlans, wenn ein eigenes Logo im Projekt hinterlegt ist. Ist das bei dir so?
                  • 20.09.2015
                  • 34
                  #58
                  "Firmenlogo verwenden" ist nicht angehakt.
                    Ich bin mir nicht sicher, ob ich gerade ein De Javú habe, aber mir war so, als hätte ich zu dem Thema schon mal geschrieben, dass ich das nur näher analysieren kann, wenn ich das Loxplan File (also das Projektfile der Loxone Config) per PM bekomme.
                    • skyrop
                      skyrop kommentierte
                      Hallo Christian
                      Ich wollte das Plugin auch testen, leider erhalte ich die gleiche Fehlermeldung wie bei Post 56 im getloxplan Log
                      wenn ich auf "Loxone and Import" gehe. Die Verbindung zum MS ist i.o. Ein Firmen Logo ist bei mir auch nicht hinterlegt.
                      Ich werde dir für die weitere Analyse die Loxone Config per PM zustellen.
                  • Gargamel
                    • 16.12.2018
                    • 775
                    #60
                    Ich lese meine Außentemperatur, Warmwassertemperatur usw. über den Vaillant eEbus aus.
                    Leider kann ich keine eEBus Werte ins Plugin einbinden.
                    Gibt es eine Möglichkeit die eeBus Werte einzubinden?
                      Werden die Bausteine im Plugin nicht aufgelistet?
                      Welchen „Type“ haben die im Loxone XML?
                    • toubee
                      toubee kommentierte
                      Hallo Gargamel
                      Ich kann das Verhalten bei Werten aus dem Vaillant eEbus bestätigen.
                      Als Workaround habe ich die eEbus-Eingänge mit einem Merker verbunden. Diesen Merker kannst Du anschliessend einlesen
